Diverging Simulation using rhoSimplecFoam, kOmegaSST
Old   January 7, 2013, 16:35
Default Diverging Simulation using rhoSimplecFoam, kOmegaSST
Andreas Petrikat
AndreasP. is on a distinguished road
Hello everybody,
I have been trying for quite some time to run a compressible simulation of a NACA 0012 profile, using rhoSimplecFoam and kOmegaSST for turbulence modeling.
My mesh is unstructured, checkMesh indicates no problems.
Running a simulation at Mach 0.7 generates following output:
Starting time loop
Time = 0.1
GAMG: Solving for Ux, Initial residual = 1, Final residual = 0.0615838, No Iterations 1
GAMG: Solving for Uy, Initial residual = 1, Final residual = 0.0598451, No Iterations 1
GAMG: Solving for p, Initial residual = 1, Final residual = 27.4647, No Iterations 1000
time step continuity errors : sum local = 0.793546, global = 0.47889, cumulative = 0.47889
rho max/min : 0.1 0.1
GAMG: Solving for h, Initial residual = 0.627704, Final residual = 0.906171, No Iterations 1000
GAMG: Solving for omega, Initial residual = 0.00118687, Final residual = 5.36443e-06, No Iterations 1
smoothSolver: Solving for k, Initial residual = 1, Final residual = 0.0494026, No Iterations 2
ExecutionTime = 7.73 s ClockTime = 7 s
Time = 0.2
GAMG: Solving for Ux, Initial residual = 0.335287, Final residual = 0.00814846, No Iterations 2
GAMG: Solving for Uy, Initial residual = 0.0892067, Final residual = 0.00223789, No Iterations 2
#0 Foam::error:rintStack(Foam::Ostream&) in "/opt/openfoam201/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
#1 Foam::sigFpe::sigHandler(int) in "/opt/openfoam201/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
#2 in "/lib/libc.so.6"
in "/opt/openfoam201/platforms/linux64GccDPOpt/bin/rhoSimplecFoam"
#10 __libc_start_main in "/lib/libc.so.6"
#11
Floating point exception
I presume there's something off when calculating for p and h. I have no clue what the problem is though, an incompressible simulation, using simpleFoam and Spallart-Allmaras works fine.
Switching transonic off in fvSolution seems to stabilize the simulate at least so much to allow a minimal amount of postprocessing; every single variable diverges massively. Changing the relaxation factors has no significant effect.
I am quite new to OpenFoam, and have generated my files according to various threats in this forum as well as to the tutorial cases.
Here are my files fvSolution, fvSchemes, p and U.
solvers
    p0
        solver          GAMG;
        tolerance       1e-10;
        relTol          0.1;
        smoother        GaussSeidel;
        nPreSweeps      0;
        nPostSweeps     2;
        nFinestSweeps   2;
        cacheAgglomeration true;
        nCellsInCoarsestLevel 20;
        agglomerator    faceAreaPair;
        mergeLevels     1;
    p1
        solver          GAMG;
        tolerance       1e-10;
        relTol          0.1;
        nPreSweeps      0;
        nPostSweeps     2;
        nFinestSweeps   2;
        mergeLevels     1;
    p
        solver          GAMG;
        tolerance       1e-10;
        relTol          0.1;
        nPreSweeps      0;
        nPostSweeps     2;
        nFinestSweeps   2;
        mergeLevels     1;
    omega0
        solver          PBiCG;
        preconditioner  DILU;
        tolerance       1e-10;
        relTol          0.1;
    omega1
        solver          smoothSolver;
        nSweeps         1;
        tolerance       1e-10;
        relTol          0.1;
    omega
        solver          GAMG;
        tolerance       1e-10;
        relTol          0.1;
        nPreSweeps      0;
        nPostSweeps     2;
        nFinestSweeps   2;
        mergeLevels     1;
    U0
        solver          PBiCG;
        tolerance       1e-10;
        relTol          0.1;
    U1
        nSweeps         1;
        tolerance       1e-10;
        relTol          0.1;
    U
        solver          GAMG;
        tolerance       1e-10;
        relTol          0.1;
        nPreSweeps      0;
        nPostSweeps     2;
        nFinestSweeps   2;
        mergeLevels     1;
    h0
        solver          PBiCG;
        tolerance       1e-10;
        relTol          0.1;
    h1
        nSweeps         1;
        tolerance       1e-10;
        relTol          0.1;
    h
        solver          GAMG;
        tolerance       1e-10;
        relTol          0.1;
        nPreSweeps      0;
        nPostSweeps     2;
        nFinestSweeps   2;
        mergeLevels     1;
    k0
        solver          PBiCG;
        tolerance       1e-10;
        relTol          0.1;
    k1
        solver          PBiCG;
        tolerance       1e-10;
        relTol          0.1;
    k
        tolerance        1e-10;
        relTol           0.1;
        nSweeps          1;
SIMPLE
    nNonOrthogonalCorrectors 0;
    rhoMin          rhoMin [1 -3 0 0 0] 0.1;
    rhoMax          rhoMax [1 -3 0 0 0] 1.0;
    transonic       yes;
    pRefPoint        (100 0 0);
    pRefValue       11000;
relaxationFactors
    p               0.5;
