March 5, 2013, 16:54 |
whats the cause of error?
Ehsan
Rep Power: 26 |
i have written three pressure BC.and then tried to do by groovyBC.although it seems equivalent to others it don't work.
if this problem resolve i think the trouble is removed. fixedValue p:OK Code:
type fixedValue; value uniform 1023382.5; Code:
type totalPressure; rho none; psi psi; phi phi; p0 1023382.5; gamma 1.4; Code:
type groovyBC; fractionExpression "1"; valueExpression "1023382.5/pow(1+(1.4-1)*magSqr(U)/(2*1.4*287.14*T),3.5)"; value uniform 3523382.5; Code:
Create time Create mesh for time = 0 PIMPLE: no residual control data found. Calculations will employ 3 corrector loops Reading thermophysical properties Selecting thermodynamics package hPsiThermo<pureMixture<sutherlandTransport<specieThermo<janafThermo<perfectGas>>>>> Reading field U Reading/calculating face flux field phi Creating turbulence model Selecting turbulence model type laminar Creating field dpdt Creating field kinetic energy K Starting time loop Courant Number mean: 0 max: 0 deltaT = 1e-06 Time = 1e-06 diagonal: Solving for rho, Initial residual = 0, Final residual = 0, No Iterations 0 PIMPLE: iteration 1 DILUPBiCG: Solving for Ux, Initial residual = 0.9999620096, Final residual = 4.199402748e-15, No Iterations 2 DILUPBiCG: Solving for Uy, Initial residual = 1.005998662e-08, Final residual = 7.973709578e-16, No Iterations 1 DILUPBiCG: Solving for h, Initial residual = 0.0001693584029, Final residual = 4.837750541e-11, No Iterations 1 #0 Foam::error::printStack(Foam::Ostream&) in "/opt/openfoam211/platforms/linux64GccDPOpt/lib/libOpenFOAM.so" #1 Foam::sigFpe::sigHandler(int) in "/opt/openfoam211/platforms/linux64GccDPOpt/lib/libOpenFOAM.so" #2 in "/lib/x86_64-linux-gnu/libc.so.6" #3 Foam::divide(Foam::Field<double>&, Foam::UList<double> const&, Foam::UList<double> const&) in "/opt/openfoam211/platforms/linux64GccDPOpt/lib/libOpenFOAM.so" #4 void Foam::divide<Foam::fvsPatchField, Foam::surfaceMesh>(Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh>&, Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&) in "/opt/openfoam211/platforms/linux64GccDPOpt/lib/libcompressibleRASModels.so" #5 Foam::tmp<Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> > Foam::operator/<Foam::fvsPatchField, Foam::surfaceMesh>(Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::tmp<Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> > const&) in "/opt/openfoam211/platforms/linux64GccDPOpt/lib/libcompressibleRASModels.so" #6 Foam::fv::backwardDdtScheme<Foam::Vector<double> >::fvcDdtPhiCorr(Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&) in "/opt/openfoam211/platforms/linux64GccDPOpt/lib/libfiniteVolume.so" #7 at rhoPimpleFoam.C:0 #8 in "/opt/openfoam211/platforms/linux64GccDPOpt/bin/rhoPimpleFoam" #9 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6" #10 in "/opt/openfoam211/platforms/linux64GccDPOpt/bin/rhoPimpleFoam" Floating point exception thanks for quick helps. |
March 5, 2013, 16:57 |
Ehsan
Rep Power: 26 |
the whole p is:
FoamFile { version 2.0; format ascii; class volScalarField; object p; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dimensions [1 -1 -2 0 0 0 0]; internalField uniform 3523382.5;//1823382.5 boundaryField { right { /*type fixedValue; value uniform 1023382.5;*/ /*type totalPressure; rho none; psi psi; phi phi; p0 1023382.5; gamma 1.4;*/ type groovyBC; fractionExpression "1"; valueExpression "1023382.5/pow(1+(1.4-1)*magSqr(U)/(2*1.4*287.14*T),3.5)"; value uniform 3523382.5; } left { type zeroGradient; } walls { type zeroGradient; } empty { type empty; } } I have to write BC in groovyBC form because of more complicated main case I have to solve. thanks very much.please answer rapidly. |
March 5, 2013, 18:50 |
Daniel P. Combest
There are several issues:
Your BC may be giving the error when a boundary condition is corrected and has a T == zero for some reason. Honestly, without more information this is the best i can do with solving your issue...but its an educated guess at this point. #OFProtip Last edited by chegdan; March 5, 2013 at 19:24. |
March 5, 2013, 19:03 |
Ehsan
Rep Power: 26 |
thanks.T isn't zero and also its same for all three tests.but only in groovy it occurs.
