Viscosity model in the twoPhaseEulerFoam
Old   February 29, 2012, 23:43
Default Viscosity model in the twoPhaseEulerFoam
Jeong Kim
enoch is on a distinguished road
I'm not using the kinetic theory for the solid-phase stress tensor, but I could borrow "viscosity models" used in the solver.
For the solid phase, the momentum equation is
dUa/dt = div( nuEffa*TAU) + ...
where nuEffa=mua/rhoa
I'd like to use the BirdCarreau viscosity model for mua. mua is a function of strainRate and alpha where mua_inf, mua_0, k, and n are constants.
I checked non-newtonian solver and its viscosity models, and I tried to implement the modified BirdCarreau viscosity model located in the folder:
../twoPhaseEulerFoamMod/kineticTheoryModels/viscosityModel/BirdCarreau
When I compiled kineticTheoryModels using wmake libso, it failed. Could you give me your direction or remedy? Attached are files for the viscosity model.
enoch is offline   Reply With Quote
Old   March 1, 2012, 02:42
Laurens Van Dyck
laurensvd is on a distinguished road
Whats the error message?
laurensvd is offline   Reply With Quote
Old   March 1, 2012, 11:09
Jeong Kim
Below is what I've got on my monitor screen.
viscosityModel/BirdCarreau/BirdCarreauViscosity.C: At global scope:
viscosityModel/BirdCarreau/BirdCarreauViscosity.C:91: error: prototype for ‘Foam::tmp<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> > Foam::kineticTheoryModels::BirdCarreauViscosity::m ua(const Foam::volScalarField&, const Foam::volVectorField&) const’ does not match any in class ‘Foam::kineticTheoryModels::BirdCarreauViscos ity’
viscosityModel/BirdCarreau/BirdCarreauViscosity.H:100: error: candidates are: Foam::tmp<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> > Foam::kineticTheoryModels::BirdCarreauViscosity::m ua(const Foam::volScalarField&, int) const
viscosityModel/BirdCarreau/BirdCarreauViscosity.H:69: error: Foam::tmp<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> > Foam::kineticTheoryModels::BirdCarreauViscosity::m ua() const
viscosityModel/BirdCarreau/BirdCarreauViscosity.C:110: error: ‘oam’ has not been declared
viscosityModel/BirdCarreau/BirdCarreauViscosity.C:112: error: ISO C++ forbids declaration of ‘dictionary’ with no type
viscosityModel/BirdCarreau/BirdCarreauViscosity.C:112: error: expected ‘,’ or ‘...’ before ‘&’ token
viscosityModel/BirdCarreau/BirdCarreauViscosity.C: In function ‘bool read(int)’:
viscosityModel/BirdCarreau/BirdCarreauViscosity.C:115: error: ‘viscosityModel’ has not been declared
viscosityModel/BirdCarreau/BirdCarreauViscosity.C:115: error: ‘viscosityProperties’ was not declared in this scope
viscosityModel/BirdCarreau/BirdCarreauViscosity.C:117: error: ‘BirdCarreauViscosityCoeffs_’ was not declared in this scope
viscosityModel/BirdCarreau/BirdCarreauViscosity.C:117: error: ‘typeName’ was not declared in this scope
viscosityModel/BirdCarreau/BirdCarreauViscosity.C:119: error: ‘nu0_’ was not declared in this scope
viscosityModel/BirdCarreau/BirdCarreauViscosity.C:120: error: ‘nuInf_’ was not declared in this scope
viscosityModel/BirdCarreau/BirdCarreauViscosity.C:121: error: ‘k_’ was not declared in this scope
viscosityModel/BirdCarreau/BirdCarreauViscosity.C:122: error: ‘n_’ was not declared in this scope
In file included from viscosityModel/BirdCarreau/BirdCarreauViscosity.H:37,
from viscosityModel/BirdCarreau/BirdCarreauViscosity.C:26:
lnInclude/viscosityModel.H: In static member function ‘static Foam::autoPtr<Foam::kineticTheoryModels::viscosity Model> Foam::kineticTheoryModels::viscosityModel::adddict ionaryConstructorToTable<viscosityModelType>::New( const Foam::dictionary&) [with viscosityModelType = Foam::kineticTheoryModels::BirdCarreauViscosity]’:
lnInclude/viscosityModel.H:86: instantiated from ‘Foam::kineticTheoryModels::viscosityModel::adddic tionaryConstructorToTable<viscosityModelType>::add dictionaryConstructorToTable(const Foam::word&) [with viscosityModelType = Foam::kineticTheoryModels::BirdCarreauViscosity]’
viscosityModel/BirdCarreau/BirdCarreauViscosity.C:42: instantiated from here
lnInclude/viscosityModel.H:77: error: cannot allocate an object of abstract type ‘Foam::kineticTheoryModels::BirdCarreauViscos ity’
viscosityModel/BirdCarreau/BirdCarreauViscosity.H:53: note: because the following virtual functions are pure within ‘Foam::kineticTheoryModels::BirdCarreauViscos ity’:
lnInclude/viscosityModel.H:109: note: virtual Foam::tmp<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> > Foam::kineticTheoryModels::viscosityModel::mua(con st Foam::volScalarField&, const Foam::volScalarField&, const Foam::volScalarField&, const Foam::dimensionedScalar&, const Foam::dimensionedScalar&, const Foam::dimensionedScalar&) const
make: *** [Make/linuxGccDPOpt/BirdCarreauViscosity.o] Error 1
Old   March 17, 2016, 09:53
Default Solved?
Vinícius da Costa Ávila
avila.vc is on a distinguished road
Enoch, have you managed to solve the problem?
Vinícius dC.A.
avila.vc is offline   Reply With Quote
Implementing new viscosity model prjohnston OpenFOAM Running, Solving & CFD 6 July 3, 2015 04:26
Yielding viscosity for Herschel Bulkley model Godwin FLUENT 1 December 12, 2011 05:42
Help with choosing a viscosity model xTamx420 FLUENT 5 July 4, 2011 17:09
Eddy Viscosity Model Parameters Tristan CFX 5 January 20, 2010 15:25
Casson Viscosity model as one user define function Zahra Rahmdel FLUENT 0 November 6, 2004 05:53
