Fluctuating sum local error
Old   August 7, 2012, 11:45
Default Fluctuating sum local error
Kalyan
kalyangoparaju is on a distinguished road
Guys,
I am having this problem where the sum local fluctuates between 10-30 for I have no idea why. I am running rhoPorousMRFSimpleFoam and everything seems to be right but sum local does this. Is there a reason why this happens and what exactly does this mean? If I increase the nNonOrthogonalCorrectors, it fluctuates between 0.1 and 2. After some iterations, when I check the solution, it gives pure rubbish results (negative pressure !!!) . I am quite sure all the initial and boundary conditions are right ( I have a fluent case for same numbers which gave me expected results)
Checkmesh doesnt report any errors. I tried fiddling with the relaxation settings and that doesn't help much. Also, I am running a first order upwind scheme.
Can someone tell me what all of this can mean?
Thanks,
Kalyan
kalyangoparaju is offline   Reply With Quote
Old   August 9, 2012, 14:05
Kalyan
The error has been resolved ..
Even though checkMesh hasn't given me any errors, looks like the mesh is not the best in the world. I had to use 10 nonOrthogonalCorrectors to get it to run and give me correct results.
Kalyan
sum local, time step continuity
error compiling modified applications yvyan OpenFOAM Programming & Development 21 March 1, 2016 04:53
[swak4Foam] GroovyBC the dynamic cousin of funkySetFields that lives on the suburb of the mesh gschaider OpenFOAM Community Contributions 300 October 29, 2014 18:00
How to install CGNS under windows xp? lzgwhy Main CFD Forum 1 January 11, 2011 18:44
ParaView for OF-1.6-ext Chrisi1984 OpenFOAM Installation 0 December 31, 2010 06:42
CGNS lib and Fortran compiler manaliac Main CFD Forum 2 November 29, 2010 06:25