    U               0.7;
    k               0.5;
    omega           0.5;
    rho            1;
    h            0.95;
relaxationFactors0
    p             0.3;
    rho           0.4;
    U             0.7;
    h             0.7;
    k             0.7;
    omega         0.7;
ddtSchemes
    default             steadyState;
gradSchemes
    default         fourth;
    grad(p)         fourth;
    grad(U)         Gauss linear;
    grad(omega)        Gauss linear;
divSchemes
    default             none;
    div(phi,U)          Gauss upwind; //limitedLinearV 1; //upwind;
    div((muEff*dev2(T(grad(U)))))      Gauss linear;
    div(phi,h)          Gauss upwind; //limitedLinear 1; //upwind;
    div(phi,k)          Gauss upwind;
    div(phi,omega)    Gauss upwind;
    div(phid,p)         Gauss upwind;
    div(U,p)            Gauss linear;
laplacianSchemes
    default         Gauss linear limited 0.5;
interpolationSchemes
    default                 none;
    interpolate(rho)        linear;
    div(U,p)                upwind phi;
    interpolate((psi*U))    linear;
    interpolate(U)          linear;
    UD                      upwind phid;
    interpolate(p)          linear;
    interpolate(((rho|(A(U)-H(1)))-(rho|A(U)))) linear;
    interpolate((rho*U))    linear;
snGradSchemes
    default                 corrected;
fluxRequired
    default                 no;
    p;
    pCorr;
dimensions      [1 -1 -2 0 0 0 0];
internalField   uniform 11000;
boundaryField
    NONE1      //Nearfield1
        type            empty;
    NONE2    //Nearfield2
        type            empty;
    NONE3     //Pressure Side
        type            zeroGradient;
    NONE4    //Nearfield3
        type            empty;
    NONE5    //Nearfield4
        type            empty;
    NONE6    //Suction Side
        type            zeroGradient;
    NONE7    //Wake resolution1
        type            empty;
    NONE8    //Wake resolution2
        type            empty;
    NONE9    //Trailing Edge
        type            zeroGradient;
    NONE10    //Farfield1
        type            empty;
    NONE11    //Farfield2
        type            empty;
    NONE12    //Outer rim, lower half
        type            freestreamPressure;
        //type            fixedValue;
        value           uniform 11000;
    NONE13    //Outer rim, upper half
        //type            fixedValue;
dimensions      [0 1 -1 0 0 0 0];
internalField   uniform (239.266 20.933 0);
boundaryField
    NONE1      //Nearfield1
        type            empty;
    NONE2    //Nearfield2
        type            empty;
        type            fixedValue;
        value           uniform (0 0 0);
    NONE4    //Nearfield3
        type            empty;
    NONE5    //Nearfield4
        type            empty;
       type            fixedValue;
        type            empty;
        type            empty;
        type            fixedValue;
    NONE10    //Farfield1
        type            empty;
    NONE11    //Farfield2
        type            empty;
        type            freestream;
        freestreamValue uniform (239.266 20.933 0);
       type            freestream;
Thanks in advance for your help.
AndreasP. is offline   Reply With Quote
Old   January 10, 2013, 02:16
Andreas Petrikat
*Bump*
Any help would be greatly appreciated
Old   January 27, 2013, 06:19
Hannes Kröger
hannes is on a distinguished road
Originally Posted by AndreasP. View Post
Hello everybody,
Looks like you always hit the lower limit of rho (given in fvSolution/SIMPLE-section).
I think you should adapt "rhoMin" to your quite low abient pressure of 11kPa.
hannes is offline   Reply With Quote
Old   January 27, 2013, 06:37
Andreas Petrikat
Hey Hannes,
thanks for the reply!
Unfortunately, decreasing rhoMin seems to have no effect...
Old   March 30, 2013, 10:12
HECKMANN Frédéric
fredo490 is on a distinguished road
It's a bit late to answer but I often see thread with problems over rhoMin and rhoMax.
Those two values are some "limiters" to avoid unphysical values of rho. This limiter has to be temporary (often at the beginning of the computation to avoid any divergence).
You need to know first the freestream value of rho. If you are lazy you can use Wolfram: http://www.wolframalpha.com/input/?i...=&equal=Submit
Then you have to choose your rhoMin and rhoMax arround the freestream value. And here you need to be smart and use your experience because the min and max often depend of the geometry. Until Mach 0.5 the density usually change of less than +/- 0.2.
fredo490 is offline   Reply With Quote
Solar Radiation in OpenFOAM plainstyle OpenFOAM Running, Solving & CFD 15 July 8, 2014 04:43
GUI crash and simulation engine still running RPJones FLOW-3D 2 November 9, 2010 08:18
velocity profile export from a simulation onto another sudhirlv STAR-CCM+ 1 September 12, 2010 18:57
strange simulation error Ralf Schmidt FLUENT 2 May 4, 2007 13:02
3-D Contaminant Dispersal Simulation Apple L S Chan Main CFD Forum 1 December 23, 1998 10:06
