Operation to READ_IF_PRESENT field
Like Tree2Likes
  • 1 Post By niklas
  • 1 Post By niklas
Old   September 17, 2009, 08:28
Default Operation to READ_IF_PRESENT field
sega's Avatar
Sebastian Gatzka
sega is on a distinguished road
Hello World.
What happens to an operation like
volVectorField us = fvc::interpolate(U)
done to to a field (U in this case) which is READ_IF_PRESENT?
Will this operation cause an error or will it just be skipped if the field is not present?!
Schrödingers wife: "What did you do to the cat? It's half dead!"
sega is offline   Reply With Quote
Old   September 17, 2009, 09:17
niklas's Avatar
Niklas Nordin
niklas will become famous soon enoughniklas will become famous soon enough
READ_IF_PRESENT just means that the field will be read from disk if it is available,
otherwise it will be set to the value given in the constructor.
niklas is offline   Reply With Quote
Old   February 12, 2011, 03:39
Default ....
Mohammad.R.Shetab
mrshb4 is on a distinguished road
Hi
[READ_IF_PRESENT just means that the field will be read from disk if it is available,
otherwise it will be set to the value given in the constructor. ]
What do you mean the value given in the constructor?
mrshb4 is offline   Reply With Quote
Old   February 14, 2011, 02:14
niklas's Avatar
Niklas Nordin
volScalarField hTotal
    IOobject
        "hTotal",
        runTime.timeName(),
        mesh,
        IOobject::READ_IF_PRESENT,
        IOobject::AUTO_WRITE
    h+h0
In the above example,
if the file hTotal exists, the value will be read from that file.
Otherwise it will use the values from 'h+h0'
rajibroy likes this.
Old   February 14, 2011, 04:13
Mohammad.R.Shetab
Hi Niklas
Thanks for your reply.
I have another problem, that by now I've couldn't solve that!
I'm solving an equiation with a source term, like:
ddt2(p)-laplacian(p)=q
(source term is q)
I calculate source term from another solver every 1e-5 second and bring all of them in time directories in this solver.
The time interval of this solver is 1e-8 and I want that this solver reads every q whenever it reachs its time. For example at first it reads q in 0 directory and work with that, but when it reachs 1e-5 q should be read and changed and so on.......
Do you know how should I define q to be read like this?!?
Thank you
Mohammadreza
Old   February 14, 2011, 04:27
niklas's Avatar
Niklas Nordin
You read q at start so that volScalarField exists already, then you place the code below
just before the equation you want to solve
    IOobject qHeader
        "q",
        runTime.timeName(),
        mesh,
        IOobject::NO_READ
    if (qHeader.headerOk())
        volScalarField qNew
            IOobject
                "q",
                runTime.timeName(),
                mesh,
                IOobject::MUST_READ,
                IOobject::NO_WRITE
            mesh
        q = qNew;
    // ... solve the equation with the new q
This will try and read a new field every time step, but it will only update it when it exists
Roozbeh_Sa likes this.
Old   February 15, 2011, 09:57
Mohammad.R.Shetab
Hi Niklas
Thank you so much for your reply...with a little modification it worked properly.
Mohammadreza
Phase Field modeling in OpenFOAM adona058 OpenFOAM Running, Solving & CFD 35 November 16, 2021 00:16
Adding Temperature field to IcoFoam yapalparvi OpenFOAM Programming & Development 14 November 19, 2015 04:57
Moving mesh Niklas Wikstrom (Wikstrom) OpenFOAM Running, Solving & CFD 122 June 15, 2014 06:20
Problem with rhoSimpleFoam matteo_gautero OpenFOAM Running, Solving & CFD 0 February 28, 2008 06:51
Initial Condition in 3D flows. shekharc Main CFD Forum 9 June 8, 2005 04:17