March 5, 2013, 19:23 |
Daniel P. Combest
did you try another time integration scheme? I see a backwardDdtScheme in your error message and there may be something happening there. Also, just to prove that its not the T in the denominator, change your value expression to
valueExpression "1023382.5/pow(1+(1.41)*magSqr(U)/(2*1.4*287.14*T + 1e-8),3.5)"; |
March 6, 2013, 05:07 |
Ehsan
Rep Power: 26 |
i changed time scheme to Euler and changed T but error persists.initial U is zero and i changed it but the error didn't change
these are variable BC's: p: Code:
FoamFile { version 2.0; format ascii; class volScalarField; object p; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dimensions [1 -1 -2 0 0 0 0]; internalField uniform 3523382.5;//1823382.5 boundaryField { right { /*type fixedValue; value uniform 1023382.5;*/ /*type totalPressure; rho none; psi psi; phi phi; p0 1023382.5; gamma 1.4;*/ type groovyBC; fractionExpression "1"; valueExpression "1023382.5/pow(1+(1.4-1)*magSqr(U)/(2*1.4*287.14*T+1e-8),3.5)"; value uniform 3523382.5; } left { type zeroGradient; } walls { type zeroGradient; } empty { type empty; } } Code:
dimensions [0 1 -1 0 0 0 0]; internalField uniform (1 0 0); boundaryField { right { type zeroGradient; } left { type fixedValue; value uniform (0 0 0); /*type groovyBC; variables ( ); fractionExpression "1"; valueExpression "vector(internalField(U).x,0,0)"; value uniform (0 0 0);*/ } walls { type fixedValue; value uniform (0 0 0); } empty { type empty; } } Code:
FoamFile { version 2.0; format ascii; class volScalarField; object T; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dimensions [0 0 0 1 0 0 0]; internalField uniform 973; boundaryField { right { type zeroGradient; /*type groovyBC; value uniform 973; // valueExpression "907";//T0_2-(1.4-1)*magSqr(internalField(U))/(2*1.4*287.14) gradientExpression "0"; fractionExpression "0";*/ } left { type zeroGradient; } walls { type zeroGradient; } empty { type empty; } } Code:
solvers { p { solver PCG; preconditioner DIC; tolerance 1e-11; relTol 0; } pFinal { $p; relTol 0; } "rho.*" { $p; tolerance 1e-10; relTol 0; } "(U|e|h|R|k|epsilon|omega)" { solver PBiCG; preconditioner DILU; tolerance 1e-10; relTol 0; maxIter 25000; } "(U|h|R|k|epsilon|omega)Final" { $U; relTol 0; } } PIMPLE { momentumPredictor yes; nOuterCorrectors 3; nCorrectors 5; nNonOrthogonalCorrectors 0; rhoMin rhoMin [ 1 -3 0 0 0 ] 0.01; rhoMax rhoMax [ 1 -3 0 0 0 ] 100.0; } Code:
ddtSchemes { default Euler;//backward } gradSchemes { default faceMDLimited Gauss midPoint 1; grad(p) faceMDLimited Gauss midPoint 1; grad(U) faceMDLimited Gauss cubic 1; //faceMDLimited Gauss GammaV 1 } divSchemes { default none; div(phi,U) Gauss SFCDV grad(U);//SFCDV-linearUpwind div(phi,K) Gauss SuperBee;//Minmod div(phi,h) Gauss SuperBee; div(phi,k) Gauss SuperBee; div(phi,omega) Gauss SuperBee; div(U) Gauss SuperBeeV;//Gauss limitedLimitedLinear 1 0 1 div((muEff*dev2(T(grad(U))))) Gauss linear; } laplacianSchemes { default Gauss midPoint limited .5;//limited .5 /*laplacian(muEff,U) Gauss linear corrected; laplacian(mut,U) Gauss linear corrected; laplacian(DkEff,k) Gauss linear corrected; laplacian(DomegaEff,omega) Gauss linear corrected; laplacian((rho*(1|A(U))),p) Gauss linear corrected; laplacian(alphaEff,h) Gauss linear corrected; laplacian(k,T) Gauss linear corrected; laplacian(alpha,e) Gauss linear corrected; laplacian(alphaEff,e) Gauss linear corrected;*/ } interpolationSchemes { default midPoint;// cubicCorrection } snGradSchemes { default limited .5;//corrected } fluxRequired { default no; p ; } Code:
