New boundary condition
Like Tree2Likes
Old   November 30, 2005, 15:07
Default I need to implement Johnson an
Alberto Passalacqua
I need to implement Johnson and Jacksnon boundary conditions in twoPhaseEulerFoam:
Is there something similar in OpenFoam to take as a starting point?
Thanks,
Alberto
Alberto Passalacqua
Old   December 1, 2005, 03:04
Default Hi, We had a similar bc in
niklas's Avatar
Niklas Nordin
niklas will become famous soon enoughniklas will become famous soon enough
We had a similar bc in our version of the two-phase code, but I decided to remove it from the official version, since it makes the calculations
even more prone to crash/oscillate.
I will see if i can dig out the old code and send it to you.
N
niklas is offline   Reply With Quote
Old   December 1, 2005, 04:38
Default Hello, yes, I know these boun
Alberto Passalacqua
yes, I know these boundary conditions can give such a kind of problems, but they're widely used in risers simulations.
It would be of great help if I could see your code :-)
Alberto
Alberto Passalacqua
Old   December 1, 2005, 06:28
Default OK, with the help of Rasmus I
niklas's Avatar
Niklas Nordin
OK, with the help of Rasmus I got these
particleSlip.tgz
The particleSlip bc.
To use this you just compile the library and add
the -lparticleSlip to the Make/options of your code and recompile that.
and to use it you set
type particleSlip
in the Ua bc's
If you want to postProcess the Ua variable you need to add the -lparticleSlip to the foamUser lib.
Its a partial slip conditions which is calculated in the .C file, a valueFraction() of 0 corresponds to the full slip condtion and 1 to a no-slip (or the fixedValue of (0 0 0))
The bc also needs some input from the transportProperties dictionary, da and phi0,
the diameter of the particles and their sphericity.
It's just possible to set the tangential component at the wall, since the normal should be zero.
...and of course you can rename it to something else then particleSlip, but it should be pretty straightforward to use you own equation for the 'slipperyness'.
N
chunleili likes this.
Old   December 1, 2005, 07:39
Default Thank you and Rasmus. I'll add
Alberto Passalacqua
Thank you and Rasmus. I'll add the Theta condition and post back the code as soon as possible.
Alberto
Alberto Passalacqua
Old   December 2, 2005, 09:52
Default Hello, if you consider the pa
Alberto Passalacqua
if you consider the partial slip boundary condition in the form:
U - a*dU = 0
where dU is the gradient in the normal direction, and a in [0, +inf[, is valueFraction defined as:
valueFraction = a/(1-a)
If not, what's the definition of valueFraction?
Thanks,
Alberto
Alberto Passalacqua
Old   December 2, 2005, 10:45
Default Hola, Not 100 percent sure,
niklas's Avatar
Niklas Nordin
Hola,
Not 100 percent sure, but I'd say its like this:
valueFraction*U + (1-valueFraction)*dU = 0
N
Old   December 2, 2005, 14:36
Default Hello, I'm a bit confused bec
Alberto Passalacqua
I'm a bit confused because the user's guide, pag. 148, says we have a complete slip b.c. for valueFraction = 1, so it can't be
because, for valueFraction = 1, it gives the no-slip b.c. and not the slip one. This is the reason I thought to something like:
(1-valueFraction)*U + valureFraction*dU = 0
but I'm not sure.
Any confirmation is welcome :-)
Thanks again,
Alberto
Alberto Passalacqua
Old   December 2, 2005, 22:10
Default I tried to apply the condition
Alberto Passalacqua
I tried to apply the condition you sent to me, but when I start the solver, I get this error:
Create mesh for time = 0
Reading environmentalProperties
Reading transportProperties
--> FOAM FATAL ERROR :
request for volScalarField alpha from objectRegistry region0 failed
available objects of type volScalarField are
0
From function objectRegistry::lookupObject<type>(const word&) const
in file /home/dm2/henry/OpenFOAM/OpenFOAM-1.2/src/OpenFOAM/lnInclude/objectR egistryTemplates.C at line 122.
Also, is it possible to use data contained in the phase object and use the kineticProperties dictionary instead of transportProperties?
Alberto
Alberto Passalacqua
Old   December 3, 2005, 08:09
Default Hi, I might possibly have the
niklas's Avatar
Niklas Nordin
I might possibly have the definition mixed up,but the easiest wasy to check is to run the icoFoam cavity tutorial with a fixed valueFraction and ascii format and check the values on the wall patch.
You're picking up the wrong database, the code I sent is from before the database was re-written and I dont know the new name (Mattijs does though Im sure)
Of course you can use the kineticProeprties dictionary instead, just change the name in the particleSlip.C file.
N
Old   December 3, 2005, 10:07
Default The kineticTheoryProperties di
  #11
Alberto Passalacqua
The kineticTheoryProperties dictionary seems to be unknown: it gives another fatal error where it states it can't find the dictionary. But this is probably related to the database issue too.
About the database, the only access (if I'm not wrong :-)) the code does to it should be through db(), but no name is specified there.
