all processes end up in the same node when submitting parallel job by SGE
Old   November 1, 2012, 08:11
Default all processes end up in the same node when submitting parallel job by SGE
Marko Niinimaki
man@hepia is on a distinguished road
Dear all,
has anyone seen this kind of problem?
Background: OpenFOAM version OpenFOAM-2.1.x, compiled by "Allwmake",
Grid Engine GE 6.2u3, Scientific Linux SL release 5.5
Cluster of 224 cores in 20-something nodes.
The following distributes a task nicely in many nodes:
mpirun -np 64 --machinefile machines simpleFoam -parallel
Slaves :
63
"node015.374"
"node016.2178"
But submitting the same task by SGE leads to a situation where _all_ the processes are in a single node.
mpirun -np $NSLOTS --machinefile $TMPDIR/machines simpleFoam -parallel
The nodes in "machines" generated by SGE are diverse node015, node016.. but simpleFoam always starts the processes in a single node.
Is there something I should check? mpirun is from the ThirdParty package.
man@hepia is offline   Reply With Quote
Old   November 12, 2012, 02:12
axpl's Avatar
Alexandro Palmieri
axpl is on a distinguished road
Send a message via Skype™ to axpl
Add this line to your script:
unset SGE_ROOT
Sincerely,
Alex
axpl is offline   Reply With Quote
Old   November 13, 2012, 03:43
Marko Niinimaki
thanks for the reply. I am not sure what else I should change in the script. Here we have it:
mpirun -np $NSLOTS -machinefile $TMPDIR/machines /opt/OpenFOAM/OpenFOAM-2.1.x/platforms/linux64GccDPOpt/bin/simpleFoam -parallel
this runs everything in just one node
unset SGE_ROOT
fails with the following error message:
ssh: Unsupported option - -x
Old   November 15, 2012, 12:44
axpl's Avatar
Alexandro Palmieri
The error may depends to openmpi: what version are you using? Can you post your launch script?
Alex
Old   November 16, 2012, 00:07
linnemann's Avatar
Niels Nielsen
linnemann will become famous soon enough
Hi
if openmpi was built using --with-sge then you dont need "-machinefile $TMPDIR/machines"
unset $SGE_ROOT for our cluster puts the job on one node even though its reserving the nodes.
Here is how I start an OF job on a sge cluster "qsub runScript" with runScript containing the lines below
#!/bin/bash
#$ -cwd
#$ -o ./log.out
#$ -e ./log.err
#$ -pe orte 24
#$ -q all.q
#$ -S /bin/bash
# unset SGE_ROOT
echo Got $NSLOTS processors.
source /share/apps/OpenFOAM/OpenFOAM-2.1.x/etc/bashrc
mpi=`command -v mpirun`
solver=`command -v pimpleDyMFoam`
echo $mpi
echo $solver
if [ -z "$mpi" -a -z "$solver" ]
  then
      echo ">> mpi was not found, quitting!"
      exit 1
  else
      echo ">> mpi was found will continue"
      $mpi -np $NSLOTS -x LD_LIBRARY_PATH -x PATH -x WM_PROJECT_DIR -x WM_PROJECT_INST_DIR -x  WM_OPTIONS -x  FOAM_LIBBIN -x  FOAM_APPBIN -x  FOAM_USER_APPBIN -x MPI_BUFFER_SIZE $solver -parallel > log
fi
Linnemann
PS. I do not do personal support, so please post in the forums.
linnemann is offline   Reply With Quote
Old   November 16, 2012, 08:42
Marko Niinimaki
Many thanks!
Unfortunately the script that you copied behaves the same way as before: all processes in 1 node.
I need to set "machinefile" in the script, otherwise I get "ssh unsupported option -x" in stderr.
I compiled OpenFOAM 2.1.1 with just "./Allwmake". Is there a trick to force "--with-sge"?
sge
Problems with CEL (guess it's simple to solve) Felggv CFX 22 March 26, 2019 16:42
Difficulty in calculating angular velocity of Savonius turbine simulation alfaruk CFX 14 March 17, 2017 06:08
CFX Parameters Settings Flaky CFX 21 October 28, 2010 18:16
error using combination of step function xujjun CFX 1 January 15, 2008 16:46
How to apply negtive pressure to outlet bioman66 CFX 5 June 3, 2006 01:40
