[swak4Foam] Boundary Conditions with GroovyBC, Normal Gradient
Like Tree10Likes
Old   December 14, 2012, 04:55
Peter Benovsky
Peter Benovsky is on a distinguished road
Originally Posted by gschaider View Post
You can only have one BC on a patch at a time. Have you made sure that groovyBC is actually evaluated on that patch (for instance by introducing a syntactic error into an expression - if it fails it's evaluated)
BTW: which version of OF?
2.1.1
What I meant is that I use groovyBC for the temperature. alphat uses standard alpatWallFunction, hence should not be groovyfied.
Peter Benovsky is offline   Reply With Quote
Old   December 14, 2012, 06:26
Assistant Moderator
Bernhard Gschaider
Originally Posted by Peter Benovsky View Post
2.1.1
OK. Please provide some context (like which fields you used which BC on). It is not as absurd as you might think: I have seen people specifying 'type' twice hoping both would work.
Anyway: if the value 0 is only there during the first timestep then it is the same bug
Note: I don't use "Friend"-feature on this forum out of principle. Ah. And by the way: I'm not on Facebook either. So don't be offended if I don't accept your invitation/friend request
Old   December 17, 2012, 09:44
Peter Benovsky
It took longer than I thought but here it is (the context):
location "0";
object alphat;
heater
type alphatWallFunction;
value uniform 0.01;
object T;
heater
type groovyBC;
refValue uniform 300;
valueExpression "300";
gradientExpression "gradT*time()";
fractionExpression "0";
variables "heatFlux=100;gradT=heatFlux/(alphaEff);";
Without groovybc in the next time step I get for alphat:
location "0";
object alphat;
heater
Prt                             0.85;
value nonuniform List<scalar>
With groovy bc it is just fixedValue with value=0
Cheers
Peter
Old   December 17, 2012, 12:30
Assistant Moderator
Bernhard Gschaider
location "0";
object alphat;
heater
value uniform 0.01;
object T;
heater
type groovyBC;
location "0";
object alphat;
heater
Prt                             0.85;
Cheers
Peter
Hmm. That is strange. It should work. Could you try some things:
- instead of alphaEff add a constant (although I don't think that is the problem)
- set valueFraction to "uniform 0" (just to be sure)
- reset the 300 in the refValue to x. This should fail (this is just to make sure that it is really read)
Which version of swak do you use (check the start of the output of funkySetFields)
Old   February 21, 2014, 16:25
Xuan Ge
xuan8908 is on a distinguished road
Hi, Bernhard,
I am trying to look at your codes of the groovyBC implementation. I am
curious where you pass those strings, like "valueExpression_" and
"gradientExpression_"? In the source code, groovyBCCommon.C, you just
look up those keywords from the dictionary file and read them. How do
those strings come into play to update the boundary condition? I guess
one of those source codes may contain the implementation of this. Could
you please tell me which source code is the right one that I can read
and learn from? Thanks a lot in advance. I will appreciate your reply.
xuan8908 is offline   Reply With Quote
Old   February 22, 2014, 11:23
Assistant Moderator
Bernhard Gschaider
Originally Posted by xuan8908 View Post
Hi, Bernhard,
grep is your friend if you want to find the location of variables in the source code (of course there are more sophisticated tool, but this is installed on every system)
That'd be updateCoeffs in groovyBCFvPatchField.C. But the real magic happens in Libraries/swak4FoamParsers (especially everything with PatchValue in the beginning)
Old   February 22, 2014, 11:54
Xuan Ge
Thank you, Bernhard. I will take a look at it.
Old   September 17, 2014, 04:40
Sliwa is on a distinguished road
I am not sure this is the right thread for my question, but I was wondering if it was possible to set a fixed gradient in the direction normal to the patch and a fixed value in the tangential direction with groovyBC?
Sliwa is offline   Reply With Quote
Old   September 17, 2014, 17:29
Assistant Moderator
Bernhard Gschaider
There is a groovyBCDirection that wraps directionMixed (http://www.cfd-online.com/Forums/ope...-mixed-bc.html) but maybe this is not exactly what you need (no Dirichlet in tangential direction)
behzad-cfd likes this.
Old   September 18, 2014, 10:56
Yes, I needed the Dirichlet in the tangential direction. Thanks anyway.
Old   November 15, 2017, 14:57
behzad Ghasemi
behzad-cfd is on a distinguished road
Hi Bernhard,
I want to solve \nabla^{2}\xi+\vec{n}\cdot\nabla\xi=0 equation and obtain B that is defined like \overrightarrow{B}=(\frac{\partial\xi}{\partial  y})\vec{e_{x}}-(\frac{\partial\xi}{\partial x})\vec{e_{y}}.
I've implemented the equation in my base solver. Now i want to test functionality of the new solver but i have some boundary condition problem before testing.
For example if i want to get \overrightarrow{B}=(0,1) in boundaries i need to set (\frac{\partial\xi}{\partial  y})=0 and -(\frac{\partial\xi}{\partial x})=1.
Can i use groovyBC for this?
How can i implement this BCs?
Thanks in advance,
behzad-cfd is offline   Reply With Quote
Old   November 16, 2017, 20:16
Assistant Moderator
Bernhard Gschaider
Originally Posted by behzad-cfd View Post
Hi Bernhard,
Thanks in advance,
I'm afraid not. Because if you have a boundary with constant x then (\frac{\partial\xi}{\partial  y})=0 is not a boundary condition but a differential equation for the value on the boundary
Old   November 17, 2017, 03:44
behzad Ghasemi
Thanks for reply,
I should tell you that actually we have \vec{A}=(0,0,\xi) and \vec{B}=\nabla \times A = (\frac{\partial \xi}{\partial y}, -\frac{\partial \xi}{\partial x})
So how can i set such a condition?!
boundary, condition, gradient, groovybc, normal
Problem in setting Boundary Condition Madhatter92 CFX 12 January 12, 2016 04:39
Problem with SIMPLEC-like finite volume channel flow boundary conditions ghobold Main CFD Forum 3 June 15, 2015 11:14
Radiation interface hinca CFX 15 January 26, 2014 17:11
Water subcooled boiling Attesz CFX 7 January 5, 2013 03:32
RPM in Wind Turbine Pankaj CFX 9 November 23, 2009 04:05
