the interface reconstruction in InterFoam
Old   June 12, 2012, 20:52
Default the interface reconstruction in InterFoam
Y. Cao
young_Cao is on a distinguished road
Hi, everybody,I am studying the source codes of the InterFoam recently, as far as I known, for VOF method,you have to reconstruct the interface between different phases based on the solution of the volume fraction, however, I haven't seen the codes of the interface reconstructing, So could anybody tell me which kind of interface reconstructing method is used in the solver,and its corresponding codes in interFoam. And also I don't understand the transporting equation of volume fraction (alpha) they used in the solver, so could anybody explain it,or show me the exact formulation of alpha?
young_Cao is offline   Reply With Quote
Old   June 13, 2012, 02:41
akidess's Avatar
Anton Kidess
akidess will become famous soon enough
See the publicly available PhD thesis's by Henrik Rusche and Edin Berberovic for details on the algorithm.
*On twitter @akidTwit
*Spend as much time formulating your questions as you expect people to spend on their answer.
akidess is offline   Reply With Quote
Old   June 13, 2012, 02:52
Pablo Higuera
Phicau is on a distinguished road
Hello Young
no interface reconstruction is carried out in interFoam, as the VOF equation is diffusive an artificial compressive term is added. As pointed out by Anton, check those references for full details.
Regards
Phicau is offline   Reply With Quote
Old   June 13, 2012, 06:45
Y. Cao
Thank both of you, I have download these thesis,I will read them.
interFoam - stratified flow - problem with shear stress at interface AnjaMiehe OpenFOAM Running, Solving & CFD 8 June 14, 2010 06:49
RPM in Wind Turbine Pankaj CFX 9 November 23, 2009 04:05
Convective Heat Transfer - Heat Exchanger Mark CFX 6 November 15, 2004 15:55
Replace periodic by inlet-outlet pair lego CFX 3 November 5, 2002 20:09
