GAMG solver causes troubles
Old   May 10, 2011, 10:02
Default GAMG solver causes troubles
colinB is on a distinguished road
Hey there,
it has been a while since my last post here, but no working again with OF troubles come back
my problem is the following error message that I encountered during my calculationon a hydrofoil:
(before that happens the number of iterations for solving the pressure reach their maximum)
#0  Foam::error::printStack(Foam::Ostream&) in "/opt/openfoam171/lib/linuxGccDPOpt/libOpenFOAM.so"
#1  Foam::sigFpe::sigFpeHandler(int) in "/opt/openfoam171/lib/linuxGccDPOpt/libOpenFOAM.so"
#2  Uninterpreted:
#3  Foam::GAMGSolver::scalingFactor(Foam::Field<double>&,  Foam::Field<double> const&, Foam::Field<double>  const&, Foam::Field<double> const&) const in  &quot;/opt/openfoam171/lib/linuxGccDPOpt/libOpenFOAM.so&quot;
#4  Foam::GAMGSolver::scalingFactor(Foam::Field<double>&,  Foam::lduMatrix const&, Foam::Field<double>&,  Foam::FieldField<Foam::Field, double> const&,  Foam::UPtrList<Foam::lduInterfaceField const> const&,  Foam::Field<double> const&, unsigned char) const in  &quot;/opt/openfoam171/lib/linuxGccDPOpt/libOpenFOAM.so&quot;
#5   Foam::GAMGSolver::Vcycle(Foam::PtrList<Foam::lduMatrix::smoother>  const&, Foam::Field<double>&, Foam::Field<double>  const&, Foam::Field<double>&,  Foam::Field<double>&, Foam::Field<double>&,  Foam::PtrList<Foam::Field<double> >&,  Foam::PtrList<Foam::Field<double> >&, unsigned char)  const in  &quot;/opt/openfoam171/lib/linuxGccDPOpt/libOpenFOAM.so&quot;
#6  Foam::GAMGSolver::solve(Foam::Field<double>&,  Foam::Field<double> const&, unsigned char) const in  &quot;/opt/openfoam171/lib/linuxGccDPOpt/libOpenFOAM.so&quot;
#7  Foam::fvMatrix<double>::solve(Foam::dictionary const&) in  &quot;/opt/openfoam171/lib/linuxGccDPOpt/libfiniteVolume.so&quot;
 in &quot;/opt/openfoam171/applications/bin/linuxGccDPOpt/interFoam&quot;
#9  __libc_start_main in &quot;/lib/tls/i686/cmov/libc.so.6&quot;
Unfortunately I have no clue what it means and also my search on google and here in the forum didn't gave me sufficient help.
Attached you find the case including the log file but wo results
so if you want to run it simply type:
blockMesh
setFields
interFoam
it is a rather simple case with ~ 110k cells
I guess the trouble comes from the &quot;special&quot; layer I introduced with alpha1=0.5 which I did for avoiding interference of a sharp changeover from the airInlet and waterInlet.
Eventually also the grid maybe troubling. But checkMesh accepts it.
