[swak4Foam] Two questions about groovyBC
Old   December 4, 2012, 15:44
Default Two questions about groovyBC
immortality's Avatar
Ehsan
immortality is on a distinguished road
1)if the variable or constant names in variables list is same as the name of a field it makes any problem?names should be different?
2)as well as variables is it possible to write formulas in valueExpression and others in more than one line?how?
thanks again.
immortality is offline   Reply With Quote
Old   December 4, 2012, 15:53
Ehsan
another little question.
groovy makes error in ^ sign.is there another easy way for making power(except itself!)
thanks.
Old   December 4, 2012, 18:38
Assistant Moderator
Bernhard Gschaider
thanks.
^ is (and this follows the convention of OpenFOAM) not the power function but the cross product of vectors (external product).
Power function is named pow.
But all that is (I admin not very verbosely) documented at http://openfoamwiki.net/index.php/Co...e_implemented:
Note: I don't use "Friend"-feature on this forum out of principle. Ah. And by the way: I'm not on Facebook either. So don't be offended if I don't accept your invitation/friend request
Old   December 4, 2012, 18:42
Assistant Moderator
Bernhard Gschaider
Best way to find out is to try.
But the answer is: a variable with the name alpha "shadows" a field with the name alpha ... no problem but you can't access the field anymore.
Anyway: if you're unsure about the behaviour name the variable differently
thanks again.
You asked that elsewhere
[swak4Foam] groovyBC for oscillatory flow liybzd OpenFOAM Community Contributions 5 November 12, 2018 07:53
[swak4Foam] reactingMultiPhaseEulerFoam problems with groovyBC zanilu70 OpenFOAM Community Contributions 4 December 13, 2016 06:46
[swak4Foam] Change in alpha and U with groovyBC in twoPhaseEulerFoam dani2702 OpenFOAM Community Contributions 0 November 17, 2016 03:30
[swak4Foam] some questions about neibours of patches in groovyBC immortality OpenFOAM Community Contributions 7 March 3, 2013 11:38
[swak4Foam] questions about groovyBC immortality OpenFOAM Community Contributions 2 December 14, 2012 10:07