FoamFile { version 2.0; format ascii; class dictionary; location "system"; object controlDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // libs ( "libOpenFOAM.so" "libsimpleSwakFunctionObjects.so" "libswakFunctionObjects.so" "libgroovyBC.so" ); application rhoPimpleFoam; startFrom latestTime; startTime 0; stopAt endTime; endTime 2000e-6;//0.020708089; deltaT 1e-6; writeControl adjustableRunTime; writeInterval .000001; purgeWrite 0; writeFormat ascii; writePrecision 10; writeCompression off; timeFormat general; timePrecision 6; runTimeModifiable true; adjustTimeStep yes; maxCo 0.1; maxDeltaT 1; |
March 6, 2013, 10:21 |
Ehsan
Rep Power: 26 |
thanks for your effort to help dear Daniel.
It was because of new groovyBC.I changed to old version and it answer now. |
March 6, 2013, 10:22 |
Daniel P. Combest
OK, it is indeed your BC setup. I don't have the time to set this up for you, but i have some suggestions.
Good luck EDIT: read your new post that just mystically appeared....glad you figured it out Last edited by chegdan; March 6, 2013 at 10:26. Reason: read new post |
March 6, 2013, 11:41 |
Ehsan
Rep Power: 26 |
a question occur to me that I'm curious about.
when I set BC for U to zeroGradient or: Code:
right { type groovyBC; fractionExpression "0"; gradientExpression "vector(0,0,0)"; } but when I set it to: Code:
right { type groovyBC; fractionExpression "1"; valueExpression "internalField(U)";//vector(internalField(U).x,0,0) } Code:
From function janafThermo<EquationOfState>::limit(const scalar T) const in file /home/opencfd/OpenFOAM/OpenFOAM-2.1.1/src/thermophysicalModels/specie/lnInclude/janafThermoI.H at line 108 attempt to use janafThermo<EquationOfState> out of temperature range 200 -> 6000; T = -3333091.721 --> FOAM Warning : From function janafThermo<EquationOfState>::limit(const scalar T) const in file /home/opencfd/OpenFOAM/OpenFOAM-2.1.1/src/thermophysicalModels/specie/lnInclude/janafThermoI.H at line 108 attempt to use janafThermo<EquationOfState> out of temperature range 200 -> 6000; T = 4080511.561 --> FOAM Warning : From function janafThermo<EquationOfState>::limit(const scalar T) const in file /home/opencfd/OpenFOAM/OpenFOAM-2.1.1/src/thermophysicalModels/specie/lnInclude/janafThermoI.H at line 108 attempt to use janafThermo<EquationOfState> out of temperature range 200 -> 6000; T = -7124696.499 --> FOAM Warning : From function janafThermo<EquationOfState>::limit(const scalar T) const in file /home/opencfd/OpenFOAM/OpenFOAM-2.1.1/src/thermophysicalModels/specie/lnInclude/janafThermoI.H at line 108 attempt to use janafThermo<EquationOfState> out of temperature range 200 -> 6000; T = 5774453.414 --> FOAM Warning : From function janafThermo<EquationOfState>::limit(const scalar T) const in