initialization of scalar source using volume integral of source cells
Old   March 22, 2013, 07:21
Default initialization of scalar source using volume integral of source cells
Marcus Letzel
letzel is on a distinguished road
Dear All,
my modified pisoFoam solver includes a passive scalar transport equation for LES:
        turbulence->correct();
        solve
            fvm::ddt(s1)
          + fvm::div(phi, s1)
          - fvm::laplacian(turbulence->nut(), s1)
          s1Source
        runTime.write();
In createFields.H, both s1 and s1Source are defined per Volume (m^-3):
    volScalarField s1
        IOobject
            "s1",
            runTime.timeName(),
            mesh,
            IOobject::READ_IF_PRESENT,
            IOobject::AUTO_WRITE
        mesh,
        dimensionedScalar("s1", dimensionSet(1,-3,0,0,0,0,0), scalar(0))
    Info<< "Reading field s1Source\n" << endl;
    volScalarField s1Source
        IOobject
            "s1Source",
            runTime.timeName(),
            mesh,
        mesh,
        dimensionedScalar("s1Source", dimensionSet(1,-3,-1,0,0,0,0), scalar(0))
My practical scenario is an air pollution simulation where I know the source volume and its (total) emission rate in kg/s.
So far, I initialize s1Source using a region in setFieldsDict:
    boxToCell
        box (35.75 0.0 27.5) (36.25 0.5 28.5);
        fieldValues
            volScalarFieldValue s1Source 0.001
In my current mesh, setFields finds and sets two cells, and the total emission rate depends on the size of these cells. This is not what I want.
Instead, I need an algorithm that sets s1Source in these cells to values so that the volume integral of s1Source over these cells matches a prescribed total emission rate.
Can this be achieved using setFields, or perhaps funkySetFields? If not, how and in which file could it be coded?
Best regards,
Marcus
letzel is offline   Reply With Quote
Old   March 24, 2013, 10:33
Assistant Moderator
Bernhard Gschaider
Originally Posted by letzel View Post
Dear All,
Somewhere between funkySetFields, coded and your solution: swak4Foam has something called expressionSource (search for that on the forum and you'll find an explanation how to integrate that) that you insert into your solver (at the place where you insert the field). That evaluates a funkySetFields-like expression and adds it as a source term. Built on that swak offers you child classes to basicSource (in OF up to 2.1) and fvOption (since 2.1) which you could add to your solver similarly. With that your solver doesn't need swak, but it can choose to use it via runtime selection.
If you don't want to change the solver anymore there is always the possibility to modify the s1-field with the modifyField-functionObject
Note: I don't use "Friend"-feature on this forum out of principle. Ah. And by the way: I'm not on Facebook either. So don't be offended if I don't accept your invitation/friend request
Old   May 13, 2015, 03:58
Yan Wang
wayne14 is on a distinguished road
Dear All,
        solve
            fvm::ddt(s1)
          + fvm::div(phi, s1)
          s1Source
        runTime.write();
    volScalarField s1
        IOobject
            "s1",
            runTime.timeName(),
            mesh,
        mesh,
        IOobject
            "s1Source",
            runTime.timeName(),
            mesh,
        mesh,
    boxToCell
        fieldValues
Best regards,
Marcus
Hi Marcus,
I met the same problem. Did you find any solution?
Thank you!
wayne14 is offline   Reply With Quote
[swak4Foam] groovyBC in openFOAM-2.0 for parabolic velocity bc ofslcm OpenFOAM Community Contributions 25 March 6, 2017 10:03
[swak4Foam] swak4foam building problem GGerber OpenFOAM Community Contributions 54 April 24, 2015 16:02
friction forces icoFoam ofslcm OpenFOAM 3 April 7, 2012 10:57
pisoFoam compiling error with OF 1.7.1 on MAC OSX Greg Givogue OpenFOAM Programming & Development 3 March 4, 2011 17:18
physical boundary error!! kris Siemens 2 August 3, 2005 00:32
