icoFOAM don't calculate right
Old   December 10, 2012, 02:03
Question icoFOAM don't calculate right
Wang Han
whyingwang is on a distinguished road
Hello FOAM users,
Recently I use icoFOAM to claculate a channel flow,like the picture show,
I use ICEM to make a struct-mesh,see below.
Later,I use icoFOAM,one of the two pipes is inlet another is outlet.
But I failed.After 2000 steps,It shows that the velocity still stay at inlet,like the picture shows.The red only can be see at one pipe.
Please,Who can tell me why?
Thanks.
whyingwang is offline   Reply With Quote
Old   December 10, 2012, 02:38
Robert
vainilreb is on a distinguished road
My first quick guess would be:
You set the channel walls to "wall" - which usually means the velocity at the boundary is "uniform (0 0 0)". Have you had a look at a cross-section through the channel? There might be high flow velocities in the middle of the channel. This is what you see at the inlet cross-section, too.
vainilreb is offline   Reply With Quote
Old   December 10, 2012, 03:06
Wang Han
Thanks For your answer.But, actually It's velocity at the middle of the channel is nearly zero,see below . My inlet velocity is 1.9m/s.
Old   December 10, 2012, 03:33
Robert
Well, at least there IS a flow profile. Please post your BC files, especially p and U!
Old   December 10, 2012, 07:34
Wang Han
OK,Here is my 0 time files
FoamFile
version 2.0;
format ascii;
class volScalarField;
object p;
dimensions [0 2 -2 0 0 0 0];
internalField uniform 0;
boundaryField
inletWall
type zeroGradient;
outletWall
type fixedValue;
value uniform 101.630;
upWalls
type zeroGradient;
inPipe
type zeroGradient;
outPipe
type zeroGradient;
downWalls
type zeroGradient;
outerWalls
type zeroGradient;
FoamFile
version 2.0;
format ascii;
class volVectorField;
object U;
dimensions [0 1 -1 0 0 0 0];
internalField uniform (0 0 0);
boundaryField
inletWall
type fixedValue;
value uniform (0 0 -1.9099);
outletWall
type zeroGradient;
upWalls
type fixedValue;
value uniform (0 0 0);
inPipe
type fixedValue;
outPipe
type fixedValue;
downWalls
type fixedValue;
outerWalls
type fixedValue;
Old   December 10, 2012, 07:54
Robert
Okay, first thing I see is your inlet velocity.
(0 0 -1.9099) points in negative Z-direction which is, according to the coordinate system, orthogonal to your inlet patch - because Y is the vertical axis!
Try (0 -1.9099 0).
And why is your pressure at the outlet so much higher than in the internal field? Uniform 0 for internal field means you've got ambient pressure level in the internal. Uniform 101.630 at the outlet means you've got 101.63 N/mē overpressure at the outlet. This probably won't work if you want the fluid to leave your channel at this patch. I suggest you try uniform 0 there, too.
Hope this will fix your problem.
Old   December 10, 2012, 08:42
Wang Han
Try (0 -1.9099 0).
yes,Thank you Very Much,vainilreb.
I get the reason now.
Density in icoFoam Densidad en icoFoam manuel OpenFOAM Running, Solving & CFD 8 September 22, 2010 04:10
calculate values for eps and k from Re or u????? sbar OpenFOAM Pre-Processing 5 August 16, 2010 04:10
Kubuntu uses dash breaks All scripts in tutorials platopus OpenFOAM Bugs 8 April 15, 2008 07:52
IcoFoam parallel woes msrinath80 OpenFOAM Running, Solving & CFD 9 July 22, 2007 02:58
How to calculate Torque for francis turbine manish CFX 4 March 15, 2007 02:57
