July 22, 2009, 08:14 |
movingConeTopo
Rep Power: 16 |
hello,
i am testing something with movngConeTopo in OpenFOAM-1.5-dev.With the given tutorial parametres all is done fine. After that i tried to increase the the meshdensity in blockMeshDict (e.g. 9 9 1 instead of 3 3 1). But after some loops delta z is reaching very small values (1e-10) an the solver stops with an error. What is the problem there ? And ist there any good doc in the web i can use ? *edit* Program received signal SIGFPE, Arithmetic exception. [Switching to Thread 0xb55ff6d0 (LWP 11190)] 0xb6568330 in Foam::Time::adjustDeltaT (this=0xbff72ee8) at db/Time/Time.C:83 83 label nStepsToNextWrite = label(timeToNextWrite/deltaT_ - SMALL) + 1; Last edited by dipling; July 22, 2009 at 10:29. |
October 3, 2012, 17:12 |
Carlos Garrido
Rep Power: 14 |
hey,
Can you upload your case to check...I'm testing as well with this problem. regards, |
movingConeTopo tutorial from 1.5-dev crashes with Floating Point Exception | jaswi | OpenFOAM Running, Solving & CFD | 2 | April 26, 2009 10:21 |