parts of the log you see here (it doesn't fit into the case folder)
Courant Number mean: 0.000140728 max: 0.930393
Interface Courant Number mean: 3.19131e-06 max: 0.930393
deltaT = 1.32721e-05
Time = 0.458845
MULES: Solving for alpha1
Liquid phase volume fraction = 0.525029  Min(alpha1) = -1.20388  Max(alpha1) = 1.00001
Liquid phase volume fraction = 0.525029  Min(alpha1) = -1.24572  Max(alpha1) = 1.00001
Liquid phase volume fraction = 0.525029  Min(alpha1) = -1.28785  Max(alpha1) = 1.00001
Liquid phase volume fraction = 0.525029  Min(alpha1) = -1.33024  Max(alpha1) = 1.00001
DILUPBiCG:  Solving for Ux, Initial residual = 0.0335748, Final residual = 8.67805e-13, No Iterations 2
DILUPBiCG:  Solving for Uz, Initial residual = 0.113298, Final residual = 2.72921e-07, No Iterations 1
GAMG:  Solving for p_rgh, Initial residual = 0.0649962, Final residual = 0.00032663, No Iterations 41
GAMG:  Solving for p_rgh, Initial residual = 0.000332293, Final residual = 3.24954e-06, No Iterations 100
GAMG:  Solving for p_rgh, Initial residual = 1.11011e-05, Final residual = 1.10477e-07, No Iterations 290
time step continuity errors : sum local = 1.88113e-11, global = -8.98642e-12, cumulative = -8.38788e-05
GAMG:  Solving for p_rgh, Initial residual = 0.0119578, Final residual = 8.14812e-05, No Iterations 2
GAMG:  Solving for p_rgh, Initial residual = 8.20786e-05, Final residual = 7.75983e-07, No Iterations 36
GAMG:  Solving for p_rgh, Initial residual = 1.38782e-06, Final residual = 1.31951e-08, No Iterations 137
time step continuity errors : sum local = 9.66489e-12, global = -8.98642e-12, cumulative = -8.38788e-05
GAMG:  Solving for p_rgh, Initial residual = 0.00137856, Final residual = 2.8292e-06, No Iterations 2
GAMG:  Solving for p_rgh, Initial residual = 3.04841e-06, Final residual = 2.87014e-08, No Iterations 102
GAMG:  Solving for p_rgh, Initial residual = 2.43316e-07, Final residual = 9.43905e-09, No Iterations 231
time step continuity errors : sum local = 8.99151e-12, global = -8.98642e-12, cumulative = -8.38788e-05
GAMG:  Solving for p_rgh, Initial residual = 0.000148687, Final residual = 6.88212e-07, No Iterations 1
GAMG:  Solving for p_rgh, Initial residual = 8.41732e-07, Final residual = 9.84476e-09, No Iterations 253
GAMG:  Solving for p_rgh, Initial residual = 2.06668e-07, Final residual = 9.83106e-09, No Iterations 236
time step continuity errors : sum local = 9.00801e-12, global = -8.98642e-12, cumulative = -8.38788e-05
ExecutionTime = 2818.28 s  ClockTime = 2862 s
Courant Number mean: 0.000127959 max: 0.844884
Interface Courant Number mean: 4.37856e-06 max: 0.844884
deltaT = 1.25508e-05
Time = 0.458858
Liquid phase volume fraction = 0.525029  Min(alpha1) = -1.31119  Max(alpha1) = 1.00001
Liquid phase volume fraction = 0.525029  Min(alpha1) = -1.2924  Max(alpha1) = 1.00001
Liquid phase volume fraction = 0.525029  Min(alpha1) = -1.27387  Max(alpha1) = 1.00001
Liquid phase volume fraction = 0.525029  Min(alpha1) = -1.25562  Max(alpha1) = 1.00001
DILUPBiCG:  Solving for Ux, Initial residual = 0.0169796, Final residual = 1.86494e-07, No Iterations 1
DILUPBiCG:  Solving for Uz, Initial residual = 0.080901, Final residual = 4.03905e-11, No Iterations 2
GAMG:  Solving for p_rgh, Initial residual = 0.311232, Final residual = 0.00210653, No Iterations 3
GAMG:  Solving for p_rgh, Initial residual = 0.00227784, Final residual = 1.54957e-05, No Iterations 11
GAMG:  Solving for p_rgh, Initial residual = 3.70093e-05, Final residual = 2.54066e-07, No Iterations 11
time step continuity errors : sum local = 2.12385e-11, global = -7.17953e-12, cumulative = -8.38788e-05
GAMG:  Solving for p_rgh, Initial residual = 0.109349, Final residual = 0.00081582, No Iterations 4
GAMG:  Solving for p_rgh, Initial residual = 0.000898281, Final residual = 7.66732e-06, No Iterations 12
GAMG:  Solving for p_rgh, Initial residual = 3.44177e-05, Final residual = 2.52469e-07, No Iterations 9
