chtMultiRegionFoam, adding a member to an existing class (regionProperties) |
October 3, 2012, 12:13 |
Romain
Rep Power: 13 |
I would like to add a member to an existing class, regionproperties, which already have two members, solid and liquid, but I do not find how to do so. I would like to have solid, liquid and gas. Gas will not be resolve with the same equations as liquid. I try to modify the existing regionProperties.C. in src/turbulenceModels/compressible/turbulenceModel/derivedFvPatchFields/turbulentTemperatureCoupledBaffle/regionProperties.C (and .H) But I can not run the .Allwmake in the opt directory, and if I copy the src directory in my user directory, and I have the following error : Code:
+ wmake libso turbulenceModel /usr/bin/ld: cannot open output file /opt/openfoam211/platforms/linux64GccDPOpt/lib/libcompressibleTurbulenceModel.so: Permission denied collect2: ld returned 1 exit status make: *** [/opt/openfoam211/platforms/linux64GccDPOpt/lib/libcompressibleTurbulenceModel.so] Error 1 + wmake libso RAS /usr/bin/ld: cannot open output file /opt/openfoam211/platforms/linux64GccDPOpt/lib/libcompressibleRASModels.so: Permission denied collect2: ld returned 1 exit status make: *** [/opt/openfoam211/platforms/linux64GccDPOpt/lib/libcompressibleRASModels.so] Error 1 + wmake libso LES /usr/bin/ld: cannot open output file /opt/openfoam211/platforms/linux64GccDPOpt/lib/libcompressibleLESModels.so: Permission denied collect2: ld returned 1 exit status make: *** [/opt/openfoam211/platforms/linux64GccDPOpt/lib/libcompressibleLESModels.so] Error 1 An other solution will be to specify that all liquid region do not have to be solve by the same equation, by I am also stuck here. I will have to put something else than forAll(fluidRegions) in the following code : Code:
forAll(fluidRegions, i) { Info<< "\nSolving for fluid region " << fluidRegions[i].name() << endl; #include "setRegionFluidFields.H" #include "readFluidMultiRegionSIMPLEControls.H" #include "solveFluid.H" } Romain |
October 10, 2012, 15:05 |
Romain
Rep Power: 13 |
The easiest solution I have found, even if it is not as elegant as I would like is to use a "if test" in myChtSimpleFoam.C and to check the name of the liquid region.
If it is gas, I use solveGas.H, if it is some other name, I use solveFluid.H It is working if I use the right name for my zone. I could have problem with multiples zones, but I guess I could found a way with something like regionname1_gas (ect) |
[OpenFOAM] Native ParaView Reader Bugs | tj22 | ParaView | 270 | January 4, 2016 11:39 |
Doxygen documentation | Tanay | OpenFOAM Installation | 9 | September 23, 2011 11:40 |
Help with chtMultiRegionFoam | jbvw96 | OpenFOAM Running, Solving & CFD | 2 | December 26, 2010 17:16 |
Version 15 on Mac OS X | gschaider | OpenFOAM Installation | 113 | December 2, 2009 10:23 |
Errors running allwmake in OpenFOAM141dev with WM_COMPILE_OPTION%3ddebug | unoder | OpenFOAM Installation | 11 | January 30, 2008 20:30 |
