Influence of particle diameter in multi-phase flows?
Old   November 14, 2012, 10:04
Default Influence of particle diameter in multi-phase flows?
Petr Furmanek
petr.f. is on a distinguished road
Hi all,
considering the multi-phase solvers (multiphaseEulerFoam, twoPhaseEulerFoam) - what is the particle diameter influence on computation? It must be set for both liquid and gas phases so are there any hints how to determine it e.g. for water and air? Should it be greater or smaller than the smallest cell in computational mesh?
Any help appreciated...
petr.f. is offline   Reply With Quote
Old   January 31, 2013, 06:37
Gerhard Holzinger
GerhardHolzinger will become famous soon enoughGerhardHolzinger will become famous soon enough
The Eulerian solvers are used to simulate a dispersed phase (dust, droplets, etc.) and a continuos phase (air, water). Both phase can take the whole domain (e.g. foggy air). Instead of filling a control volume (a cell) completely with one phase, both phases use up this volume up to a certain fraction. The sum of this volume fractions must be one.
A half empty glass of water is filled by 50 % with water and the rest is air. The Eulerian solvers work in a similar way. the volume fraction of the dispersed phase tells you whether a cell is filled with one phase, the other phase or a mixture of both phases.
The momentum exchange terms depend on the particle diameter. If you use a blended drag model, both diameters are used. If you specify a drag phase, the diameter of the continuous phase should be of no importance.
The diameter of the dispersed phase should be set according to your problem in mind, e.g. for air bubbles in water, you should use the bubble diameter.
GerhardHolzinger is offline   Reply With Quote
Old   April 8, 2013, 03:56
Dongyue Li
sharonyue is on a distinguished road
Long time no see~Have you ever test twophaseeulerfoam on a tet mesh? How is the result?
sharonyue is offline   Reply With Quote
cfx post- two phase flow- particle size distribution hari139 CFX 3 July 14, 2012 05:23
multi phase Prince of Persia FLUENT 2 May 10, 2012 05:17
using interface with Euler multi phase model karimi FLUENT 0 May 22, 2011 02:46
regarding multi phase flows srikanth Main CFD Forum 1 January 26, 2006 02:49
References fr 2 phase flows in porous media Madhavan Main CFD Forum 2 June 29, 2000 14:01
