May 1, 2008, 09:59 |
Dear Group
The bubble colum
Dear Group
The bubble column test case in tutorials was carried out with twoPhaseEulerFoam solver. With turbulence off( set in transportProperties file) , all went well. But if I turn turbulence on, the following messages appeared, and the execution aborted DILUPBiCG: Solving for alpha, Initial residual = 0.560997, Final residual = 3.05437e-11, No Iterations 23 Dispersed phase volume fraction = 0.387282 Min(alpha) = -12.3385 Max(alpha) = 27.9207 DILUPBiCG: Solving for alpha, Initial residual = 0.985119, Final residual = 1.67429e-11, No Iterations 25 Dispersed phase volume fraction = 0.382111 Min(alpha) = -22.733 Max(alpha) = 29.9401 #0 Foam::error::printStack(Foam:stream&) in "/home/sujunwei/OpenFOAM/OpenFOAM-1.4.1/lib/linuxGccDPOpt/libOpenFOAM.so" #1 Foam::sigFpe::sigFpeHandler(int) in "/home/sujunwei/OpenFOAM/OpenFOAM-1.4.1/lib/linuxGccDPOpt/libOpenFOAM.so" #2 Uninterpreted: [0xb7ef9420] #3 Foam::GAMGSolver::scalingFactor(Foam::Field<double >&, Foam::Field<double> const&, Foam::Field<double> const&, Foam::Field<double> const&) const in "/home/sujunwei/OpenFOAM/OpenFOAM-1.4.1/lib/linuxGccDPOpt/libOpenFOAM.so" #4 Foam::GAMGSolver::scalingFactor(Foam::Field<double >&, Foam::lduMatrix const&, Foam::Field<double>&, Foam::FieldField<foam::field,> const&, Foam::UPtrList<foam::lduinterfacefield> const&, Foam::Field<double> const&, unsigned char) const in "/home/sujunwei/OpenFOAM/OpenFOAM-1.4.1/lib/linuxGccDPOpt/libOpenFOAM.so" #5 Foam::GAMGSolver::Vcycle(Foam::PtrList<foam::lduma trix::smoother> const&, Foam::Field<double>&, Foam::Field<double> const&, Foam::Field<double>&, Foam::Field<double>&, Foam::Field<double>&, Foam::PtrList<foam::field<double> >&, Foam::PtrList<foam::field<double> >&, unsigned char) const in "/home/sujunwei/OpenFOAM/OpenFOAM-1.4.1/lib/linuxGccDPOpt/libOpenFOAM.so" #6 Foam::GAMGSolver::solve(Foam::Field<double>&, Foam::Field<double> const&, unsigned char) const in "/home/sujunwei/OpenFOAM/OpenFOAM-1.4.1/lib/linuxGccDPOpt/libOpenFOAM.so" #7 Foam::fvMatrix<double>::solve(Foam::Istream&) in "/home/sujunwei/OpenFOAM/OpenFOAM-1.4.1/lib/linuxGccDPOpt/libfiniteVolume.so" #8 main in "/home/sujunwei/OpenFOAM/OpenFOAM-1.4.1/applications/bin/linuxGccDPOpt/twoPhaseE ulerFoam" #9 __libc_start_main in "/lib/libc.so.6" #10 Foam::regIOobject::readIfModified() in "/home/sujunwei/OpenFOAM/OpenFOAM-1.4.1/applications/bin/linuxGccDPOpt/twoPhaseE ulerFoam" float point exception I also found that, the max phase fraction alpha>>1 see the message above. I have read the thesis of Henrik Rusche.With the modified form of phase fraction equation, the problem is avoid. why it occured in my simulaiton. Some things were omitted? Any reply is appreciated! Thanks, su junwei |
November 1, 2012, 03:55 |
Dongyue Li
Rep Power: 17 |
could anyone know how handle this question?~
November 2, 2012, 01:12 |
Alberto Passalacqua
Rep Power: 36 |
It is quite simple: the turbulence model in twoPhaseEulerFoam is very simple, and not ideal to manage systems with phase separation.
You will need to implement a better model (see literature).
Alberto Passalacqua GeekoCFD - A free distribution based on openSUSE 64 bit with CFD tools, including OpenFOAM. Available as in both physical and virtual formats (current status: http://albertopassalacqua.com/?p=1541) OpenQBMM - An open-source implementation of quadrature-based moment methods. To obtain more accurate answers, please specify the version of OpenFOAM you are using. |
TwoPhaseEulerFoam convergence problems | alberto | OpenFOAM Running, Solving & CFD | 74 | June 7, 2016 05:26 |
TwoPhaseEulerFoam | sara | OpenFOAM Running, Solving & CFD | 2 | November 6, 2008 19:26 |
Bug in twoPhaseEulerFoam | alberto | OpenFOAM Bugs | 2 | May 20, 2008 21:25 |
TwoPhaseEulerFoam Bug | alondono | OpenFOAM Bugs | 1 | February 19, 2008 20:01 |
TwoPhaseEulerFoam | newbee | OpenFOAM | 0 | March 27, 2006 08:41 |
