consult some questions about the interPhaseChangeFoam |
August 30, 2010, 01:26 |
zhangmo
Hello,everyone:
I'm very interested in the cavitation flow around airfoil. Furthermore, I want to use the interPhaseChangeFoam solver in the directory of application. But I can't understand how to set the three files of 0、constant and system ? Could you give me some advice about it? Or some Tutorials about the cavitaion flow. thank you very much! |
September 1, 2010, 11:46 |
Tutorial
Sabin Ceuca
Rep Power: 16 |
Hi there you can find a tutorial for this solver here http://www.tfd.chalmers.se/~hani/kur...ChangeFoam.pdf
chalmers is the right address for many solvers best regards |
March 1, 2012, 19:34 |
Singhal models in myinterPhasechangeFoam
vahid
Rep Power: 13 |
My purpose is adding Zwart and Singhal models to interPhaseChangeFoam solver.
I transform Saur model to Zwart model successfully but transforming Saur model to Singhal model is faild!!! my error is : phaseChangeTwoPhaseMixtures/phaseChangeTwoPhaseMixture/phaseChangeTwoPhaseMixture.C:48: error: no matching function for call to ‘Foam::dimensioned<double>::dimensioned()’ Can you help me??? |
March 2, 2012, 11:05 |
dimension?
vahid
Rep Power: 13 |
thanks for your idea,but i need more Explanation about it!!!
June 6, 2012, 23:48 |
please help me...
vahid
Rep Power: 13 |
Hello dear foames,
I have an easy question, i wanna add the kinetic Turbulence energy (k) in model <<Sauer>> for solver <<interPhaseChangeFoam>>. For this purpose, after adding turbulence library in the option file, for introducing “k” in the Sauer model, this parameter is added as the follow // * * * * * * * * * * * * * * Member Functions * * * * * * * * * * * * * * // Foam::tmp<Foam::volScalarField> Foam:haseChangeTwoPhaseMixtures::SchnerrSauer::r Rb ( const volScalarField& limitedAlpha1 ) const { return pow ( ((k_*4*constant::mathematical:i*n_)/3) *limitedAlpha1/(1.0 + alphaNuc() - limitedAlpha1), 1.0/3.0 ); } when I execute wmake in terminal ,this error is appeared. phaseChangeTwoPhaseMixtures/SchnerrSauer/SchnerrSauer.C:79: error: ‘k_’ was not declared in this scope make: *** [Make/linux64GccDPOpt/SchnerrSauer.o] Error 1 could everyone to tell me the steps of how to add the kinetic energy in the Sauer model so that after any iteration, new updated value is entered to this model ? Regards |
April 8, 2013, 07:25 |
#10 |
ABE
Rep Power: 13 |
I am using InterPhaseChange solver to simulate cavitation in OF2.1x Although by old versions (i.e. OF1.5) I can get good results, with this new version results are not good at all. Dose anybody else get similar conflicts? ABE |
Bug about MULES::implicitSolve for interPhaseChangeFoam in OF-1.6 | chiven | OpenFOAM Bugs | 18 | April 18, 2013 22:56 |
NACA0012 Validation Case Questions | ozzythewise | Main CFD Forum | 3 | August 3, 2010 14:39 |
So many questions in DPM & UDF - Help! URGENT! | Prashanth | FLUENT | 0 | March 3, 2009 22:26 |
Questions about CFD | Lebeau alexandre | Main CFD Forum | 1 | April 6, 1999 14:23 |
turbulence modeling questions | llowen | Main CFD Forum | 3 | September 11, 1998 04:24 |
