Solving boundary layer with k-e model
Old   February 24, 2010, 08:41
Default Solving boundary layer with k-e model
Gearb0x is on a distinguished road
Hello
In fluent, you can use "Enhanced wall treatment" to solve the boudary layer with the k-e turbulence model.
How can you do that with OpenFoam? Which boundary conditions to set instead of wall functions?
Thank you
Gearb0x is offline   Reply With Quote
Old   February 24, 2010, 09:06
cboss is on a distinguished road
as far as I am understanding your question, you want to resolve the laminar sublayer with a fine mesh (with y-plus around 1) using the implemented k-epsilon turbulence model?
In literature it is often pointed out, that if the laminar sublayer should be resolved with the k-epsilon model, additional damping functions (to limit the k production) are needed.
In OF 1.6 one modified k-epsilon turbulence model for this usage is included. The Launder-Sharma low-Re k-epsilon model.
http://www.cfd-online.com/Wiki/Low-Re_k-epsilon_models
If you can manage provide small y-plus values to resolve the laminar sublayer, you can perhaps try this model. (Personally I have no experience with this model)
Regards
cboss is offline   Reply With Quote
Old   February 24, 2010, 09:09
You totally understand and this is the model I was using but it gives me different results than fluent so I wanted to know if it was possible to stick as cloes as possible to the parameters in fluent by using the standard k-e model
Thanks for the answer!
Old   February 25, 2010, 02:30
Alberto Passalacqua
Well, if you want to actually resolve the boundary layer you need a low-Re model. For incompressible flows there are a few in OpenFOAM.
Now the question is how did you set the boundary conditions at the walls? If you use a low-Re model, you should not use the wall-functions but directly specify the conditions for k and epsilon.
Best,
Alberto Passalacqua
Old   February 25, 2010, 06:39
At the walls, k and epsilon are set to something like 1e-06 and nut is set as calculated
Old   January 23, 2013, 04:31
-mAx-'s Avatar
Maxime Perelli
-mAx- will become famous soon enough
Hello Jérémy,
Did you manage to get what you wanted?
I also want to resolve the BL with y+ around1, (simpleFoam)
In memory of my friend Hervé: CFD engineer & freerider
-mAx- is offline   Reply With Quote
Old   January 24, 2013, 04:40
Aathavan
Aadhavan is on a distinguished road
Hi All,
I am using MRFSimpleFoam,
y+ value = 3, Growth factor = 1.2, layers = 15 and the whole domain has 6.3 Millions cells.
I am using kOmegaSST, the problem is, simulation not all getting converged.
my question is for kOmegaSST turb-model, is it right setting???
if not what should I change?
I have given the boundary conditions as follows
0/nut,
for all walls
top0
type nutkWallFunction;
value uniform 0;
top1
value uniform 0;
top2
value uniform 0;
0/k
top0
type kqRWallFunction;
value uniform 0.062424;
top1
top2
0/omega
top0
type omegaWallFunction;
value uniform 0.99;
top1
value uniform 0.99;
top2
value uniform 0.99;
0/U --> massFlowRate ---> 4m3/s inlet
0/p --> Gauge Pressure --> 0 Outlet
Thanks,
Aadhavan
Aadhavan is offline   Reply With Quote
Superlinear speedup in OpenFOAM 13 msrinath80 OpenFOAM Running, Solving & CFD 18 March 3, 2015 05:36
Turbulent Boundary Layer on a Flat Plate Hoshang Garda FLUENT 1 November 27, 2013 10:24
RPM in Wind Turbine Pankaj CFX 9 November 23, 2009 04:05
Errno 24 linux ivanwhlau OpenFOAM Running, Solving & CFD 6 July 1, 2009 10:16
Modeling in micron scale using icoFoam m9819348 OpenFOAM Running, Solving & CFD 7 October 27, 2007 00:36
