Problem with tempFoam setting system/fvSolution |
February 15, 2013, 11:14 |
Daniele Obiso
i'm new with OpenFOAM, and i'm trying to learn using it thanks to some tutorials. I'm studyng a HVAC problem with a thermal transient. I run the case and it seems to go well, but before endTime i get a crash with this error: #0 Foam::error:rintStack(Foam::Ostream&)-------------------------------------------------------------------------- An MPI process has executed an operation involving a call to the "fork()" system call to create a child process. Open MPI is currently operating in a condition that could result in memory corruption or other system errors; your MPI job may hang, crash, or produce silent data corruption. The use of fork() (or system() or other calls that create child processes) is strongly discouraged. I think the problem is the solver used for temperature in system/fvSolution, because i was not sure about setting it. I used both GaussSeidel and PBiCG, and it's not working. Any tip about this problem? Best regards, Daniele |
Problem setting C_MU_T with DEFINE_ADJUST | Andy | FLUENT | 3 | June 22, 2018 02:53 |
Problem in setting porosity region for rhoPorousSimpleFoam | run_cfd | OpenFOAM Pre-Processing | 1 | May 31, 2011 09:02 |
Problem setting AV | Marko | CFX | 0 | March 18, 2005 08:06 |
Problem setting C_MU_T with DEFINE_ADJUST | sarah_ron | FLUENT | 1 | February 24, 2005 12:11 |
Help setting up combustor problem | Tom | FLUENT | 0 | February 5, 2005 01:20 |