Also I looked at other BC's implementation and the same syntax is adopted.
Where do you choose the dictionary you pick?
Thanks and sorry if I'm boring :-)
Alberto
Alberto Passalacqua
Old   December 9, 2005, 02:56
Default Hi, Just tested the code an
  #12
niklas's Avatar
Niklas Nordin
Just tested the code and it works, but I was able to reproduce the error message.
Here's the bc input you need
walls
type particleSlip;
value uniform (0 0 0);
I'm guessing that you didnt include the value-statement, remember that if you want partial slip, you need a reference velocity.
N
Old   December 10, 2005, 19:06
Default You're right Niklas. I forgot
  #13
Alberto Passalacqua
You're right Niklas. I forgot the value statement.
Thank you!
Alberto
Alberto Passalacqua
Old   February 16, 2006, 12:23
Default How does one obtain the tangen
  #14
Jeff Allen
jballen is on a distinguished road
How does one obtain the tangent vector to a given face. I know for example that Sf() gives the normal vector.
Thanks
Jeff
jballen is offline   Reply With Quote
Old   February 16, 2006, 16:01
Default 1) Take any vector, a 2) get
  #15
Hrvoje Jasak
2) get a face normal n; if not already available, do Sf/mag(Sf)
3) the tangential component is:
a_t = a - n*(n & a)
Be careful: if you choose a to be parallel with n, you will get a zero vector. In that case, try a different a
Enjoy,
Hrv
utkunun likes this.
Hrvoje Jasak
Old   March 26, 2009, 20:23
Cynthia Poon
Cynthia Poon is on a distinguished road
Hi Niklas and everybody,
I've got some problem when post-processing the boundary condition. The error message in ParaView show that the "alpha" request from objectRegistry region0 failed.
Referring to #4 post, I find "If you want to postProcess the Ua variable you need to add the -lparticleSlip to the foamUser lib."
Can I ask where is that foamUser lib for post-processing?
I am sorry if my question is too silly.
Regards,
Cynthia
Cynthia Poon is offline   Reply With Quote
Old   April 9, 2009, 11:58
Dr. Alexander Vakhrushev
makaveli_lcf is on a distinguished road
Send a message via ICQ to makaveli_lcf
Hi all!
I'm trying to implement heat convective BC like at http://web.njit.edu/topics/Prog_Lang...ml/node198.htm
So we have as a parameters for applied BC:
h_ext - external heat transfer coefficient
T_ext - external heat-sink temperature
k_f - thermal conductivity of liquid
On the one hand, from Fourier's law heat flux q is equal
q = - k_f * d(T)/dn (1)
On the other hand,
q = h_ext * (T_ext - T_w) (2)
where T_w is wall temperature, which should be calculated. Combining (1) and (2), we get BC in form:
T - T_ext - k_f /h_f * d(T)/dn = 0 (3)
How to implement this BC in OpenFOAM? I tried to used "mixed" BC, setting refValue to T_ext, refGradient to zero, and calculating valueFraction as
valueFraction = 1/(1+k_f/h_f)
But at this stage I'm sure that it is not properly. Waiting for your suggestions!
Thank you
Best regards,
Dr. Alexander VAKHRUSHEV
Christian Doppler Laboratory for "Metallurgical Applications of Magnetohydrodynamics"
Simulation and Modelling of Metallurgical Processes
Department of Metallurgy
University of Leoben
http://smmp.unileoben.ac.at
makaveli_lcf is offline   Reply With Quote
Old   April 14, 2009, 03:03
So first I solved with a mixed type, and later made own BC on the basis of fixed gradient type, considering it in form
dT/dn = h_ext / k_f * (T_ext - T) (1)
and using under relaxation for values in boundary patch as it is described at http://www.cfd-online.com/Forums/ope...tml#post182101
This implicit boundary condition gives good agreement with FLUENT simulation, while mixed type BC just produces values at boundary close to T_ext.
Best regards,
Old   April 14, 2009, 04:46
tnk
L.E.Tonkov
tnk is on a distinguished road
Dear Foamers,
How can I implement "switching" b.c. on outlet channel boundary?
I need, for example, zeroGradient condition for pressure on supersonic part of outlet and fixedValue condition on rest outlet part (depend on calculated Mach number).
Need I construct new class for this type of b.c.?
Best regards
Leonid
tnk is offline   Reply With Quote
Old   April 14, 2009, 04:58
Leonid,
look at boundary condition types in Programming guide, there is allready a set of switching boundary conditions based on velocity direction.
Best regards,
heat transfer, new bc
Boundary condition for UDS Tomik FLUENT 0 December 5, 2006 17:37
Boundary condition of the third kind or Danckwertz boundary condition plage OpenFOAM Running, Solving & CFD 4 October 3, 2006 12:21
Slip Boundary Condition for Moving Boundary Shukla Main CFD Forum 3 November 11, 2005 15:02
UDF boundary condition Jeff FLUENT 2 November 20, 2003 17:15
Boundary Condition in LES Zhang Tsiang Main CFD Forum 3 February 5, 2002 20:15
