where the codes for limiting of velocity should be added in rhoPimpleFoam? |
March 19, 2013, 12:59 |
Ehsan
Rep Power: 26 |
where the below codes for limiting velocity on a patch should be added in rhoPimpleFoam?
word patchName = "NAME_OF_THE_PATCH"; label patchID = mesh.boundary().findPatchID(patchName2); forAll(U.boundaryField()[patchID],faceI) { U.boundaryField()[patchID][faceI].component(0)=some value; } Code:
#include "fvCFD.H" #include "basicPsiThermo.H" #include "turbulenceModel.H" #include "bound.H" #include "pimpleControl.H" // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // int main(int argc, char *argv[]) { #include "setRootCase.H" #include "createTime.H" #include "createMesh.H" pimpleControl pimple(mesh); #include "createFields.H" #include "initContinuityErrs.H" // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Info<< "\nStarting time loop\n" << endl; while (runTime.run()) { #include "readTimeControls.H" #include "compressibleCourantNo.H" #include "setDeltaT.H" runTime++; Info<< "Time = " << runTime.timeName() << nl << endl; #include "rhoEqn.H" // --- Pressure-velocity PIMPLE corrector loop while (pimple.loop()) { #include "UEqn.H" #include "hEqn.H" // --- Pressure corrector loop while (pimple.correct()) { #include "pEqn.H" } if (pimple.turbCorr()) { turbulence->correct(); } } runTime.write(); Info<< "ExecutionTime = " << runTime.elapsedCpuTime() << " s" << " ClockTime = " << runTime.elapsedClockTime() << " s" << nl << endl; } Info<< "End\n" << endl; return 0; } Code:
// Solve the Momentum equation tmp<fvVectorMatrix> UEqn ( fvm::ddt(rho, U) + fvm::div(phi, U) + turbulence->divDevRhoReff(U) ); UEqn().relax(); volScalarField rAU(1.0/UEqn().A()); if (pimple.momentumPredictor()) { solve(UEqn() == -fvc::grad(p)); K = 0.5*magSqr(U); } Code:
{ fvScalarMatrix hEqn ( fvm::ddt(rho, h) + fvm::div(phi, h) - fvm::laplacian(turbulence->alphaEff(), h) == dpdt - (fvc::ddt(rho, K) + fvc::div(phi, K)) ); hEqn.relax(); hEqn.solve(); thermo.correct(); } Code:
rho = thermo.rho(); rho = max(rho, rhoMin); rho = min(rho, rhoMax); rho.relax(); U = rAU*UEqn().H(); if (pimple.nCorrPISO() <= 1) { UEqn.clear(); } if (pimple.transonic()) { surfaceScalarField phid ( "phid", fvc::interpolate(psi) *( (fvc::interpolate(U) & mesh.Sf()) + fvc::ddtPhiCorr(rAU, rho, U, phi) ) ); while (pimple.correctNonOrthogonal()) { fvScalarMatrix pEqn ( fvm::ddt(psi, p) + fvm::div(phid, p) - fvm::laplacian(rho*rAU, p) ); pEqn.solve(mesh.solver(p.select(pimple.finalInnerIter()))); if (pimple.finalNonOrthogonalIter()) { phi == pEqn.flux(); } } } else { phi = fvc::interpolate(rho)* ( (fvc::interpolate(U) & mesh.Sf()) + fvc::ddtPhiCorr(rAU, rho, U, phi) ); while (pimple.correctNonOrthogonal()) { // Pressure corrector fvScalarMatrix pEqn ( fvm::ddt(psi, p) + fvc::div(phi) - fvm::laplacian(rho*rAU, p) ); pEqn.solve(mesh.solver(p.select(pimple.finalInnerIter()))); if (pimple.finalNonOrthogonalIter()) { phi += pEqn.flux(); } } } #include "rhoEqn.H" #include "compressibleContinuityErrs.H" // Explicitly relax pressure for momentum corrector p.relax(); // Recalculate density from the relaxed pressure rho = thermo.rho(); rho = max(rho, rhoMin); rho = min(rho, rhoMax); rho.relax(); Info<< "rho max/min : " << max(rho).value() << " " << min(rho).value() << endl; U -= rAU*fvc::grad(p); U.correctBoundaryConditions(); K = 0.5*magSqr(U); dpdt = fvc::ddt(p); Last edited by immortality; March 19, 2013 at 13:22. |
Plotting Radial Velocity and Tangential Velocity in CFD Post | ashtonJ | CFX | 5 | July 13, 2015 02:49 |
help with UDF for contact angle based on contact line velocity | gandesk | Fluent UDF and Scheme Programming | 14 | October 29, 2012 13:58 |
how to compute relative velocity from absolute? | spk | Main CFD Forum | 3 | July 9, 2010 08:42 |
Terrible Mistake In Fluid Dynamics History | Abhi | Main CFD Forum | 12 | July 8, 2002 09:11 |
Convection velocity of Coherent structures | Jongdae Kim | Main CFD Forum | 3 | February 5, 2002 04:04 |
