definition of totalPressure
Old   March 5, 2013, 10:18
Default definition of totalPressure
immortality's Avatar
Ehsan
immortality is on a distinguished road
in the totalPressure BC at this part:
if (psiName_ == "none" && rhoName_ == "none")
        operator==(p0p - 0.5*(1.0 - pos(phip))*magSqr(Up));
    else if (rhoName_ == "none")
        const fvPatchField<scalar>& psip =
            patch().lookupPatchField<volScalarField, scalar>(psiName_);
        if (gamma_ > 1.0)
            scalar gM1ByG = (gamma_ - 1.0)/gamma_;
            operator==
                p0p
               /pow
                    (1.0 + 0.5*psip*gM1ByG*(1.0 - pos(phip))*magSqr(Up)),
                    1.0/gM1ByG
        else
            operator==(p0p/(1.0 + 0.5*psip*(1.0 - pos(phip))*magSqr(Up)));
there is this well-known formula.but there is some questions
1) why "(1.0 - pos(phip))" term is put in this formula?what it means?
2)does Up and psip stand for internalField(p) and 1/(R*internalField(T))?
p0p
               /pow
                    1.0/gM1ByG
3)I have written this formula(isentropic relation) in groovyBC in this manner:
p0_2/pow(1+(gamma-1)/2*magSqr(internalField(U))/(gamma*R*internalField(T)),3.5)
is it equivalent correctly to what there is in OF totalPressure code?
immortality is offline   Reply With Quote
Old   March 5, 2013, 10:31
doubtsincfd is on a distinguished road
We had some discussion on the total pressure bc sometime back.
See if it helps you:
http://www.cfd-online.com/Forums/ope...tml#post401213
doubtsincfd is offline   Reply With Quote
Old   March 5, 2013, 12:04
Ehsan
thanks a lot.
then its incorrect to set totalPressure at outlet?
I have 2 totalPressure BC at inlet and outlet.at inlet it behaves somewhat good(except supersonic velocity at 3-4 begining time steps that should be subsonic in real but it modifies at later time steps and becomes subsonic) but when outlet opens pressure goes too little and velocity increases a lot and problem diverges.
could anyone argue about the formula I have written at above post?
thanks.
Old   March 8, 2013, 03:58
Ehsan
any more remarks?
Old   March 8, 2013, 08:59
Hi Ehsan,
Regarding the bcs, I have replied on http://www.cfd-online.com/Forums/ope...tml#post412540
I also faced the similar problem i.e velocity going supersonic and solution blowing up. I then changed the relaxation parameters suggested by niklas in the post mentioned above.
In my case, I monitored the absolute pressure at inlet and it went negative for first few iterations. Are you experiencing the same problem?
Old   March 8, 2013, 18:45
Ehsan
i set fixedValue at outlet and it fixed the problem!
But in inlet the issue is remain and because my case is transient i think its important and i can't use relaxations.i tried to limit velocity by groovyBC but i didn't have any effect.
I'll be glad if you let me know your progress.
Old   March 9, 2013, 21:13
I was using simpleFOAM (steady state) and so was not concerned with the transient solution
the relaxation factors prevented solution from blowing up but the problem for first few iterations still persists
Old   March 15, 2013, 04:38
Ehsan
did anyone find a way or have an idea to limiting velocity at initial iterations when using total pressure at inlet?
Totalpressure Ansys Leuchte CFX 2 April 9, 2013 18:56
(AutoGRID 5) Problem in Geometry definition of propeller venkat_aero2007 Fidelity CFD 14 July 31, 2012 14:05
BC settings to expand pressure on atmosphere - simpleFoam / totalPressure sErik OpenFOAM Running, Solving & CFD 1 June 15, 2011 02:49
OpenFOAM static build on Cray XT5 asaijo OpenFOAM Installation 9 April 6, 2011 12:21
OpenFOAM14 for Mac OSX Darwin 104 gschaider OpenFOAM Installation 118 July 20, 2008 05:19
