Creating a tool to interpolate results
Old   March 24, 2013, 18:47
Default Creating a tool to interpolate results
Luis Batista
Luis Batista is on a distinguished road
Dear Users,
I am developing a function to interpolate results between nodal results points for an incompressible, laminar, 2D flow.
I am aware that there are some built-in function inside OpenFoam to do this by sampleDict but I would need to implement a 9 node interpolation polynomial.
I can write an external subroutine to read the results and find the interpolated results, however, I has wondering if:
1- Can I add write an interpolation routine inside OpenFoam and add it to sampleDict in order that I can call it through the command-line sample.
2- In the case 1) is possible, I need to solve a small linear system for U and p. I have a couple of them programmed in Fortran and I could reprogram them in C++, however, isn't it possible to use the linear matrix solvers from OpenFoam? If so, how can this be achieved?
3- Which procedures do I have available to access the results from the solver in order that I can manipulate the results?
note: I am a beginner in OpenFoam, if you take the patience to answer, please mind that
Best regards,
Luis Batista
Luis Batista is offline   Reply With Quote
Old   April 6, 2013, 01:06
RPS
RPS is on a distinguished road
Hi Luis,
I had implemented a new interpolation technique for FEM calculations for force and moments in a simulation software. Depending on how far your node sets are the error in interpolation will vary. Let me know if you are interested in it.
BR,
Raghunandan Patthar
raghunandan.patthar@gmail.com
RPS is offline   Reply With Quote
Old   April 11, 2013, 08:15
Luis Batista
I will try to express better my needs.
I have built in FORTRAN an interpolation tool that carries out operations in the result files (p.e. Ux, Uy, pressure).
I would like to write this interpolation tool in c++ and use it as an "interporlation scheme", that I can use in other OpenFoam operations, as per example, for sampling data for plotting throught sample.
I believe this should be possible but I would like to hear from more experienced people if this is wise to do.
Regards,
Luis
interpolation, linear system
[Commercial meshers] Fluent3DMeshToFoam simvun OpenFOAM Meshing & Mesh Conversion 50 January 19, 2020 15:33
OpenFOAM - Validation of Results Ahmed OpenFOAM Running, Solving & CFD 10 May 13, 2018 18:28
Oscillating Airfoil Poor Results at High k (reduced frequency) dancfd OpenFOAM Running, Solving & CFD 3 November 4, 2013 08:32
Transient Run - Output "Time" in partial results? evcelica CFX 2 May 16, 2012 21:36
Problems with Meshing: Collapsed Cells Emmanuel Resch Siemens 1 July 30, 2007 03:02