file /home/opencfd/OpenFOAM/OpenFOAM-2.1.1/src/thermophysicalModels/specie/lnInclude/janafThermoI.H at line 108 attempt to use janafThermo<EquationOfState> out of temperature range 200 -> 6000; T = -6575768.989 --> FOAM Warning : From function janafThermo<EquationOfState>::limit(const scalar T) const in file /home/opencfd/OpenFOAM/OpenFOAM-2.1.1/src/thermophysicalModels/specie/lnInclude/janafThermoI.H at line 108 attempt to use janafThermo<EquationOfState> out of temperature range 200 -> 6000; T = 5981361.409 --> FOAM Warning : From function janafThermo<EquationOfState>::limit(const scalar T) const in file /home/opencfd/OpenFOAM/OpenFOAM-2.1.1/src/thermophysicalModels/specie/lnInclude/janafThermoI.H at line 108 attempt to use janafThermo<EquationOfState> out of temperature range 200 -> 6000; T = 1404258.482 --> FOAM Warning : From function janafThermo<EquationOfState>::limit(const scalar T) const in file /home/opencfd/OpenFOAM/OpenFOAM-2.1.1/src/thermophysicalModels/specie/lnInclude/janafThermoI.H at line 108 attempt to use janafThermo<EquationOfState> out of temperature range 200 -> 6000; T = -17090209.16 --> FOAM Warning : From function janafThermo<EquationOfState>::limit(const scalar T) const in file /home/opencfd/OpenFOAM/OpenFOAM-2.1.1/src/thermophysicalModels/specie/lnInclude/janafThermoI.H at line 108 attempt to use janafThermo<EquationOfState> out of temperature range 200 -> 6000; T = 36020792.5 --> FOAM Warning : From function janafThermo<EquationOfState>::limit(const scalar T) const in file /home/opencfd/OpenFOAM/OpenFOAM-2.1.1/src/thermophysicalModels/specie/lnInclude/janafThermoI.H at line 108 attempt to use janafThermo<EquationOfState> out of temperature range 200 -> 6000; T = -94818398.64 --> FOAM Warning : From function janafThermo<EquationOfState>::limit(const scalar T) const in file /home/opencfd/OpenFOAM/OpenFOAM-2.1.1/src/thermophysicalModels/specie/lnInclude/janafThermoI.H at line 108 attempt to use janafThermo<EquationOfState> out of temperature range 200 -> 6000; T = 40233402.34 --> FOAM Warning : From function janafThermo<EquationOfState>::limit(const scalar T) const in file /home/opencfd/OpenFOAM/OpenFOAM-2.1.1/src/thermophysicalModels/specie/lnInclude/janafThermoI.H at line 108 attempt to use janafThermo<EquationOfState> out of temperature range 200 -> 6000; T = -106376680.8 --> FOAM Warning : From function janafThermo<EquationOfState>::limit(const scalar T) const in file /home/opencfd/OpenFOAM/OpenFOAM-2.1.1/src/thermophysicalModels/specie/lnInclude/janafThermoI.H at line 108 attempt to use janafThermo<EquationOfState> out of temperature range 200 -> 6000; T = 37389446.51 --> FOAM Warning : From function janafThermo<EquationOfState>::limit(const scalar T) const in file /home/opencfd/OpenFOAM/OpenFOAM-2.1.1/src/thermophysicalModels/specie/lnInclude/janafThermoI.H at line 108 attempt to use janafThermo<EquationOfState> out of temperature range 200 -> 6000; T = -76115211.3 --> FOAM Warning : From function janafThermo<EquationOfState>::limit(const scalar T) const in file /home/opencfd/OpenFOAM/OpenFOAM-2.1.1/src/thermophysicalModels/specie/lnInclude/janafThermoI.H at line 108 attempt to