Mutiphase flow solver
Old   March 4, 2012, 20:53
Default Mutiphase flow solver
TGH
Tarsilo Girona
TGH is on a distinguished road
Dear OpenFoam Community,
I hope everything is fine with you. I have some doubts with OpenFoam that I would like to share with you. Maybe you can solve them. I am using the multiphase flow solver TwoLiquidsMixingFoam. The momentum equation is in Ueqn.H. I don't understand:
1)
Why the gravity term is
ghf*fvc::snGrad(rho)
instead of only ghf*rho
Why this surface normal gradient in rho??
3) Why the pressure gradient term is:
fvc::snGrad(p_rgh)
instead of only
fvc:: grad(p_rgh)
Why surface normal gradient?
Does anyone have any idea??? Any suggestions are welcome. Thanks a lot in advance
TGH is offline   Reply With Quote
Old   March 20, 2012, 08:59
santiagomarquezd's Avatar
Santiago Marquez Damian
santiagomarquezd will become famous soon enough
Hi, check the following thread, particularly the post #9
http://www.cfd-online.com/Forums/ope...-pressure.html
Regards
Santiago MÁRQUEZ DAMIÁN, Ph.D.
Research Scientist
Research Center for Computational Methods (CIMEC) - CONICET/UNL
Tel: 54-342-4511594 Int. 7032
Colectora Ruta Nac. 168 / Paraje El Pozo
(3000) Santa Fe - Argentina.
http://www.cimec.org.ar
santiagomarquezd is offline   Reply With Quote
Solver for an incompressible, turbulent flow with heat transfer tH3f0rC3 OpenFOAM Running, Solving & CFD 9 June 17, 2019 06:12
compressible flow calculation error using rhoSimpleFoam solver student4326 OpenFOAM Running, Solving & CFD 7 November 2, 2015 11:34
How do I select solver options for external flow over an aircraft by fluent? hadieliasi FLUENT 5 May 2, 2011 03:54
pre-conditioning for low mach number compressible flow solver Shenren_CN Main CFD Forum 0 April 29, 2011 21:07
fluid flow fundas ram Main CFD Forum 5 June 17, 2000 21:31
