Dimentsions error in my modification of SST model
Old   June 19, 2008, 05:50
Default Hi everyone: i want to modify
wayne.zhang
waynezw0618 is on a distinguished road
Send a message via MSN to waynezw0618 Send a message via Skype™ to waynezw0618
Hi everyone:
i want to modify the SST model with AIAA paper A98-32817.so i change the definion of member function F1 like this
tmp<volscalarfield> kOmegaSSTRC::F1(const volScalarField& CDkOmega) const
//**modification** define the limitation of the CDkw by the maximum value of cross section term in the flow field (AIAA98-2554)
double CDkOmegalim = 1.0e-8*gMax(CDkOmega);
volScalarField CDkOmegaPlus = max
CDkOmega,
dimensionedScalar("CDkOmegalim", dimless/sqr(dimTime), CDkOmegalim)
);//**modification** use the CDkOmegalim instead of 1.0e-10,
volScalarField arg1 = min
min
max
(scalar(1)/betaStar)*sqrt(k_)/(omega_*y_),
scalar(500)*nu()/(sqr(y_)*omega_)
(4*alphaOmega2)*k_/(CDkOmegaPlus*sqr(y_))
scalar(10)
return tanh(pow4(arg1));
but it was run with error that
-> FOAM FATAL ERROR : Arguments of max have different dimensions
dimensions : [0 0 -1 0 0 0 0] and [0 0 -0.5 0 0 0 0]
#0 Foam::error::printStack(Foam:stream&) in "/home/waynezw0618/OpenFOAM/OpenFOAM-1.4.1/lib/linux64GccDPOpt/libOpenFOAM.so"
#1 Foam::error::abort() in "/home/waynezw0618/OpenFOAM/OpenFOAM-1.4.1/lib/linux64GccDPOpt/libOpenFOAM.so"
#2 Foam::max(Foam::dimensionSet const&, Foam::dimensionSet const&) in "/home/waynezw0618/OpenFOAM/OpenFOAM-1.4.1/lib/linux64GccDPOpt/libOpenFOAM.so"
#3 Foam::tmp<foam::geometricfield<double,> > Foam::max<double,>(Foam::tmp<foam::geometricfield< double,> > const&, Foam::tmp<foam::geometricfield<double,> > const&) in "/home/waynezw0618/OpenFOAM/waynezw0618-1.4.1/lib/linux64GccDPOpt/libincompressi bleTurbulenceModels.so"
#4 Foam::turbulenceModels::kOmegaSSTRC::correct() in "/home/waynezw0618/OpenFOAM/waynezw0618-1.4.1/lib/linux64GccDPOpt/libincompressi bleTurbulenceModels.so"
#5 main in "/home/waynezw0618/OpenFOAM/OpenFOAM-1.4.1/applications/bin/linux64GccDPOpt/simp leFoam"
#6 __libc_start_main in "/lib64/libc.so.6"
#7 __gxx_personality_v0 in "/home/waynezw0618/OpenFOAM/OpenFOAM-1.4.1/applications/bin/linux64GccDPOpt/simp leFoam"
From function max(const dimensionSet& ds1, const dimensionSet& ds2)
in file dimensionSet/dimensionSet.C at line 213.
FOAM aborting
could you please tell me what is wrong with my modification?
thanks !
yours wayne
waynezw0618 is offline   Reply With Quote
Old   June 19, 2008, 06:03
Default BTW, i have add the definion o
wayne.zhang
BTW, i have add the definion of private date F1_ declaration and initialize it in the constructor of the model like this :
omega_
IOobject
"omega",
runTime_.timeName(),
mesh_,
IOobject::MUST_READ,
IOobject::AUTO_WRITE
mesh_
F1_
IOobject
"F1",
mesh_,
mesh_
nut_(a1*k_/max(a1*(omega_ + omegaSmall_), F2()*mag(symm(fvc::grad(U_)))))
and i give a file named F1 in "0" document :
class volScalarField;
object F1;
dimensions [0 0 0 0 0 0 0];
internalField uniform 0;
boundaryField
BOTTOM
type fixedValue;
value uniform 0;
INLET1
type fixedValue;
value uniform 0;
OUTLET
type fixedValue;
value uniform 0;
SIDE
type fixedValue;
value uniform 0;
TOP
type fixedValue;
value uniform 0;
WING
type fixedValue;
value uniform 0;
can anyone help me!!
thanks!
wayne
Old   April 19, 2012, 12:36
pooyan
sam1364 is on a distinguished road
Could you find a solution for that error?!
I see the same error when modifying a turbulence model.
Thanks,
sam1364 is offline   Reply With Quote
Turbulence Model Modification and Implement qtian OpenFOAM Running, Solving & CFD 1 January 25, 2009 06:53
design modification alireza CFX 5 February 18, 2008 07:46
modification of UDF ammi FLUENT 2 January 18, 2007 21:35
modification for CFX? caty CFX 5 May 19, 2005 18:48
UDF modification merac FLUENT 4 March 1, 2001 06:42
