fvm::div(phi, Ug)...how to insert properly?
Old   October 17, 2012, 05:11
Default (U_j+Ug_j)*d(U_i+Ug_i)/dx_j...how to insert properly?
Tom
sawyer86 is on a distinguished road
Hi there,
My question can be seen even from this prospective. I have to insert in the equation this term:
where Ug_i are the components of a given velocity field and U is the velocity I want to solve. This above is the convective term in the expression "u*grad(u)"-like
how can I do? Is it possible?
Thank you in advance!
sawyer86 is offline   Reply With Quote
Old   October 17, 2012, 05:23
treima is on a distinguished road
how did you initialise Ug, is it equal to the initialisation of U? Or perhaps there are some problems with the implicit and explicit treatment. You can have a look at this thread: http://www.cfd-online.com/Forums/ope...operation.html. There is a description of the same problem.
regards
treima
treima is offline   Reply With Quote
Old   October 17, 2012, 05:24
akidess's Avatar
Anton Kidess
akidess will become famous soon enough
You do not solve for Ug, hence that term is explicit. phi is not the variable you solve for, it's the data from the previous iteration.
*On twitter @akidTwit
*Spend as much time formulating your questions as you expect people to spend on their answer.
akidess is offline   Reply With Quote
Old   October 17, 2012, 05:32
Tom
one question. Do you say that the volume velocity flux is given from the previous iteration...that's so the way how icoFoam treats the non linear-convective term in the way to linearize it, am I right?
This linearization influence the calculation of UEqn.H()...but if I do insert that term explict how does UEqn.H() must change?
Thank you very much
Old   October 17, 2012, 05:36
Tom
Sorry I did not explain this term. It is essentially the convective term when you do a kind of linearization starting from a base flow...like in the RANS, but different...
Then the term i exactly want to add is the part of the above expression:
U_j*dUg_i/dx_j
Old   October 17, 2012, 05:45
Tom
Originally Posted by treima View Post
regards
treima
Thank you for the answer but i had a look of that thread and this is not just what I am looking for. By the way thank you again!
Regards
insert picture carno Main CFD Forum 4 May 11, 2011 07:33
Meshing a 2D airfoil properly jms Main CFD Forum 2 March 28, 2011 03:30
GAMBIT Error Msg database file not properly closed Janomano ANSYS Meshing & Geometry 8 November 23, 2010 04:14
Insert a velocity waveform Hila FLUENT 0 April 21, 2006 07:04
3D Insert modelling in Mold Flow Dan Rößler Main CFD Forum 0 December 20, 2005 06:37
