Averaging due to parallel running - cuttingPlane
Like Tree3Likes
  • 1 Post By woody
  • 2 Post By woody
Old   December 8, 2010, 07:42
Default Averaging due to parallel running - cuttingPlane
Tobias Holzinger
woody is on a distinguished road
Dear All,
I am actually implementing a boundary condition that accesses some Field values like p, U, rho from cutting planes inside the mesh. As only the average of the cut Field is of interest, I have to create some kind of weighting factor for each processor part.
So far the Code looks like this:
   // Create the cutting Planes
   point planeLocation = planeLocations[planeI];
   plane extPlane(planeLocation,orientPatch);
   cuttingPlane cuttedPlane(extPlane,this->dimensionedInternalField().mesh());
   vector averageUPRho(0.0,0.0,0.0);
   scalar weigthPatch;
   // Compute the the cut of each processor
   if (cuttedPlane.cut()== 1)
    averageUPRho.component(0)= (average(cuttedPlane.sample(Ufield)) & orientPatch); // The mean Velocity in normal Direction
    averageUPRho.component(1)= average(cuttedPlane.sample(pfield));// The mean Pressure
    averageUPRho.component(2)=average(cuttedPlane.sample(rhofield));// The mean Density
    weigthPatch= cuttedPlane.size(); // The weighting factor
    else
    weigthPatch=0;
Now I forward the averageUPRho and the weigthPatch to the Master and do the averaging with
rhoMean=sum(averageUPRho*weigthPatch)/sum(weigthPatch);
unfortunately I weight by the number of faces and not by their Area (magSf for patches works ... not for planes?).
How can I acces them??
Any hints?
solefire likes this.
woody is offline   Reply With Quote
Old   December 8, 2010, 10:35
Laurence R. McGlashan
l_r_mcglashan will become famous soon enough
I notice that sampledPlane inherits from sampledSurface and cuttingPlane. sampledSurface has an area() function. Would that help you? Could you create a sampledPlane from your plane?
Laurence R. McGlashan :: Website
l_r_mcglashan is offline   Reply With Quote
Old   December 8, 2010, 10:54
Tobias Holzinger
It worked...
just adding / editing 2 lines...
sampledPlane smpPl("smpPl",this->dimensionedInternalField().mesh(),extPlane);
weigthPlane= sum(smpPl.magSf());
mm.abdollahzadeh and Pagoda like this.
Old   December 8, 2010, 11:58
You can replace weightPlane with smpPI.area()
Also because samplePlane inherits from cuttingPlane, you probably don't need cuttedPlane and can just use smpPI?
Old   December 9, 2010, 03:33
Tobias Holzinger
Hi Laurence,
Thanks for the reply...
area() unfortunately passes the total plane magnitude, not only the part a processor contains ....
...this works fine...
Thanks so far...
area, averaging, cuttingplane, parallel processing
Running decomposePar / reconstructPar as parallel apps? carcass OpenFOAM Running, Solving & CFD 3 January 17, 2024 07:19
Segmentation fault when running dieselFoam or dieselEngineFoam in parallel francesco OpenFOAM Bugs 4 May 2, 2017 21:59
Issue with running in parallel on multiple nodes daveatstyacht OpenFOAM 7 August 31, 2010 17:16
Error while running in PARALLEL Ravi Duggirala FLUENT 4 August 3, 2010 10:01
Parallel CFD Conference Abstracts Due Feb 5th Pat Fox Main CFD Forum 1 January 21, 1999 14:01
