SIMPLE gave this error message: "Illegal master cellID 0. Should be 0..0"
Like Tree4Likes
  • 2 Post By romant
  • 2 Post By Yuanwei
Old   May 10, 2012, 06:33
Default SIMPLE gave this error message: "Illegal master cellID 0. Should be 0..0"
anonymous
libia87 is on a distinguished road
Hi!
I do a cylinder with gambit and then convert to OpenFOAM, but then when I run my case (tutorial buoyantBoussinesSimpleFoam) the program gives me an error:
--> FOAM FATAL IO ERROR:
file: /home/xr12/Anna/buoyantBoussinesqSimpleFoam/gambit_rectangle/system/fvSolution::SIMPLE from line 39 to line 50.
From function void Foam::setRefCell
const volScalarField&,
const dictionary&,
label& scalar&,
bool
in file cfdTools/general/findRefCell/findRefCell.C at line 66.
FOAM exiting
I understand that in file fvSolution, the part of SIMPLE i have to change the 0, but I don't know what i have to put... someone can help me??
my fvSolution:
solvers
p_rgh
solver PCG;
preconditioner DIC;
tolerance 1e-08;
relTol 0.01;
"(U|T|k|epsilon|R)"
solver PBiCG;
preconditioner DILU;
tolerance 1e-05;
relTol 0.1;
SIMPLE
nNonOrthogonalCorrectors 0;
pRefCell 0;
pRefValue 0;
residualControl
p_rgh 1e-2;
U 1e-4;
T 1e-2;
// possibly check turbulence fields
"(k|epsilon|omega)" 1e-3;
relaxationFactors
fields
p_rgh 0.7;
equations
U 0.3;
T 0.5;
"(k|epsilon|R)" 0.7;
libia87 is offline   Reply With Quote
Old   May 10, 2012, 07:07
romant's Avatar
Roman Thiele
romant is on a distinguished road
Is not really a description of the flow case. It is a closed case. It is an open case? what kind of boundary conditions are you using. In order to get help in this forum you should go by the rules http://openfoamwiki.net/index.php/Ho..._Message_Board
Therefore, questions:
1. what kind of case is it?
2. what kind of boundary conditions are there?
and please consider using the code tags in order to insert longer parts of a property or case file, it reads much easier that way.
~roman
romant is offline   Reply With Quote
Old   May 10, 2012, 09:25
niaz's Avatar
A_R
niaz is on a distinguished road
Dear libia
look at simple carefully.
you omit one } at the end of simple class
niaz is offline   Reply With Quote
Old   May 10, 2012, 10:50
romant's Avatar
Roman Thiele
Nope, there is no "}" missing. It comes after residual control. But good point, this is what I meant with setting it into code blocks
~roman
Old   May 11, 2012, 03:07
anonymous
only what i'm doing is the tutorial "buoyantBoussinesqSimpleFoam" but with different geometry.
First I change this geometry with GMSH and the program runs, but then I make the geometry with gambit and after convert to openfoam. But when I run the case appears this error, and I don't understand why, because changing the geometry with gmsh the program runs...
Old   May 11, 2012, 03:22
romant's Avatar
Roman Thiele
Does your geometry have an opening or is it also closed like the two tutorials? Try changing the number 0 for refCell to something different, since it will set a reference cell.
What you should also do is to expect your mesh with paraview (running paraFoam) and run checkMesh. See if there is something wrong. In paraview you can also select single cells and get their ID, which you can use to set for refCell instead of 0.
~roman
Old   May 11, 2012, 03:41
anonymous
my geometry is closed like the tutorial. I try to change the number to 0.1 for example and gives me this error:
wrong token type - expected int, found on line 40 the doubleScalar 0.1
file: /home/xr12/Anna/buoyantBoussinesqSimpleFoam/gambit_rectangle/system/fvSolution::SIMPLE:RefCell at line 40.
From function operator>>(Istream&, int&)
in file primitives/ints/int/intIO.C at line 68.
