script for replacing block of code
Old   March 14, 2013, 11:18
Default script for replacing block of code
Henning86 is on a distinguished road
Im runnning OpenFoam on a server. im exchanging the data with samba and do the post processing with paraview on windows the problem is that paraview doesn't know the bc:
inflow
type uniformFixedValue;
uniformValue table
( 0 (0 0 0.0))
( 0.0005 (50 0 0.0))
( 0.0025(600 0 0))
so i can't see the velocity field. I want to replace the solution with a different BC for example
inflow
type fixedValue;
value uniform (600 0 0);
With that bc im able to see the the velocity field with paraview on the local windows machine.
I am looking for a script that is able to replace the whole String block with another one
I just manage do replace a string with a script in the subfolder my code for that is (which works but doesn't solve the problem):
#!/bin/bash
find . -name "*.txt" -exec sed -i 's/old/new/g' {} \;
Im unable to find a sed code that will do the job.
Can anybody post a script that will replace the bc with the other one?
Henning86 is offline   Reply With Quote
Old   March 14, 2013, 11:48
Nucleophobe is on a distinguished road
In vim, you *can* do multiline find-replace. Just use '\n' to capture newlines.
There's probably a better way, as this gets messy. But you can try:
:%s/inflow\n{\ntype uniformFixedValue; \nuniformValue table \n(\n( 0 (0 0 0.0))\n( 0.0005 (50 0 0.0)) \n( 0.0025(600 0 0)) \n);\n}/inflow\r{\rtype fixedValue;\rvalue uniform (600 0 0);\r}
The '\r' is also a carriage return. I don't understand why, but if you try to write the '\n' character, it turns into '\@'
Anyways, I just tried this and it worked.
Nucleophobe is offline   Reply With Quote
Old   March 15, 2013, 04:32
im really bad at scripting. so i just replaced sed with vim.tiny followed by the long command:
#!/bin/bash
find . -name "*.jsp" -exec vim.tiny :%s/inflow\n{\ntype uniformFixedValue; \nuniformValue table \n(\n( 0 (0 0 0.0))\n( 0.0005 (50 0 0.0)) \n( 0.0025(600 0 0)) \n);\n}/inflow\r{\rtype fixedValue;\rvalue uniform (600 0 0);\r}
This gives me an error.
Can vim be used in a script and is vim.tiny able to do that?
vim isn't installed at the server.
i sadly haven't worked with vim at all.
[ICEM] Hexa to Sweep block conversion pertupd ANSYS Meshing & Geometry 1 June 19, 2010 21:37
Running Matlab script from Scheme code dhimans Fluent UDF and Scheme Programming 0 July 28, 2009 15:13
Design Integration with CFD? John C. Chien Main CFD Forum 19 May 17, 2001 15:56
What is the Better Way to Do CFD? John C. Chien Main CFD Forum 54 April 23, 2001 08:10
own Code vs. commercial code Bernhard Mueck Main CFD Forum 10 February 16, 2000 10:07
