BubbleInterTrackFoam with surfactant
Old   March 18, 2013, 06:47
Unhappy BubbleInterTrackFoam with surfactant
Amanda Mattos Charin
amattosc is on a distinguished road
Hi everyone,
I was hoping to get some help here about this solver.
I've tried to run the original tutorial "bubble2D_r0.75mm" and it worked fine, but I noticed that the option "cleanInterface" was set as "Yes" in "freeSurfaceProperties".
I've looked into the code and for what I understood with this option enabled, BubbleInterTrackFoam doesn't solve the surfactant's conservation equation (as expected).
So, I've tried to change this option to "No" with the add of "soluble yes" at the end of "freeSurfaceProperties". I've also added an initial field for the concentration of surfactant as a "volScalarField".
The result was the following error:
"--> FOAM FATAL IO ERROR:
cannot open file
file: /home/amanda/OpenFOAM/amanda-1.6-ext/run/tutorials/surfaceTracking/bubbleInterTrackFoam/bubble2D_r0.75mm-teste/1e-05/Cs at line 0.
From function regIOobject::readStream()
in file db/regIOobject/regIOobjectRead.C at line 62.
FOAM exiting"
I've tried to locate where the solver tries to read Cs and found its declaration in the middle of "freeSurface" in the file "makeFreeSurfaceData.C":
"surfactConcPtr_ = new areaScalarField
IOobject
"Cs",
DB().timeName(),
mesh(),
IOobject::MUST_READ,
IOobject::AUTO_WRITE
aMesh()
But at this point the solver had already entered the time loop and was trying to read from a file that has not been created yet.
It might be a silly mistake because I'm a new user of OpenFoam, but could someone give me a hand?
Thanks in advance.
Amanda Mattos
amattosc is offline   Reply With Quote
Old   March 18, 2013, 13:16
akidess's Avatar
Anton Kidess
akidess will become famous soon enough
Create the file yourself to specify the initial surfactant distribution.
*On twitter @akidTwit
*Spend as much time formulating your questions as you expect people to spend on their answer.
akidess is offline   Reply With Quote
Old   March 18, 2013, 17:24
Thanks for the answer but as I said in my previous post I've already created this file.
The problem is that the solver tries to read this concentration after it started the time loop so the concentration for time 0 exists but for the next time 1e-5 it doesnt.
Any more ideas?
Old   March 19, 2013, 01:44
akidess's Avatar
Anton Kidess
Ah, yes. You said you created a volScalarField though, whereas what you need is an areaScalarField?
Old   March 19, 2013, 05:14
I've tried to create a Cs file as an areaScalarField but it didn't work anyway.
Old   September 22, 2014, 12:21
Chiara
Chia is on a distinguished road
Hi Amanda,
I have the same problem with bubbleInterTrackFoam and the field Cs.
Did you solve the problem then? If yes, can you tell me how?
Thank you!
Chiara
Chia is offline   Reply With Quote
Old   September 24, 2014, 08:08
Originally Posted by Chia View Post
Hi Amanda,
Thank you!
Chiara
Hello Chiara,
Try calling this function "interface.surfactantConcentration();" before line 22 in file "createSurfactantConcentrationField.H" as shown in the code below and then recompile the solver.
I hope it helps!
// Volume surfactant concentration
volScalarField* CPtr = NULL;
if(!interface.cleanInterface() && interface.surfactant().soluble())
    Info << "\nReading field C\n" << endl;
    CPtr = new volScalarField
        IOobject
            "C",
            runTime.timeName(),
            mesh,
        mesh
    if(runTime.timeIndex() == 0)
        const dimensionedScalar& CA =
            interface.surfactant().surfactBulkConc();
        dimensionedScalar CB("CB", CA.dimensions(), 0);
        (*CPtr) = fluidIndicator*(CA - CB) + CB;
        if
            CPtr->boundaryField()[spacePatchID].type()
         == inletOutletFvPatchScalarField::typeName
            inletOutletFvPatchScalarField& spaceC =
                refCast<inletOutletFvPatchScalarField>
            spaceC.refValue() = CA.value();
        else
            FatalErrorIn(args.executable())
                << "Boundary condition for bulk surfactant concentration at "
                    << "space patch isn't and should be: "
                    << inletOutletFvPatchScalarField::typeName
                    << abort(FatalError);
        CPtr->correctBoundaryConditions();
        CPtr->write();
Old   October 14, 2014, 09:00
Chiara
Hi Amanda,
sorry for the delay of my feedback. Your correction worked fine, thank you!
Best,
Chiara
Old   June 15, 2016, 06:13
Default recompile
Jan Zawala
Johnzi is on a distinguished road
Could you please advise how to recompile the code?
Thanks
Johnzi is offline   Reply With Quote
Old   May 18, 2019, 05:09
Ali
ali_jan is on a distinguished road
Hi Amanda
thank you for your advice
Thanks
ali_jan is offline   Reply With Quote
bubbleintertrackfoam, surfactant
bubbleInterTrackFoam and Mass transport kel85uk OpenFOAM 3 May 11, 2016 07:48
bubbleInterTrackFoam in parallel (fluidIndicator) pbohorquez OpenFOAM Running, Solving & CFD 6 January 18, 2015 21:54
interTrackFoam and bubbleInterTRackFoam problems hfsf OpenFOAM 0 December 26, 2012 02:12
bubbleInterTrackFoam tutorial kel85uk OpenFOAM 16 December 21, 2012 09:47
How much surfactant affect surface tension qunwuhe@hotmail.com Main CFD Forum 0 June 7, 2007 05:01
