mixedValue BC reads different Values than fixedGradient BC
Old   September 15, 2017, 11:29
Default mixedValue BC reads different Values than fixedGradient BC
lohoko is on a distinguished road
Hi Guys!
I'm very new to the forum, but reading some of the threads here always helped a lot! Unfortunately I haven't found anything on my topic.
I am using the solidDisplacement Solver of OpenFOAM-2.3.x (but I couldn't find a solution for my problem on any newer or different Version).
Currently I am trying to "transform" the tractionDisplacement boundary condition, which is fixedGradient into mixedValue, so I can set a specific value at the boundary for certain conditions.
So I copied the code and changed the settings from fixedGradient to mixedValue (in the constructors part and .H file). I cut the codes, so nothing is calculated, but only the sigmaD value read and put out. I tried the code by just testing the following lines
    const fvPatchField<symmTensor>& sigmaD =
        patch().lookupPatchField<volSymmTensorField, symmTensor>("sigmaD");
Info << "sigmaD" << max((sigmaD)) << " min " << min((sigmaD)) << endl;
I made sure that the code doesn't do anything else, for both BCs fixedGradient and mixedValue. But unfortunately the sigmaD values vary a lot. While the fixedGradient BC is getting values between -7500 and +7500, the midexValue BC gets values between -2e+09 and +2e+08.
This seems very strange to me.
Can anybody help me? Did I miss anything with the constructors? Does that even influence the value?
lohoko
lohoko is offline   Reply With Quote
TimeVaryingMappedFixedValue irishdave OpenFOAM Running, Solving & CFD 32 June 16, 2021 06:55
Setting patch field values equal to internal field values leroyv OpenFOAM Programming & Development 1 October 21, 2014 15:49
Loading Cell Values in Tecplot P1361 OpenFOAM Post-Processing 3 September 16, 2014 04:02
[swak4Foam] About groovyBC to set distributed fixedGradient values for each cell boundary patch nwpukaka OpenFOAM Community Contributions 6 August 12, 2014 06:34
Plotting raw data values Wilesco Siemens 0 January 5, 2006 05:34
