Neighbor of a boundary face
Old   March 9, 2012, 19:36
Default Neighbor of a boundary face
Senthil Kabilan
skabilan is on a distinguished road
Hi Foamers,
I need to access the neighboring faces of boundary face. I have the following code:
label patchID = mesh.boundaryMesh().findPatchID("walls");
const polyPatch& cPatch = mesh.boundaryMesh()[patchID];
forAll(cPatch, facei)
I need to access the neighboring FACES of facei
Thanks in advance!
Senthil
skabilan is offline   Reply With Quote
Old   March 10, 2012, 02:36
Disabled
anon_a is on a distinguished road
    List<List<bool> > neighbourFace;                          // a list for each face,
        // a list of bools for the other faces of the patch
        // The bool responds to whether they are neighbour faces or not
    neighbourFace.setSize(cPatch.size());
    forAll(cPatch, faceI)                                             // faceI: the face whose neighbour faces we want
        neighbourFace[faceI].setSize(cPatch.size());
        forAll(cPatch, faceJ)                                         // faceJ: possible neighbour face
            neighbourFace[faceI][faceJ] = false;
            if (faceI != faceJ)                                        // if they are the same, they can't be neighbours
                forAll(cPatch[faceI], pointI)                       // check all points of which faceI consists
                    forAll(cPatch[faceJ], pointJ)                   // and compare them with the ones of faceJ
                        if (cPatch[faceI][pointI] == cPatch[faceJ][pointJ])
                                neighbourFace[faceI][faceJ] = true;
I have only tested that briefly but it seems to be working.
I check if there are common points but you can easily modify it to check if there are common edges only.
anon_a is offline   Reply With Quote
Old   March 10, 2012, 14:41
Senthil Kabilan
Hi anon_a,
Thank you for the help!
Cheers!
Senthil
[Other] mesh airfoil NACA0012 anand_30 OpenFOAM Meshing & Mesh Conversion 13 March 7, 2022 17:22
CFX13 Post Periodic interface EtaEta CFX 7 December 8, 2011 17:15
channelFoam for a 3D pipe AlmostSurelyRob OpenFOAM 3 June 24, 2011 13:06
[blockMesh] BlockMesh FOAM warning gaottino OpenFOAM Meshing & Mesh Conversion 7 July 19, 2010 14:11
Boundary conditions? Tom Main CFD Forum 0 November 5, 2002 01:54
