January 10, 2013, 17:07 |
chtMultiRegionSimpleFoam tutorial error
Oli
Rep Power: 17 |
Hello together !
I want to solve the tutorial of the chtMultiRegionSimpleFoam: multiRegionHeater For the solids I want to use the thermoType directionalKSolidThermo. So i just switch the thermoType and start the ./Allrun Then i get the error: Solving for solid region heater terminate called after throwing an instance of 'std::length_error' what(): basic_string::_S_create at the end of the first iteration. Is there something else i have to change when using the directionalKSolidThermo ? I'm using OpenFOAM v 2.1 Best Regards and thanks !! Oliver |
January 23, 2013, 07:09 |
Oli
Rep Power: 17 |
Anybody an idea?
Building OpenFOAM1.7.0 from source | ata | OpenFOAM Installation | 46 | March 6, 2022 13:21 |
Compile calcMassFlowC | aurore | OpenFOAM Programming & Development | 13 | March 23, 2018 07:43 |
[swak4Foam] installing funkySetFields | igo | OpenFOAM Community Contributions | 1 | November 20, 2012 20:16 |
Ansys Fluent 13.0 UDF compilation problem in Window XP (32 bit) | Yogini | Fluent UDF and Scheme Programming | 7 | October 3, 2012 07:24 |
checking the system setup and Qt version | vivek070176 | OpenFOAM Installation | 22 | June 1, 2010 12:34 |
