Describing div terms in fvSchemes
Like Tree3Likes
  • 1 Post By santiagomarquezd
  • 2 Post By santiagomarquezd
Old   February 28, 2011, 21:36
Default Describing div terms in fvSchemes
santiagomarquezd's Avatar
Santiago Marquez Damian
santiagomarquezd will become famous soon enough
Hi FOAMers, I have a solver with this code:
    fvVectorMatrix UEqn
        fvm::ddt(rhom, U)
      + fvm::div(phi, U)
      + fvc::div
            alpha*rhop*Vdrp*Vdrp,
            "div(phiVdrp,Vdrp)"
      - fvm::laplacian(mum, U, "laplacian(mum,U)")
when I run the solver I obtain this error:
--> FOAM FATAL IO ERROR:
keyword div(phiVdrp,Vdrp) is undefined in dictionary "/home/santiago/OpenFOAM/santiago-1.6.x/run/tankBubbles/system/fvSchemes::divSchemes"
file: /home/santiago/OpenFOAM/santiago-1.6.x/run/tankBubbles/system/fvSchemes::divSchemes from line 30 to line 32.
    From function dictionary::lookupEntry(const word&, bool, bool) const
    in file db/dictionary/dictionary.C at line 396.
FOAM exiting
then if I add this:
divSchemes
    div(phi,U)  Gauss upwind; //limitedLinearV 1;
    div(rhop*phi,alpha) Gauss upwind;
    div(phiVdrp,alpha) Gauss upwind;
    div(phiVdrp,Vdrp) Gauss upwind;
to my system/fvSchemes dictionary I still get an error, but a different one:
attempt to read beyond EOF
file: /home/santiago/OpenFOAM/santiago-1.6.x/run/tankBubbles/system/fvSchemes::divSchemes::div(phiVdrp,Vdrp) at line 33.
From function ITstream::read(token& t)
in file db/IOstreams/Tstreams/ITstream.C at line 84.
FOAM exiting
Any clues about that?, I've checked some similar threads without success.
Regards.
Santiago MÁRQUEZ DAMIÁN, Ph.D.
Research Scientist
Research Center for Computational Methods (CIMEC) - CONICET/UNL
Tel: 54-342-4511594 Int. 7032
Colectora Ruta Nac. 168 / Paraje El Pozo
(3000) Santa Fe - Argentina.
http://www.cimec.org.ar
santiagomarquezd is offline   Reply With Quote
Old   March 1, 2011, 04:57
akidess's Avatar
Anton Kidess
The divergence schemes in fvSchemes apply to convective terms like fvm::div(phi, X), but your term in the equation seems to be a simple explicit divergence of a scalar field, so why not just write it in the following way?
 fvVectorMatrix UEqn
        fvm::ddt(rhom, U)
      + fvm::div(phi, U)
      + fvc::div
Old   March 1, 2011, 12:06
Anton, I took this notation from settlingFoam, but on the other hand I'd tried you suggested with same results:
    fvVectorMatrix UEqn
        fvm::ddt(rhom, U)
      + fvm::div(phi, U)
      + fvc::div
error obtained at runtime:
keyword div((((alpha*rhop)*Vdrp)*Vdrp)) is undefined in dictionary "/home/santiago/OpenFOAM/santiago-1.6.x/run/tankBubbles/system/fvSchemes::divSchemes"
FOAM exiting
adding corresponding line in system/fvSchemes
file: /home/santiago/OpenFOAM/santiago-1.6.x/run/tankBubbles/system/fvSchemes::divSchemes::div((((alpha*rhop)*Vdrp)*Vd rp)) at line 34.
FOAM exiting
Regards.
Kummi likes this.
Research Scientist
Old   March 1, 2011, 13:03
akidess's Avatar
Anton Kidess
Ah, you are right, looking at fvcDiv.* it is indeed possible to name even an explicit term and force usage of a certain divergence scheme instead of plainly calling surfaceIntegrate. I'm sorry I don't really have other ideas what could cause the problem. Hopefully someone else will notice this thread and have an answer.
Old   March 1, 2011, 15:15
Anton, the correct entry in fvSchemes is:
divSchemes
    div(phi,alpha) Gauss upwind;
   div(phiVdrp,Vdrp) Gauss upwind phiVdrp;
it's necessary to explicitly write the flux which will be used in order to interpolate the values at faces. Early alberto shown me the wording to include the flux properly.
Regards.
kiddmax and Stratos_ like this.
Research Scientist
Implicit treatment of advection terms and pressure correction nikosb Main CFD Forum 0 January 17, 2010 16:07
Using source terms jsm Main CFD Forum 4 August 20, 2009 06:44
Question in definition of terms in solve titio OpenFOAM Running, Solving & CFD 0 March 19, 2009 16:02
Source terms for additional variable transport eqn Nandini Rohilla CFX 0 February 6, 2004 13:38
K-Epsilon model? Brindaban Ghosh Main CFD Forum 2 June 24, 2000 04:22