use janafThermo<EquationOfState> out of temperature range 200 -> 6000; T = -24650104.63 --> FOAM Warning : From function janafThermo<EquationOfState>::limit(const scalar T) const in file /home/opencfd/OpenFOAM/OpenFOAM-2.1.1/src/thermophysicalModels/specie/lnInclude/janafThermoI.H at line 108 attempt to use janafThermo<EquationOfState> out of temperature range 200 -> 6000; T = -26951665.22 --> FOAM Warning : From function janafThermo<EquationOfState>::limit(const scalar T) const in file /home/opencfd/OpenFOAM/OpenFOAM-2.1.1/src/thermophysicalModels/specie/lnInclude/janafThermoI.H at line 108 attempt to use janafThermo<EquationOfState> out of temperature range 200 -> 6000; T = 471535.4463 --> FOAM Warning : From function janafThermo<EquationOfState>::limit(const scalar T) const in file /home/opencfd/OpenFOAM/OpenFOAM-2.1.1/src/thermophysicalModels/specie/lnInclude/janafThermoI.H at line 108 attempt to use janafThermo<EquationOfState> out of temperature range 200 -> 6000; T = 465677.0027 --> FOAM Warning : From function janafThermo<EquationOfState>::limit(const scalar T) const in file /home/opencfd/OpenFOAM/OpenFOAM-2.1.1/src/thermophysicalModels/specie/lnInclude/janafThermoI.H at line 108 attempt to use janafThermo<EquationOfState> out of temperature range 200 -> 6000; T = 277204.4414 --> FOAM Warning : From function janafThermo<EquationOfState>::limit(const scalar T) const in file /home/opencfd/OpenFOAM/OpenFOAM-2.1.1/src/thermophysicalModels/specie/lnInclude/janafThermoI.H at line 108 attempt to use janafThermo<EquationOfState> out of temperature range 200 -> 6000; T = -145721.0621 --> FOAM Warning : From function janafThermo<EquationOfState>::limit(const scalar T) const in file /home/opencfd/OpenFOAM/OpenFOAM-2.1.1/src/thermophysicalModels/specie/lnInclude/janafThermoI.H at line 108 attempt to use janafThermo<EquationOfState> out of temperature range 200 -> 6000; T = 15779.92442 --> FOAM Warning : From function janafThermo<EquationOfState>::limit(const scalar T) const in file /home/opencfd/OpenFOAM/OpenFOAM-2.1.1/src/thermophysicalModels/specie/lnInclude/janafThermoI.H at line 108 attempt to use janafThermo<EquationOfState> out of temperature range 200 -> 6000; T = 112883.4828 --> FOAM Warning : From function janafThermo<EquationOfState>::limit(const scalar T) const in file /home/opencfd/OpenFOAM/OpenFOAM-2.1.1/src/thermophysicalModels/specie/lnInclude/janafThermoI.H at line 108 attempt to use janafThermo<EquationOfState> out of temperature range 200 -> 6000; T = -3083.273126 --> FOAM Warning : From function janafThermo<EquationOfState>::limit(const scalar T) const in file /home/opencfd/OpenFOAM/OpenFOAM-2.1.1/src/thermophysicalModels/specie/lnInclude/janafThermoI.H at line 108 attempt to use janafThermo<EquationOfState> out of temperature range 200 -> 6000; T = 43.52495911 --> FOAM Warning : From function janafThermo<EquationOfState>::limit(const scalar T) const in file /home/opencfd/OpenFOAM/OpenFOAM-2.1.1/src/thermophysicalModels/specie/lnInclude/janafThermoI.H at line 108 attempt to use janafThermo<EquationOfState> out of temperature range 200 -> 6000; T = 4976486.257 --> FOAM Warning : From function