mpiRun Stop AND Re-Start
Like Tree1Likes
  • 1 Post By JR22
Old   April 2, 2013, 21:11
Question mpiRun Stop AND Re-Start
JR22's Avatar
Jose Rey
JR22 will become famous soon enough
How do I stop and then re-start mpirun for a case?.
I use mpirun from within my case directory in the following way:
mpirun -np 4 simpleFoam -parallel | tee log/simpleFoam.log
This is the content of my controlDict (set to save @ iter 1000); I want to change a few parameters (related to convergence) and then restart (as described in this post : http://www.cfd-online.com/Forums/ope...tml#post412941 ) :
FoamFile
    version 2.0;
    format ascii;
    class dictionary;
    location system;
    object controlDict;
    startFrom startTime;
    startTime 0;
    stopAt endTime;
    endTime 2000.0;
    deltaT 1.0;
    writeControl timeStep;
    writeInterval 1000.0;
    purgeWrite 0;
    writeFormat ascii;
    writePrecision 10;
    writeCompression uncompressed;
    timeFormat general;
    timePrecision 6;
    graphFormat raw;
    runTimeModifiable true;
I've made the effort to look around and truly have not found an answer that can help me. The original file was created using helyx-OS. Thank you very much in advance.
Last edited by JR22; April 2, 2013 at 21:48. Reason: relevant information to changing parameters for convergence
JR22 is offline   Reply With Quote
Old   April 2, 2013, 22:11
Chris L
vbchris is on a distinguished road
You might be looking for
startFrom latestTime;
This will restart the simulation at the last recorded time step.
vbchris is offline   Reply With Quote
Old   April 2, 2013, 22:33
Default Stopping and Restarting an openFoam run
JR22's Avatar
Jose Rey
Hi Chris,
I think I got it. I was looking for some of flag to put on the mpirun command; obviously I was lost. This is what I should do:
  1. After 1000 iterations (I have it set to save then), break the process CTRL-C in the Terminal should do it.
  2. Make my changes to speedup convergence (e.g. change schemes to 2nd order)
  3. Change "startFrom startTime;" to "startFrom latestTime;" in the controlDict file.
  4. Go back to the terminal and run that sucker again (i.e. mpirun -np 4 simpleFoam -parallel | tee log/simpleFoam.log).
Thank you very much, it worked perfectly.
Originally Posted by vbchris View Post
You might be looking for startFrom latestTime;
Alpha001 likes this.
helyx-os, mpirun, openfoam 2.1.x, parallel execution, restart