time step continuity errors : sum local = 1.23284e-11, global = -7.17953e-12, cumulative = -8.38788e-05
GAMG:  Solving for p_rgh, Initial residual = 0.0671865, Final residual = 0.00060329, No Iterations 4
GAMG:  Solving for p_rgh, Initial residual = 0.000683255, Final residual = 6.25839e-06, No Iterations 12
GAMG:  Solving for p_rgh, Initial residual = 3.07815e-05, Final residual = 3.06285e-07, No Iterations 8
time step continuity errors : sum local = 1.38091e-11, global = -7.17953e-12, cumulative = -8.38788e-05
GAMG:  Solving for p_rgh, Initial residual = 0.0652599, Final residual = 0.000571597, No Iterations 4
GAMG:  Solving for p_rgh, Initial residual = 0.000580785, Final residual = 5.32414e-06, No Iterations 12
GAMG:  Solving for p_rgh, Initial residual = 2.36578e-05, Final residual = 2.32577e-07, No Iterations 8
time step continuity errors : sum local = 2.1247e-11, global = -7.17953e-12, cumulative = -8.38788e-05
ExecutionTime = 2828.13 s  ClockTime = 2872 s
Courant Number mean: 0.000124125 max: 0.921853
Interface Courant Number mean: 3.42458e-06 max: 0.921853
deltaT = 1.08773e-05
Time = 0.458869
Liquid phase volume fraction = 0.525029  Min(alpha1) = -1.28124  Max(alpha1) = 1.00001
Liquid phase volume fraction = 0.525029  Min(alpha1) = -1.30668  Max(alpha1) = 1.00001
Liquid phase volume fraction = 0.525029  Min(alpha1) = -1.33194  Max(alpha1) = 1.00001
Liquid phase volume fraction = 0.525029  Min(alpha1) = -1.35701  Max(alpha1) = 1.00001
DILUPBiCG:  Solving for Ux, Initial residual = 0.0362697, Final residual = 3.75729e-07, No Iterations 1
DILUPBiCG:  Solving for Uz, Initial residual = 0.118264, Final residual = 8.8751e-07, No Iterations 1
GAMG:  Solving for p_rgh, Initial residual = 0.109203, Final residual = 2.88085e+32, No Iterations 1000
GAMG:  Solving for p_rgh, Initial residual = 0.239738, Final residual = 1.58254e+33, No Iterations 1000
time step continuity errors : sum local = 3.92821e+95, global = -2.13933e+79, cumulative = -2.13933e+79
GAMG:  Solving for p_rgh, Initial residual = 0.336348, Final residual = 3.22301e+33, No Iterations 1000
I hope I provided all information you need, if not let me know.
I appreciate your help
regards Colin
colinB is offline   Reply With Quote
Old   May 11, 2011, 10:42
Matthias Voß
mvoss is on a distinguished road
How can alpha1 become negative ?
Did you also tried another solver ?
mvoss is offline   Reply With Quote
Old   May 11, 2011, 11:31
good question! I don't know! Some deviations are nornmal in my Opinion ( I sometimes encounter min alpha1 10e-200 or so wich I consider to be zero)
But that big negativ deviations I haven't seen before (actually I just recognized)
no I haven't! any suggestions for different solvers?
Old   January 26, 2013, 15:57
immortality's Avatar
Ehsan
immortality is on a distinguished road
hi.could you send me your GAMG solver to me?
Thanks.
immortality is offline   Reply With Quote
Old   June 13, 2013, 01:48
laurentL
laurent98 is on a distinguished road
hi Colin,
did you solve this problem? because i got the same kind of alpha growing to much
alpha going to 7 then 13. then crach..
also on a hydrofoil...
thank you LL
laurent98 is offline   Reply With Quote
Old   June 13, 2013, 07:48
Ehsan
Colin change your scheme to limited schemes and reduce time step.
Injustice Anywhere is a Threat for Justice Everywhere.Martin Luther King.
To Be or Not To Be,Thats the Question!
The Only Stupid Question Is the One that Goes Unasked.
different results between serial solver and parallel solver wlt_1985 FLUENT 11 October 12, 2018 08:23
GAMG Solver tutlhino OpenFOAM Running, Solving & CFD 5 January 26, 2013 16:01
Differences between serial and parallel runs carsten OpenFOAM Bugs 11 September 12, 2008 11:16
why the solver reject it? Anyone with experience? bearcat CFX 6 April 28, 2008 14:08
SonicTurbFoam crashes when turbulence is added gastovski OpenFOAM Running, Solving & CFD 0 January 21, 2008 07:49
