SolidBodyMotion in RhoCentralDyMFoam
Old   January 29, 2013, 21:56
Default SolidBodyMotion in RhoCentralDyMFoam
Ruben Moreno
rmoreno is on a distinguished road
Hi everyone,
I have been trying to run some simulations moving the whole mesh as a rigid body using pimpleDyMFoam as starting point. I can run simple oscillating cases in pimpleDyMFoam and the results agree with the analytical values (i.e. Theodorsen function for an oscillating airfoil).
I want to move now to rhoCentralDyMFoam, as I have been working with it for a while already. If I deform the mesh, I get similar results to what I was getting in pimpleDyMFoam. However, when I try to move the mesh as a rigid body, rhoCentralDyMFoam still asks for a solver, and even if I provide one I think it is mixing the two approaches.
Taking a look at rhoCentralDyMFoam.c I have seen that it calls motionSolver.H and CreateMesh.H, instead of dynamicFvMesh.H and CreateDynamicFvMesh.H. So, it seems that when it was programmed it was not intended to use all the capabilities available in some other solvers.
Can anybody put some light into this?. I have started to modify the code to make it work with solid body motions, but maybe there was a good reason not to do this at the original time and I might just be wasting my time...
Thanks a lot and best regards
rmoreno is offline   Reply With Quote
Old   January 30, 2013, 05:06
immortality's Avatar
Ehsan
immortality is on a distinguished road
hi
Im going to run a mesh with solid body motion.but i don't know how to start in rhoPimpleFoam.could you send me your case?
Another question i didn't get its answer is abot residualControl in rhoPimpleFoam.whats it's duty when we can set tolerances in related dictionaries in fvSolution?
immortality is offline   Reply With Quote
Old   January 30, 2013, 05:07
Ehsan
hi
Im going to run a mesh with solid body motion.but i don't know how to start in PimpleDYMFoam.could you send me your case?
Thanks.
Old   January 30, 2013, 06:27
Ruben Moreno
Originally Posted by immortality View Post
hi
Hi, I do not know about rhoPimpleFoam, I have never used it, only pimpleDymFoam. This is how the constant/dynamicMeshDict file looks
dynamicFvMesh      solidBodyMotionFvMesh;
motionSolverLibs ("libfvMotionSolvers.so");
solidBodyMotionFvMeshCoeffs
solidBodyMotionFunction oscillatingRotatingMotion;
oscillatingRotatingMotionCoeffs
CofG        (0.25 0.007 0.125);
amplitude    (0 0 0.573);
omega            30.;
Old   January 30, 2013, 09:21
Ehsan
sorry.i corrected it.how can specify which cells are moving and which are stationary ones? Could you send me necessary files?thanks.
Old   January 30, 2013, 18:06
Ruben Moreno
The dynamicMeshDict file I shared is all you need to move the mesh rigidly, it all moves as a solid. If you want to specify only certain zones I think you need to use AMI, but I have never done it...
Old   January 31, 2013, 12:32
Ehsan
thanks.these show what i want to model.
Old   February 4, 2013, 01:47
Ehsan
does anyone could help on how can it be simulated?how to start?
Old   February 5, 2013, 14:30
Ehsan
Ruben do you know how can i set in the dictionary you wrote for a linear displacement solid body motion?
Old   February 6, 2013, 19:06
Ruben Moreno
It should simply be oscillatingLinearMotion, you can see the dictionary and any other available solidbody functions in
src/dynamicFvMesh/solidBodyMotionFvMesh/solidBodyMotionFunctions/*
Old   February 12, 2013, 12:34
Ehsan
thanks.but i dont want oscillating motion.how to set linear constant velocity motion?
Old   March 16, 2016, 14:29
Default Solid Body Motion rhoCentralDyMFoam ACMI
  #12
yardsail is on a distinguished road
I just tried the same thing, starting with the tutorial oscillatingInletACMI2D and modifying it to use rhoCentralDyMFoam instead of pimpleDyMFoam.
Just like the OP, it asks for a solver even though it shouldn't use one for the prescribed solid body motion.
Here is my dynamicMeshDict file:
FoamFile
version 2.0;
format ascii;
class dictionary;
location "constant";
object dynamicMeshDict;
motionSolverLibs ( "libfvMotionSolvers.so" );
cellZone inletChannel;
solidBodyMotionFunction oscillatingLinearMotion;
oscillatingLinearMotionCoeffs
amplitude (0 0.5 0);
omega 3.14; // rad/s (.5 rps)
This is an old thread, but I wonder if anyone has found a workaround?
Thanks!
yardsail is offline   Reply With Quote
Old   October 31, 2018, 05:29
Default Solid body motion function
  #13
Chayanit Nigaltia
CHAYANIT is on a distinguished road
For mesh movement my dynamicMeshDict file is as follow
omega 30;
It is working fine on airfoil pitching. But can anyone tell me what is meant by amplitude and omega in this file.What amplitude and omega is it referring to and is this fine to work on pitching foil?
Any reply would be appreciated.
regards
Chayanit
CHAYANIT is offline   Reply With Quote
dynamicmesh, rhocentraldymfoam, solid body
A case for rhoCentralDYMFoam immortality OpenFOAM Running, Solving & CFD 3 June 5, 2014 01:54
[mesh manipulation] Which solver for solidBodyMotion A.A. OpenFOAM Meshing & Mesh Conversion 6 January 31, 2013 12:45
[blockMesh] solidBodyMotion with cavity tutorial? A.A. OpenFOAM Meshing & Mesh Conversion 0 July 19, 2012 10:40
Using solidBodyMotion for rigid body motion L1011 OpenFOAM 4 July 5, 2011 04:59
solidbodymotion and mesh.update() pablodecastillo OpenFOAM Running, Solving & CFD 0 April 13, 2011 18:24
