change symmetric lduMatrix into asymmetric
Old   August 24, 2011, 05:19
Default change symmetric lduMatrix into asymmetric
Marek
marek88 is on a distinguished road
The fvm::laplacian(psi) returns a symmetric matrix M.
I am trying to modify single entries of this matrix by accessing M.upper() and M.lower(). Unfortunately every modification of M.upper() is treated as if M.lower() is modified as well, because a symmetric matrix holds only one shared pointer for both fields.
How can I change this matrix into an asymmetric matrix?
lduMatrix::upper() is implemented such that it duplicates (*lowerPtr_) into a new scalarField, if only *lowerPtr_ exists but not *upperPtr_.
Unfortunately, this is not implemented vice versa: fvm::laplacian(psi) is written such that it defines only *upperPtr_ but not *lowerPtr_. And lduMatrix::lower() does not duplicate (*upperPtr_) into a new scalarField if (*lowerPtr_) doesn't exist.
Can somebody help?
Marek
marek88 is offline   Reply With Quote
Old   August 24, 2011, 08:44
David Gaden
marupio is on a distinguished road
All you need to do is make a non-const access request for both the upper and lower. Just write:
M.upper();
M.lower();
If your M is not const, then your matrix is now asymmetric... Although at this point upper and lower are still the same.
marupio is offline   Reply With Quote
Old   August 24, 2011, 09:02
Marek
Thank you, marupio, you are right.
I was confused by the lduMatrix source code, when I wrote about different implementations of lower() and upper(). Actually both are implemented equivalent.
Marek
Change cell zone index/thread during simulation neilduffy1024 FLUENT 0 January 17, 2011 09:40
Merits and Demerits of symmetric and asymmetric re Mukkarum Husain Main CFD Forum 0 January 7, 2009 08:46
asymmetric solution generated by symmetric problem Twiti CFX 7 October 16, 2004 19:12
Multicomponent fluid Andrea CFX 2 October 11, 2004 05:12
Symmetric problem - Asymmetric prediction Mark Main CFD Forum 14 January 29, 2001 13:21
