Unknown patchTypefield "turbulentIntensityKineticEnergyInlet" |
March 30, 2012, 05:37 |
Aram Amouzandeh
Rep Power: 17 |
dear all,
i created a utility for post processing where i manipulate variables of the RAS turbulence model (in OF-1.7.1). when i apply it to a case using the "turbulentIntensityKineticEnergyInlet" BC for k, the utility crashes at the line Code:
const volSymmTensorField RS = RASModel->R(); HTML Code:
--> FOAM FATAL ERROR: Unknown patchTypefield type turbulentIntensityKineticEnergyInlet Valid patchField types are : 30 ( advective calculated compressible::kqRWallFunction cyclic directMapped directionMixed empty fixedGradient fixedInternalValue fixedMeanValue fixedValue freestream inletOutlet mixed oscillatingFixedValue outletInlet outletMappedUniformInlet partialSlip processor sliced slip symmetryPlane timeVaryingMappedFixedValue timeVaryingUniformFixedValue timeVaryingUniformInletOutlet turbulentInlet uniformFixedValue waveTransmissive wedge zeroGradient ) From function fvPatchField<Type>::New(const word&, const fvPatch&, const DimensionedField<Type, volMesh>&) in file /home/opencfd/OpenFOAM/OpenFOAM-1.7.x/src/finiteVolume/lnInclude/newFvPatchField.C at line 53. FOAM exiting Code:
tmp<volSymmTensorField> kEpsilon::R() const { return tmp<volSymmTensorField> ( new volSymmTensorField ( IOobject ( "R", runTime_.timeName(), mesh_, IOobject::NO_READ, IOobject::NO_WRITE ), ((2.0/3.0)*I)*k_ - (mut_/rho_)*dev(twoSymm(fvc::grad(U_))), k_.boundaryField().types() ) ); } does anybody know what i m doing wrong here? thanks in adcance! beste regards, aram |
[Commercial meshers] converting Fluent mesh to openfoam standard mesh | deepesh | OpenFOAM Meshing & Mesh Conversion | 31 | March 29, 2017 05:59 |
dsmcInitialise - dsmcFoam | archymedes | OpenFOAM Pre-Processing | 94 | July 15, 2016 16:14 |
[OpenFOAM] Saving ParaFoam views and case | sail | ParaView | 9 | November 25, 2011 15:46 |
compressible two phase flow in CFX4.4 | youngan | CFX | 0 | July 1, 2003 23:32 |
Mashing Problem? | ji | CFX | 2 | April 4, 2002 05:03 |
