March 29, 2011, 04:59 |
p_rgh in OpenFOAM-1.6
Vesselin Krastev
Rep Power: 20 |
Hi all, I'm trying to modify the chtMultiregionFoam solver of OpenFOAM 1.6 adding some of the characteristics of the 1.7.1 version. Apart from the details, I need the 1.6 solver to recognize p_rgh as the new pressure variable for which the solution procedure is performed. I've modified the pEqn.H file in order to reach the goal, but after a seemingly correct compilation when I try to run a test case this is the error message coming out:
Solving for fluid region fluid1 diagonal: Solving for rho, Initial residual = 0, Final residual = 0, No Iterations 0 DILUPBiCG: Solving for Ux, Initial residual = 1, Final residual = 2.5150392e-08, No Iterations 2 DILUPBiCG: Solving for Uy, Initial residual = 1, Final residual = 9.5553996e-09, No Iterations 2 DILUPBiCG: Solving for Uz, Initial residual = 1, Final residual = 6.502438e-09, No Iterations 2 DILUPBiCG: Solving for h, Initial residual = 1, Final residual = 3.847947e-09, No Iterations 2 Min/max T:300 363 keyword p is undefined in dictionary "/work/alh/vesselin/myMultiRegionCase_4_liquid/system/fluid1/fvSolution::solvers" file: /work/alh/vesselin/myMultiRegionCase_4_liquid/system/fluid1/fvSolution::solvers from line 21 to line 124. From function dictionary::subDict(const word& keyword) const in file db/dictionary/dictionary.C at line 449. FOAM exiting Any suggestion to fix the problem? Is it possible to redefine the keyword for the pressure variable? Thank you in advance V. PS-Please, do not answer: "Switch to OF-1.7.1 instead of breaking your head on how to modify the 1.6 version...". I know this could be the simplest solution bur unfortunately I must do it the above way.... |
March 30, 2011, 04:31 |
Alberto Passalacqua
Rep Power: 36 |
Hi Vesselin,
the keyword is based on the database entry of the field name, so that's what you have to change, not the name of the variable in the code. In other words the field name between " " in the field definition. Best,
Alberto Passalacqua GeekoCFD - A free distribution based on openSUSE 64 bit with CFD tools, including OpenFOAM. Available as in both physical and virtual formats (current status: http://albertopassalacqua.com/?p=1541) OpenQBMM - An open-source implementation of quadrature-based moment methods. To obtain more accurate answers, please specify the version of OpenFOAM you are using. |
March 30, 2011, 06:29 |
#3 | |
Vesselin Krastev
Rep Power: 20 |
Thanks once again V. |
March 30, 2011, 15:00 |
Alberto Passalacqua
Rep Power: 36 |
The database with the list of objects used in your run is created in memory at runtime by the code. Take a look at the objectRegistry.
March 31, 2011, 09:35 |
#5 | |
Vesselin Krastev
Rep Power: 20 |
Solving for fluid region fluid1 diagonal: Solving for rho, Initial residual = 0, Final residual = 0, No Iterations 0 DILUPBiCG: Solving for Ux, Initial residual = 1, Final residual = 2.5150392e-08, No Iterations 2 DILUPBiCG: Solving for Uy, Initial residual = 1, Final residual = 9.5553996e-09, No Iterations 2 DILUPBiCG: Solving for Uz, Initial residual = 1, Final residual = 6.502438e-09, No Iterations 2 DILUPBiCG: Solving for h, Initial residual = 1, Final residual = 3.847947e-09, No Iterations 2 Min/max T:300 363 GAMG: Solving for p_rgh, Initial residual = 0.81016096, Final residual = 0.0049955858, No Iterations 18 diagonal: Solving for rho, Initial residual = 0, Final residual = 0, No Iterations 0 time step continuity errors (fluid1): sum local = 3.2337637e-05, global = 1.1811838e-07, cumulative = 1.1811838e-07 GAMG: Solving for p_rgh, Initial residual = 0.0019349904, Final residual = 1.4132342e-05, No Iterations 12 diagonal: Solving for rho, Initial residual = 0, Final residual = 0, No Iterations 0 time step continuity errors (fluid1): sum local = 5.6645344e-06, global = -7.9588068e-07, cumulative = -6.7776229e-07 GAMG: Solving for p_rgh, Initial residual = 9.3519277e-05, Final residual = 4.8533869e-08, No Iterations 16 diagonal: Solving for rho, Initial residual = 0, Final residual = 0, No Iterations 0 time step continuity errors (fluid1): sum local = 1.8940969e-08, global = -1.140037e-09, cumulative = -6.7890233e-07 #0 Foam::error:rintStack(Foam::Ostream&) in "/work/alh/vesselin/OpenFOAM///OpenFOAM-1.6/lib/linux64GccDPOpt/libOpenFOAM.so" #1 Foam::sigFpe::sigFpeHandler(int) in "/work/alh/vesselin/OpenFOAM///OpenFOAM-1.6/lib/linux64GccDPOpt/libOpenFOAM.so" #2 ?? in "/lib64/libc.so.6" #3 Foam::compressible::RASModels::epsilonWallFunction FvPatchScalarField::updateCoeffs() in "/work/alh/vesselin/OpenFOAM///OpenFOAM-1.6/lib/linux64GccDPOpt/libcompressibleRASModels.so" #4 Foam::compressible::RASModels::kEpsilon::correct() in "/work/alh/vesselin/OpenFOAM///OpenFOAM-1.6/lib/linux64GccDPOpt/libcompressibleRASModels.so" #5 main in "/work/alh/vesselin/OpenFOAM/OpenFOAM-1.6/applications/bin/linux64GccDPOpt/myChtMultiRegionFoam" #6 __libc_start_main in "/lib64/libc.so.6" #7 Foam::regIOobject::writeObject(Foam::IOstream::str eamFormat, Foam::IOstream::versionNumber, Foam::IOstream::compressionType) const in "/work/alh/vesselin/OpenFOAM/OpenFOAM-1.6/applications/bin/linux64GccDPOpt/myChtMultiRegionFoam" Floating exception Any ideas on what is going on? BCs and initial conditions are identical to those that work perfectly with chtMRF in OpenFOAM 1.7.1 (this is the updated version with the capability to handle liquid fluids governed by an incompressible polynomial equation of state)... Thanks V. |
[swak4Foam] OpenFOAM 1.6 and 1.7 with interFoam, groovyBC give different strange results | Arnoldinho | OpenFOAM Community Contributions | 7 | December 9, 2010 16:29 |
kOmegaSST in openfoam 1.6 | Gearb0x | OpenFOAM | 2 | March 3, 2010 06:02 |
Cross-compiling OpenFOAM 1.6 on Linux for Windows 32 and 64bits with Mingw-w64 | wyldckat | OpenFOAM Announcements from Other Sources | 7 | January 19, 2010 15:39 |
OpenFOAM 1.6 package - CentOS 5.3 x86_64 | linnemann | OpenFOAM Installation | 36 | September 2, 2009 12:46 |
OpenFOAM Version 1.6 Released | opencfd | OpenFOAM Announcements from ESI-OpenCFD | 0 | July 27, 2009 17:55 |
