Solving for two phase, incompressible, inviscid flow (OpenFOAM) |
June 14, 2012, 22:27 |
Betsy Seiffert
Rep Power: 15 |
Hello - I would like to solve for incompressible, inviscid flow (Euler Equations) for two phases (waves, NOT bubbles) in OpenFOAM. I am considering 3 options and I could use some advice on which may produce the best results or what problems I may run into:
1) Simply use interFoam and set viscosity to approximately zero (i.e. 1E-10 or something like this) 2) Write a new solver based on interFoam removing the viscous term in the Navier-Stokes equation 3) Use twoPhaseEulerFoam - although I am reluctant to use this solver since it is more difficult for me to see exactly how the solver is working and it seems to be geared more towards bubbles. Any advice is appreciated. Sincerely, Betsy |
June 15, 2012, 18:32 |
Betsy Seiffert
Rep Power: 15 |
As a follow up - does OpenFOAM use Reynolds number to non-dimensionalize the equation? If so, then this would cause problems with setting viscosity to approx. zero.
June 16, 2012, 06:58 |
Anton Kidess
Rep Power: 29 |
No, OpenFOAM works with the dimensional equation. Keep in mind that setting the viscosity to zero or something very small will make the problem "stiff", i.e. make it tougher to obtain a stable numerical solution.
*On twitter @akidTwit *Spend as much time formulating your questions as you expect people to spend on their answer. |
June 18, 2012, 17:06 |
Rob
Rep Power: 14 |
I would use interFoam. I have already seen some bachelor/master thesis that successfully simulated waves (i.e. at/around ships).
However writing your own solver might not be such a problem as well, the wiki gives some good hints on how to modify and expand solvers... |
June 27, 2012, 16:08 |
Ralph Moolenaar
Rep Power: 15 |
Depending on which kind of waves you want to simulate I'd suggest you to have a look into the LTSInterFoam solver which would be of use for semi-static problems.
CFD for marine applications? Go to http://www.marinecfd.com/ and join the OF Ship Hydromechanics Group: http://www.cfd-online.com/Forums/gro...mechanics.html |
July 15, 2012, 01:52 |
Ehsan
Rep Power: 17 |
Dear All,
Please see Eq. 4 in the paper below: http://www.marinepropulsors.com/proc...0Propulsor.pdf May I ask you whether in OpenFOAM the same equation including turbulence effects are used for viscosity of two phase flow or only simple averaging from laminar values are employed? Thanks |
July 16, 2012, 05:58 |
Pablo
Rep Power: 17 |
Hi Betsy,
Just remove the viscous terms from interFoam, and it is going to work pretty well. |
euler equations, incompressible flows, inviscid flow, two phase |
Forces in OF15 | richard | OpenFOAM Running, Solving & CFD | 180 | July 9, 2018 10:54 |
Upgraded from Karmic Koala 9.10 to Lucid Lynx10.04.3 | bookie56 | OpenFOAM Installation | 8 | August 13, 2011 04:03 |
Full pipe 3D using icoFoam | cyberbrain | OpenFOAM | 4 | March 16, 2011 09:20 |
ForcesCoeffs | ronaldo | OpenFOAM | 4 | September 14, 2009 07:11 |
Differences between serial and parallel runs | carsten | OpenFOAM Bugs | 11 | September 12, 2008 11:16 |
