Solving transport equations with known velocity field
Like Tree2Likes
  • 1 Post By chegdan
  • 1 Post By chegdan
Old   August 6, 2012, 05:20
Default Solving transport equations with known velocity field
Mojtaba.a's Avatar
Mojtaba Amiraslanpour
Mojtaba.a is on a distinguished road
Send a message via Skype™ to Mojtaba.a
Hi.
1) I want to solve 2 transport equations with known velocity field. First i want to solve coupled equations of momentum, energy and mass conservation to compute velocity field and pressure and also temperature. after solving these equations and by known velocity field i want to solve 2 other transport equations. How can i do that in openFoam?
2)
my second question is that is there anyway to include heat transfer coefficient in openfoam? or it will be computed automatically? if yes, then how can I find it?
3) I am modeling a room with heat sources which both natural convection and forced convection are significant. my case is incompressible. which solver do u suggest to use and how can i see the effects of forced convection?
Regards
Mojtaba ~
Mojtaba.a is offline   Reply With Quote
Old   August 6, 2012, 05:49
Daniel P. Combest
chegdan will become famous soon enoughchegdan will become famous soon enough
Originally Posted by Mojtaba.a View Post
Hi.
2)
Regards
Mojtaba ~
1. Yes, have a look at (http://openfoamwiki.net/index.php/ScalarTransportFoam).
2. Not sure
3. buoyantBoussinesqSimplFoam?
Give the forum a good search for passive scalar transport, natural convection, buoyancy,.... This will answer all of your questions. Hopefully this will get you started.
chegdan is offline   Reply With Quote
Old   August 6, 2012, 06:08
Mojtaba.a's Avatar
2. Not sure
Thank you for your quick answer chegdan.
1) well i have already seen that tutorials. i want to know how can i solve transport equation after finishing solving for U,p and T. is it possible?
regards
Old   August 6, 2012, 06:27
Daniel P. Combest
Yes, its possible. You will need to add your volScalarField for your scalar, formulate the implicit equation and then solve it as usual. If it is strongly coupled with the momentum equation (active) you can solve it inside the PISO/SIMPLE loop and if its a passive scalar (one-way coupled) you can solve it at the end of the time-step.
Mojtaba.a likes this.
Old   August 6, 2012, 06:42
Mojtaba.a's Avatar
Here is the source code for buoyantBoussinesqSimpleFoam:
while (simple.loop())
Info<< "Time = " << runTime.timeName() << nl << endl;
p_rgh.storePrevIter();
// Pressure-velocity SIMPLE corrector
#include "UEqn.H"
#include "TEqn.H"
#include "pEqn.H"
turbulence->correct();
runTime.write();
Info<< "ExecutionTime = " << runTime.elapsedCpuTime() << " s"
<< " ClockTime = " << runTime.elapsedClockTime() << " s"
<< nl << endl;
By "end of the time step" you mean where?
Old   August 6, 2012, 07:24
Daniel P. Combest
#include "UEqn.H"
#include "TEqn.H"
//<--here for active scalar
#include "pEqn.H"
//<-- here for passive scalar that depends on turbulence
runTime.write();
<< nl << endl;
You could try it in several places, compare execution time and solution and see which one is best. Good luck
Old   August 6, 2012, 07:43
Mojtaba.a's Avatar
#include "UEqn.H"
#include "TEqn.H"
#include "pEqn.H"
runTime.write();
<< nl << endl;
I understand it now,
Thanks chegdan ~
heat transsfer, hvac, room, transport equation
transsonic nozzle with rhoSimpleFoam Unseen OpenFOAM Running, Solving & CFD 8 July 1, 2022 06:54
Multiple floating objects CKH OpenFOAM Running, Solving & CFD 14 February 20, 2019 09:08
High Courant Number @ icoFoam Artex85 OpenFOAM Running, Solving & CFD 11 February 16, 2017 13:40
MRFSimpleFOAM goes divergenced! renyun0511 OpenFOAM Running, Solving & CFD 0 November 19, 2009 02:11
Problems with simulating TurbFOAM barath.ezhilan OpenFOAM 13 July 16, 2009 05:55
