the format of adding volVectorField term into equation
Old   March 15, 2017, 14:47
Post the format of adding volVectorField term into equation
Linyan X
linyanx is on a distinguished road
Dear OpenFOAMers,
I have a quick question regarding the volVectorField. How can we implement the volVectorField term into the equation?
Like, for example, UEqn.H in interMixingFoam. After defining a volVectorField in createField.H named 'F'. I want to add the force term(which is a vector term) into the UEqn.H, written as 'interpolate(F)'. But the system will always complain about the format of this vector term.
My UEqn.H is partially quoted below:
UEqn
fvc::reconstruct
mixture.surfaceTensionForce()
- ghf*fvc::snGrad(rho)
- fvc::snGrad(p_rgh)
+ interpolate(F) ----The term I want to add.
) * mesh.magSf()
Hence, I look over all the source code in openfoam's solver package, but still have no idea of the solution. Really appreciate your help.
Regards,
Linyan
linyanx is offline   Reply With Quote
Old   March 16, 2017, 09:27
Default Solved:outside of reconstruct statement
Linyan X
Thanks to Fanny's kindly answer here. The volVectorField F is supposed to be ok when it was written at the right side of the UEqn. Hence, the code is corrected as follow:
PHP Code:
solve
UEqn
fvc::reconstruct
fvc::snGrad(p_rgh)
mesh.magSf()
//*               Modified on Mar/16            *//
F
Adding a source term to k and epsilon equation for buoyancy rajeshkunwar OpenFOAM Running, Solving & CFD 2 April 19, 2019 07:41
Adding a Source Term to Pressure equation pEqn in SimpleFoam oscar_urri OpenFOAM 11 February 22, 2018 17:52
adding a constant volumetric source term to transport equation in a particular region cfdonline2mohsen OpenFOAM Programming & Development 15 February 16, 2017 09:55
Source term energy equation for reactive flows DaIN Main CFD Forum 0 October 6, 2011 15:11
bouyancy term in epsilon equation Michael Main CFD Forum 1 June 25, 1999 10:20