janafThermo<EquationOfState>::limit(const scalar T) const in file /home/opencfd/OpenFOAM/OpenFOAM-2.1.1/src/thermophysicalModels/specie/lnInclude/janafThermoI.H at line 108 attempt to use janafThermo<EquationOfState> out of temperature range 200 -> 6000; T = 3178348.937 --> FOAM Warning : From function janafThermo<EquationOfState>::limit(const scalar T) const in file /home/opencfd/OpenFOAM/OpenFOAM-2.1.1/src/thermophysicalModels/specie/lnInclude/janafThermoI.H at line 108 attempt to use janafThermo<EquationOfState> out of temperature range 200 -> 6000; T = -32897237.32 --> FOAM Warning : From function janafThermo<EquationOfState>::limit(const scalar T) const in file /home/opencfd/OpenFOAM/OpenFOAM-2.1.1/src/thermophysicalModels/specie/lnInclude/janafThermoI.H at line 108 attempt to use janafThermo<EquationOfState> out of temperature range 200 -> 6000; T = -44825686.95 --> FOAM Warning : From function janafThermo<EquationOfState>::limit(const scalar T) const in file /home/opencfd/OpenFOAM/OpenFOAM-2.1.1/src/thermophysicalModels/specie/lnInclude/janafThermoI.H at line 108 attempt to use janafThermo<EquationOfState> out of temperature range 200 -> 6000; T = -22612.51171 --> FOAM Warning : From function janafThermo<EquationOfState>::limit(const scalar T) const in file /home/opencfd/OpenFOAM/OpenFOAM-2.1.1/src/thermophysicalModels/specie/lnInclude/janafThermoI.H at line 108 attempt to use janafThermo<EquationOfState> out of temperature range 200 -> 6000; T = -1870.615087 --> FOAM Warning : From function janafThermo<EquationOfState>::limit(const scalar T) const in file /home/opencfd/OpenFOAM/OpenFOAM-2.1.1/src/thermophysicalModels/specie/lnInclude/janafThermoI.H at line 108 attempt to use janafThermo<EquationOfState> out of temperature range 200 -> 6000; T = 9690.272357 --> FOAM Warning : From function janafThermo<EquationOfState>::limit(const scalar T) const in file /home/opencfd/OpenFOAM/OpenFOAM-2.1.1/src/thermophysicalModels/specie/lnInclude/janafThermoI.H at line 108 attempt to use janafThermo<EquationOfState> out of temperature range 200 -> 6000; T = -39521.73991 --> FOAM Warning : From function janafThermo<EquationOfState>::limit(const scalar T) const in file /home/opencfd/OpenFOAM/OpenFOAM-2.1.1/src/thermophysicalModels/specie/lnInclude/janafThermoI.H at line 108 attempt to use janafThermo<EquationOfState> out of temperature range 200 -> 6000; T = 93265.31041 --> FOAM Warning : From function janafThermo<EquationOfState>::limit(const scalar T) const in file /home/opencfd/OpenFOAM/OpenFOAM-2.1.1/src/thermophysicalModels/specie/lnInclude/janafThermoI.H at line 108 attempt to use janafThermo<EquationOfState> out of temperature range 200 -> 6000; T = -340838.0148 --> FOAM Warning : From function janafThermo<EquationOfState>::limit(const scalar T) const in file /home/opencfd/OpenFOAM/OpenFOAM-2.1.1/src/thermophysicalModels/specie/lnInclude/janafThermoI.H at line 108 attempt to use janafThermo<EquationOfState> out of temperature range 200 -> 6000; T = 610015.5259 --> FOAM Warning : From function janafThermo<EquationOfState>::limit(const scalar T) const in file /home/opencfd/OpenFOAM/OpenFOAM-2.1.1/src/thermophysicalModels/specie/lnInclude/janafThermoI.H