Question regarding to viscoelasticFluidFoam on OpenFOAM-2.1.x
Old   May 30, 2012, 13:32
Default Question regarding to viscoelasticFluidFoam on OpenFOAM-2.1.x
Samir
samegypt is on a distinguished road
Dear all,
my name is Samir, it is my first time to use OpenFoam, I started reading and understanding the program structure, Kindly, I like to know, How I can embedd or install viscoelasticFluidFoam on OpenFOAM-2.1.x, shall I copy the files I download from http://sourceforge.net/projects/vffo...x.tgz/download to the OpenFoam directory, I am using ubuntu 12.04.
  • Please let me know the steps that I can follow in order to install or allow me to run any viscoelastic model without getting error in using the viscoelastic library.
  • One more question, is the provided code results validated and can be trusted.
thanks, and best regards.
samegypt is offline   Reply With Quote
Old   May 30, 2012, 16:08
kmooney's Avatar
Kyle Mooney
kmooney is on a distinguished road
Originally Posted by samegypt View Post
Dear all,
Hi Samir,
Is it possible to install OpenFOAM-1.6-ext instead? That will come with viscoelasticFluidFoam and might make your a life a bit easier.
kmooney is offline   Reply With Quote
Old   May 30, 2012, 16:16
Samir
Originally Posted by kmooney View Post
Hi Samir,
Dear Kyle,
Thanks for you replay, currently, I am working onOpenFOAM-2.1.x. Kindly, if you know, is it possible to write to me the steps of how to use viscoelasticFluidFoam on OpenFOAM-2.1.x
Thanks
Samir
Old   May 30, 2012, 16:30
kmooney's Avatar
Kyle Mooney
Dear Kyle,
Thanks
Samir
Looks like you should decompress the tar ball in the ~/OpenFOAM/OpenFOAM-2.0.x/ directory. After that just run the install script:
./wmakeViscoelasticFluidFoam
It worked for me right out of the box.
Old   May 30, 2012, 17:03
Samir
Hi Samir,
Dear Kyle,
please, I like to ask one more question, I try to run one of the cases from the tutorial, viscoelasticFluidFoam, Oldroyd-B, it gave me the following error.
for running the tutorial case I first went to the Oldroyd-B tutorial test case directory, then I start with generating the mesh by using blockMesh, followed by writing viscoelasticFluidFoam for running the test case, so it gave me the following error, I do not know why it gave that error, could you please check it.
the tutorial like is http://dl.dropbox.com/u/80875880/Oldroyd-B.tar.gz
Thanks
Samir
sadek@sadek:~/OpenFOAM/sadek-2.1.0/run/tutorials/viscoelastic/viscoelasticFluidFoam/Oldroyd-B$ viscoelasticFluidFoam
| \\ / O peration | Version: 2.1.0 |
| \\ / A nd | Web: www.OpenFOAM.org |
| \\/ M anipulation | |
Build : 2.1.0-bd7367f93311
Exec : viscoelasticFluidFoam
Date : May 30 2012
Time : 21:48:34
Host : "sadek"
PID : 22797
Case : /home/sadek/OpenFOAM/sadek-2.1.0/run/tutorials/viscoelastic/viscoelasticFluidFoam/Oldroyd-B
nProcs : 1
allowSystemOperations : Disallowing user-supplied system call operations
Create time
Create mesh for time = 0
Reading field p
Reading field U
Selecting viscoelastic model Oldroyd-B
Starting time loop
Courant Number mean: 6.54561e-07 max: 1.84912e-05
deltaT = 1.19999e-05
Time = 1.19999e-05
--> FOAM FATAL IO ERROR:
Unknown asymmetric matrix solver BiCGStab
Valid asymmetric matrix solvers are :
4
BICCG
GAMG
PBiCG
smoothSolver
file: /home/sadek/OpenFOAM/sadek-2.1.0/run/tutorials/viscoelastic/viscoelasticFluidFoam/Oldroyd-B/system/fvSolution::solvers::U from line 47 to line 56.
From function lduMatrix::solver::New
in file matrices/lduMatrix/lduMatrix/lduMatrixSolver.C at line 106.
FOAM exiting
Old   May 31, 2012, 09:00
kmooney's Avatar
Kyle Mooney
BiCGStab (Stabilized BiCongugate Gradient) is a linear solver that is only implemented in the 1.6-ext version. Because you are using 2.x.x, Foam cannot find that solution method. There are a lot of hints in the error output that can help you understand the issue.