FOAM exiting
Then I try to put 1, and gives me the same error that when I put 0.
Old   May 11, 2012, 03:45
romant's Avatar
Roman Thiele
what are the outcomes from checkMesh? does the mesh looks good in paraview?
select a cell from paraview which you think is a good idea to set the reference pressure in?
I suspect that something is wrong with your mesh though, since you said that it works with gmsh.
~roman
Old   May 11, 2012, 03:46
anonymous
when I star parafoam gives me another error:
--> FOAM Warning :
From function polyMesh(const IOobject&)
in file meshes/polyMesh/polyMesh.C at line 307
no points in mesh
--> FOAM Warning :
in file meshes/polyMesh/polyMesh.C at line 312
no cells in mesh
I'm new with gambit and what I do is to make the geometry with gambit, export as .msh and then copy the file into my case and convert to openfoam (gambitToFoam). What is what I'm doing wrong?
Old   May 11, 2012, 03:48
romant's Avatar
Roman Thiele
I would say you don't actually have a mesh. Since it tells you that there are no cells nor any points. what does checkMesh give you?
~roman
Old   May 11, 2012, 03:52
anonymous
sorry but... how do you do the checkmesh??
sorry if I ask a lot, but I'm new with the programs and it's difficult to find some things.
Old   May 11, 2012, 03:55
anonymous
gives me a longer error...
--> FOAM Serious Error :
From function bool zone::checkDefinition(const label maxSize, const bool report) const
in file meshes/polyMesh/zones/zone/zone.C at line 211
Zone internal20 contains invalid index label 19
Valid index labels are 0..-1
Zone internal20 contains invalid index label 20
Zone internal20 contains invalid index label 21
Zone internal20 contains invalid index label 22
Zone internal20 contains invalid index label 23
--> FOAM FATAL ERROR:
Too many errors
From function messageStream:perator OSstream&()
in file lnInclude/messageStream.C at line 200.
Old   May 11, 2012, 04:00
romant's Avatar
Roman Thiele
This just means that your mesh is not properly converted, or has not been properly set up from the beginning. I have never used gambit or gmsh, therefore I won't be able to help you with setting this up. I guess the best thing is to start a thread with a proper title and a detailed description of what you want to do, otherwise ppl might not look at the thread.
One tip, when posting error messages and terminal output, try to use the code block feature in the post (this is the little hash sign at the top of the editor when posting), this will get rid of smilies and will create a frame around long error messages.
Good luck with the meshing.
libia87 and tonnykz like this.
~roman
Old   May 11, 2012, 04:03
anonymous
ok thanks for your help!
Old   March 31, 2016, 21:58
Saurabh Tandon
STutexas is on a distinguished road
Hi
I am getting the same error for my mesh. please let me know how if you could resolve this error.
Thank you.
Saurabh
STutexas is offline   Reply With Quote
Old   October 11, 2021, 02:40
Yuanwei Bin
Yuanwei is on a distinguished road
Originally Posted by STutexas View Post
Hi
Thank you.
Saurabh
For anyone who may meet this problem, please check you 'constant/polymesh/owner' file or 'porcessorX/constant/polymesh/owner' (X should be every porcessors). This ERROR is caused by the number of cell is 0, due to the method of decomposePar.
Haitham Osman CFD and wht like this.
Yuanwei is offline   Reply With Quote
stop when I run in parallel Nolwenn OpenFOAM 36 March 21, 2021 04:56
big difference between clockTime and executionTime LM4112 OpenFOAM Running, Solving & CFD 21 February 15, 2019 03:05
Compilation error with OpenFOAM 2.1.x Martin_ OpenFOAM Installation 28 January 15, 2013 06:58
openfoam 1.6 on debian etch romant OpenFOAM Installation 9 May 6, 2010 02:26
[blockMesh] BlockMeshmergePatchPairs hjasak OpenFOAM Meshing & Mesh Conversion 11 August 15, 2008 07:36
