l Inf in wave transmissive bc
Like Tree10Likes
  • 1 Post By VSass
  • 9 Post By Gatoscar
Old   March 30, 2013, 06:56
Default l Inf in wave transmissive bc
VS
VSass is on a distinguished road
Hey guys,
does anybody know how l inf works in wave transmissive boundary condition?
In Wiki it says it's a measure of how far the farfield should be, but i don't know which exact value to give.How we difine it on each problem?
Thanks
JMOliva likes this.
VSass is offline   Reply With Quote
Old   March 30, 2013, 07:28
immortality's Avatar
Ehsan
immortality is on a distinguished road
it indicates how much of wave is reflected and how much is transferred out of the domain.you could try some values.it depends of the dimensions of your problem.if its too low it will be like totalPressure or fixedValue.set it .1 or 1 to test which is more appropriate.
immortality is offline   Reply With Quote
Old   April 1, 2013, 04:37
VS
Hey,
thanks for the reply. Is there anyway to precisely set the value? I mean, why to set 0.1 and not 0.3 or something else? Also, does it corresponds on a characteristic length, let's say, a diameter or a mean chord?
Regards
Old   April 1, 2013, 05:48
Ehsan
i think it is more a triel and error work if someone correct me.whats your problem?if you want to the waves reach the patches transfer very close to completely (maybe some numerical waves reflect) choose a large number.there are some papers i have seen about this bc in the net.
Are you certain to use this bc?why?
Old   April 1, 2013, 06:02
VS
Well, i have compressible flow around a sphere in a spherical far field. I tried inletOutlet/outletInlet BCs for U,T,p but i didn't get the correct solution. I read somewhere that wavetransimissive bc is better for compressible unsteady problems. I'm trying to set the correct l inf in order to have an accurate solution and no reflections.
Old   April 1, 2013, 09:40
Ehsan
did you reach the appropriate value?let me know.also see tutorials.
Old   April 8, 2013, 15:48
Ehsan
did you succeed?how?with spherical or cylindrical farfield?
Old   April 9, 2013, 04:01
VS
No success yet. If waveTransmissive is p outlet/Inlet for compressible flow, then it should work. I tried also zeroGradient for temperature, but it wasn't helpful.My flow doesn't seem to spread behind the sphere, it seems like we have reflections from the outer boundary.
Old   January 9, 2014, 21:07
Default test
Oscar Ochoa
Gatoscar is on a distinguished road
Originally Posted by VSass View Post
Hey,
Regards
Hello there
I did my own tests to understand the behaviour of lInf in the waveTransmissive BC. I took the wedge example in the rhoCentralFoam solver and used Ma=2.0. Keeping everything fixed I only modified the value of lInf (the results can be seen in the attached images. The image file name is the value given i.e. plInf10e-2 means lInf=10e-2). The way I understand for values lInf>1 the far-field condition is outside of the domain, for values lInf>1 the far-field condition is inside the domain. I did tests whit values grater than 1 (lInf=10e2 and lInf=10e3), but the results were the same that lInf=10e0.
Regards
Gatoscar is offline   Reply With Quote
Old   January 10, 2014, 03:13
VS
Oscar,
I agree with your results. As they show, for different lInf<1 we have a different problem each time. Truly representative work.
Regards
Old   January 10, 2014, 05:19
Ehsan
dear Oscar,what do you mean by being far-field inside the domain?whats the physical meaning of such situation?
Injustice Anywhere is a Threat for Justice Everywhere.Martin Luther King.
To Be or Not To Be,Thats the Question!
The Only Stupid Question Is the One that Goes Unasked.
wavetransmissive
Pressure for wave height in an Water Wave Tank Cluain CFX 8 December 6, 2021 03:58
Linear wave force on a cylinder Pumbam CFX 1 July 16, 2017 02:01
Wave Transmissive and Advective sahm OpenFOAM Programming & Development 8 November 15, 2015 05:15
WAVE TANK star-ccm+ . wave height dampens. WHY? muhsin STAR-CCM+ 3 October 9, 2012 13:24
Scaling up a wave energy converter - free surface flow mark_l CFX 3 February 17, 2010 16:57