at line 108 attempt to use janafThermo<EquationOfState> out of temperature range 200 -> 6000; T = -1813983.217 --> FOAM Warning : From function janafThermo<EquationOfState>::limit(const scalar T) const in file /home/opencfd/OpenFOAM/OpenFOAM-2.1.1/src/thermophysicalModels/specie/lnInclude/janafThermoI.H at line 108 attempt to use janafThermo<EquationOfState> out of temperature range 200 -> 6000; T = 2650248.864 --> FOAM Warning : From function janafThermo<EquationOfState>::limit(const scalar T) const in file /home/opencfd/OpenFOAM/OpenFOAM-2.1.1/src/thermophysicalModels/specie/lnInclude/janafThermoI.H at line 108 attempt to use janafThermo<EquationOfState> out of temperature range 200 -> 6000; T = -6558287.943 why? Last edited by immortality; March 6, 2013 at 17:08. |
April 21, 2014, 01:14 |
#10 | |
CFDUser
Did you find any clue for above warning to fix? Regards, CFDUser_ |
April 21, 2014, 10:45 |
#11 | |
Ehsan
Rep Power: 26 |
besides that, the velocity on outward flow should be read from inside implicitly and only pressure should be set there as a known value otherwise error will arise due to instability. I hope these explanations be what you asked about.
Injustice Anywhere is a Threat for Justice Everywhere.Martin Luther King. To Be or Not To Be,Thats the Question! The Only Stupid Question Is the One that Goes Unasked. |
April 22, 2014, 12:32 |
#12 | |
CFDUser
Regards, CFDUser_ |
July 11, 2019, 17:33 |
#13 |
Miriana De Rose
Rep Power: 6 |
I also have this problem. But I don't know how to fix it. --> FOAM Warning : From function Foam::scalar Foam::janafThermo<EquationOfState>::limit(Foam::sc alar) const [with EquationOfState = Foam:erfectGas<Foam::specie>; Foam::scalar = double] in file /home/pawan/OpenFOAM/OpenFOAM-v1812/src/thermophysicalModels/specie/lnInclude/janafThermoI.H at line 117 attempt to use janafThermo<EquationOfState> out of temperature range 200 -> 5000; T = -388.868 --> FOAM Warning : From function Foam::scalar Foam::janafThermo<EquationOfState>::limit(Foam::sc alar) const [with EquationOfState = Foam:erfectGas<Foam::specie>; Foam::scalar = double] in file /home/pawan/OpenFOAM/OpenFOAM-v1812/src/thermophysicalModels/specie/lnInclude/janafThermoI.H at line 117 attempt to use janafThermo<EquationOfState> out of temperature range 200 -> 5000; T = -111.631 min/max(T) = 200, 1742.55 Any suggestion? I read that the problem could be about different values in BC in the Internal Field and in the neighbor cells, but i did not understand exactly what it means! |
March 24, 2021, 07:15 |
#14 | |
Evren Yilmaz Yakin
Rep Power: 10 |
Hi, I have a same problem when using reactingFoamLTS
Do you have any idea about this issue? Quote:
Best Regards, Evren |
[swak4Foam] GroovyBC the dynamic cousin of funkySetFields that lives on the suburb of the mesh | gschaider | OpenFOAM Community Contributions | 300 | October 29, 2014 18:00 |
c++ libraries and solver compiling | vaina74 | OpenFOAM Installation | 13 | February 3, 2012 17:43 |
[OpenFOAM] Saving ParaFoam views and case | sail | ParaView | 9 | November 25, 2011 15:46 |
user defined function | cfduser | CFX | 0 | April 29, 2006 10:58 |