For Example:
These are the supported symmetric solvers that you might be able to use instead of BiCGStab:
4
BICCG
GAMG
PBiCG
smoothSolver
Also, this is where Foam had encountered the problem:
Since this is a pretty entry level error you might want to spend a little more time running tutorials or doing the examples in the users guide. It might give you a better feel for troubleshooting.
Old   May 31, 2012, 21:47
Samir
For Example:
4
BICCG
GAMG
PBiCG
smoothSolver
thanks for assistance.
Samir
Old   April 16, 2017, 13:51
A. Min
alimea is on a distinguished road
Hi all
I want to compile viscoelastic solver but I faced this error:
   fatal error: viscoelasticModel.H: No such file or directory
Could you plz help me?
Thanks
alimea is offline   Reply With Quote
Old   April 16, 2017, 14:37
piu58's Avatar
Uwe Pilz
piu58 is on a distinguished road
Somewhere before this line you find which file is missing.
Uwe Pilz
Die der Hauptbewegung überlagerte Schwankungsbewegung ist in ihren Einzelheiten so hoffnungslos kompliziert, daß ihre theoretische Berechnung aussichtslos erscheint. (Hermann Schlichting, 1950)
piu58 is offline   Reply With Quote
Old   April 16, 2017, 16:13
A. Min
Hi
Thanks for your answer
This is all of the message:
SOURCE=buoyantBoussinesqPimpleViscoFoam.C ;  g++ -m64 -Dlinux64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3  -DNoRepository -ftemplate-depth-100 -I../buoyantBoussinesqSimpleFoam -I/home/ali/OpenFOAM/OpenFOAM-2.3.1/src/sampling/lnInclude -I/home/ali/OpenFOAM/OpenFOAM-2.3.1/src/meshTools/lnInclude -I/home/ali/OpenFOAM/OpenFOAM-2.3.1/src/fvOptions/lnInclude -I/home/ali/OpenFOAM/OpenFOAM-2.3.1/src/finiteVolume/lnInclude -I/home/ali/OpenFOAM/OpenFOAM-2.3.1/src/turbulenceModels -I/home/ali/OpenFOAM/OpenFOAM-2.3.1/src/turbulenceModels/incompressible/RAS/lnInclude -I/home/ali/OpenFOAM/OpenFOAM-2.3.1/src/transportModels -I/home/ali/OpenFOAM/OpenFOAM-2.3.1/src/transportModels/incompressible/singlePhaseTransportModel -I/home/ali/OpenFOAM/OpenFOAM-2.3.1/src/thermophysicalModels/radiationModels/lnInclude -I/home/ali/OpenFOAM/OpenFOAM-2.3.1/src/transportModels/viscoelastic/lnInclude  -IlnInclude -I. -I/home/ali/OpenFOAM/OpenFOAM-2.3.1/src/OpenFOAM/lnInclude -I/home/ali/OpenFOAM/OpenFOAM-2.3.1/src/OSspecific/POSIX/lnInclude   -fPIC -c $SOURCE -o Make/linux64GccDPOpt/buoyantBoussinesqPimpleViscoFoam.o
buoyantBoussinesqPimpleViscoFoam.C:51:31: fatal error: viscoelasticModel.H: No such file or directory
compilation terminated.
buoyantBoussinesqPimpleViscoFoam.dep:712: recipe for target 'Make/linux64GccDPOpt/buoyantBoussinesqPimpleViscoFoam.o' failed
make: *** [Make/linux64GccDPOpt/buoyantBoussinesqPimpleViscoFoam.o] Error 1
Openfoam optimization question atareen64 OpenFOAM 3 June 1, 2011 08:36
OpenFOAM 1.6.x, 1.7.0 and 1.7.x are not fully prepared to work with gcc-4.5.x wyldckat OpenFOAM Bugs 18 October 21, 2010 05:51
[mesh manipulation] createPatch / cyclicGgi / OpenFoam 1.5-dev OFU OpenFOAM Meshing & Mesh Conversion 0 June 16, 2010 04:36
Critical errors during OpenFoam installation in OpenSuse 11.0 amscosta OpenFOAM 5 May 1, 2009 14:06
Questions for the bdivb function in OpenFOAM gkang OpenFOAM Running, Solving & CFD 3 May 13, 2006 11:11
