SprayEngineFoam - multiple injections
Old   January 2, 2013, 08:23
Default SprayEngineFoam - multiple injections
ris
ri
ris is on a distinguished road
I am attempting to simulate spray and combustion with multiple injections using sprayEngineFoam. I have used the system folder and engine-geometry files of enginefoam and the spraycloudproperties/chemistry/thermophysical/combustion files of sprayfoam.
My simulation runs fine with a single injection event, however when I implement multiple injections the programme fails with a segmentation fault at the start of the second injection. The logs show no indication of anything out of the ordinary.
I have attached my case folder, please could someone look at this and let me know where I could be going wrong. I am using OF-2.1.x .
Many Thanks,
ris.
ris is offline   Reply With Quote
Old   January 3, 2013, 18:43
ris
ri
I tried to implement this in openfoam-1.6-ext with the same mesh and comparable settings but it fails from a sigFloat error.
Does anyone have any ideas on this or the above post? Or maybe a working case that contains multiple injection events that I could have a look at.
ris.
Old   January 4, 2013, 12:10
mturcios777's Avatar
Marco A. Turcios
mturcios777 will become famous soon enough
Have you turned on all the debug flags for the lagrangian clouds in OpenFOAM-2.1.x/etc/controlDict? Not all the flags are on by default; turn on anything that says cloud/particle/parcel to see if you get any more useful output.
mturcios777 is offline   Reply With Quote
how to set periodic boundary conditions Ganesh FLUENT 15 November 18, 2020 06:09
OpenFOAM static build on Cray XT5 asaijo OpenFOAM Installation 9 April 6, 2011 12:21
UDF for sampling particles from multiple injections JaC Fluent UDF and Scheme Programming 0 March 31, 2010 10:43
Coal Injections problem Carlo FLUENT 0 September 30, 2009 06:15
Multiple surface particle injections from the command line mbeals FLUENT 0 June 3, 2009 14:11
