Can libraries be opened?
Old   November 16, 2010, 14:38
Default Can libraries be opened?
Usit McCarra
McCarra is on a distinguished road
Hello
I tried to open a library file and my computer returned an error: not able to detect character encoding. Does it mean that libraries can't be opened? I wanted to read one while trying to understand the whole code of a tutorial.
All the best
McCarra is offline   Reply With Quote
Old   November 17, 2010, 01:53
Kathrin Kissling
kathrin_kissling is on a distinguished road
can you tell me the path of the library: Do you try to open a file with some *.so ending?
If you tell me which library you are interested, maybe I can tell you how to find it.
Best Kathrin
kathrin_kissling is offline   Reply With Quote
Old   November 17, 2010, 04:12
Usit McCarra
I'm looking for "libfvmotionsolver.so" which is in /opt/
openfoam171/lib/linux64GccDPOpt/. Perhaps it ios a binary file and that's why I couldn't see it.
Are all ".so" files binary?
Old   November 17, 2010, 05:47
Kathrin Kissling
yes they are.
If you want to access the sourcecode you have to find the correspondig file in OpenFOAM-1.7.?/src
In your case you will find the corresponding source code in fvMotionSolver/fvMotionSolvers/fvMotionSolver/. There are three files which define the class.
Best
Kathrin
Old   November 17, 2010, 10:37
Usit McCarra
What do you mean by the corresponding file? Is the one in src the same as the one in lib? What is the relationship between them?
Many thanks Kathrin!
Old   November 17, 2010, 10:45
Kathrin Kissling
The "corresponding file" is the source code from which th *.so file was build.
so is short for shared object.
You might want to check out some literature on compiling. Usually there are some chapters on it in the programming languages books.
Best
Kathrin
Old   November 17, 2010, 10:59
Usit McCarra
Yes, that would be the answer. I'm trying to find an information source to better understand OpenFoam code.
Thanks for your help!
all the best
Can't profile shared libraries rsamuel OpenFOAM Programming & Development 1 August 3, 2009 09:58
Installation/Tutorial - libraries not found (blockMesh) bernarde OpenFOAM 3 June 19, 2009 12:36
Fortran90 (creating executable by using libraries) Ravi Main CFD Forum 0 September 27, 2004 22:34
help on POOMA/PVM etc. libraries mayank Main CFD Forum 0 November 14, 2002 23:04
More advise on libraries to solve linear system Ricardo Bonon Main CFD Forum 0 May 18, 2000 18:37
