Noise in velocity graph
Old   April 15, 2015, 09:57
Default Noise in velocity graph
Sasa Goran
Supersale is on a distinguished road
Hi all!
i am simulating a continuous ink-jet in OpenFOAM 2.1.1 using compressibleInterFoam
The geometry is basically a cilinder filled with ink that converges into a small nozzle and then exits into the atmosphere. The inlet is defined as a complex harmonical function of the pressure which in the first few time steps gradually increases from 0 to the required harmonical function (if the first time step is more than zero, the velocity experiences a sharp jump at the beginning).
The issue i am currently dealing with is that the velocity, which is induced by the pressure difference, seems to have some noice at the first time steps. later the graph becomes smooth and stable but for these first few time steps some areas with spikes can be seen. Did any of you experience something similar? Do you know where the problem might be?
I am using slightly modified files from the compressibleInterFoam tutorial cases:
fvSolution:
|  \\    /   O peration     | Version:  2.1.1                                 |
|   \\  /    A nd           | Web:      www.OpenFOAM.org                      |
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    location    "system";
    object      fvSolution;
solvers
    pcorr
        solver          PCG;
        preconditioner
            preconditioner  DIC;
            tolerance       1e-13;
            relTol          0;
            smoother        DICGaussSeidel;
            nPreSweeps      0;
            nPostSweeps     2;
            nFinestSweeps   2;
            cacheAgglomeration false;
            nCellsInCoarsestLevel 10;
            agglomerator    faceAreaPair;
            mergeLevels     1;
        tolerance       1e-13;
        relTol          0;
        maxIter         100;
    "(rho|rhoFinal)"
        solver          diagonal;
    p_rgh
        solver          GAMG;
        tolerance       1e-13;
        relTol          0.01;
        smoother        DIC;
        nPreSweeps      0;
        nPostSweeps     2;
        nFinestSweeps   2;
        cacheAgglomeration true;
        mergeLevels     1;
    p_rghFinal
        solver          PCG;
        preconditioner
            preconditioner  DIC;
            tolerance       1e-13;
            relTol          0;
            nVcycles        2;
            nPreSweeps      2;
            nPostSweeps     2;
            nFinestSweeps   2;
            mergeLevels     1;
        tolerance       1e-13;
        relTol          0;
        maxIter         20;
     U
        solver          GAMG;
        tolerance       1e-13;
        relTol          0.01;
        smoother        DIC;
        nPreSweeps      0;
        nPostSweeps     2;
        nFinestSweeps   2;
        mergeLevels     1;
    "(k|B|nuTilda)"
        solver          PBiCG;
        preconditioner  DILU;
        tolerance       1e-13;
        relTol          0;
 UFinal
        solver          PBiCG;
        preconditioner
            tolerance       1e-13;
            relTol          0;
            nVcycles        2;
            nPreSweeps      2;
            nPostSweeps     2;
            nFinestSweeps   2;
            mergeLevels     1;
        tolerance       1e-13;
        relTol          0;
        maxIter         20;
PIMPLE
    momentumPredictor yes;
    nCorrectors     3;
    nNonOrthogonalCorrectors 1;
    nAlphaCorr      1;
    nAlphaSubCycles 2;
    cAlpha          1;
fvSchemes:
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    location    "system";
    object      fvSchemes;
ddtSchemes
    default         Euler;
gradSchemes
    default         Gauss linear;
divSchemes
    div(rho*phi,U)  Gauss SFCD;
    div(phi,alpha)  Gauss vanLeer;
    div(phirb,alpha) Gauss interfaceCompression 1;
    div(phi,p_rgh)  Gauss SFCD;      div(phi,k)      Gauss vanLeer;
    div((nuEff*dev(T(grad(U))))) Gauss linear;
laplacianSchemes
    default         Gauss linear corrected;
interpolationSchemes
    default         linear;
snGradSchemes
    default         corrected;
fluxRequired
    default         no;
    p_rgh;
    pcorr;
    alpha1;
i can not use an upwind scheme as this gives me constant noise. it needs to be second order.
Anyway, thanks for the help!
Supersale is offline   Reply With Quote
compressibleinterfoam, noise, pressure and velocity, viscous
Having trouble adapting serial UDF to work in parallel muyuntao Fluent UDF and Scheme Programming 1 November 10, 2015 13:42
How to plot velocity Vs time graph at a point in a flow using starccm+ TQIM STAR-CCM+ 6 November 19, 2012 10:51
how to compute relative velocity from absolute? spk Main CFD Forum 3 July 9, 2010 08:42
Velocity in Porous medium : HELP! HELP! HELP! Kali Sanjay Phoenics 0 November 6, 2006 06:10
what the result is negatif pressure at inlet chong chee nan FLUENT 0 December 29, 2001 05:13
