Segmentation Fault w/ compiled OF 2.2.0 - motorBike example
Old   March 15, 2013, 11:39
Unhappy Solved: Segmentation Fault w/ compiled OF 2.2.0 - motorBike example
sudo is on a distinguished road
So, as suggested by another member here I was trying to run the motorBike example found in
$FOAM_TUTORIALS/incompressible/simpleFoam/motorBike
I executed from a Linux (Ubuntu 12.10 64bit) terminal
$ ./Allrun -v
and I have got the following
Running surfaceFeatureExtract on /home/OF_user/OpenFOAM/OF_user-2.2.0/run/tutorials/incompressible/simpleFoam/motorBike
Running blockMesh on /home/OF_user/OpenFOAM/OF_user-2.2.0/run/tutorials/incompressible/simpleFoam/motorBike
Running decomposePar on /home/OF_user/OpenFOAM/OF_user-2.2.0/run/tutorials/incompressible/simpleFoam/motorBike
Running snappyHexMesh in parallel on /home/OF_user/OpenFOAM/OF_user-2.2.0/run/tutorials/incompressible/simpleFoam/motorBike using 6 processes
Segmentation fault (core dumped)
`0.org' -> `./processor0/0'
`0.org/nut' -> `./processor0/0/nut'
`0.org/include' -> `./processor0/0/include'
`0.org/include/initialConditions' -> `./processor0/0/include/initialConditions'
`0.org/include/frontBackUpperPatches' -> `./processor0/0/include/frontBackUpperPatches'
`0.org/include/fixedInlet' -> `./processor0/0/include/fixedInlet'
`0.org/omega' -> `./processor0/0/omega'
`0.org/k' -> `./processor0/0/k'
`0.org/p' -> `./processor0/0/p'
`0.org/U' -> `./processor0/0/U'
`0.org' -> `./processor1/0'
`0.org/nut' -> `./processor1/0/nut'
`0.org/include' -> `./processor1/0/include'
`0.org/include/initialConditions' -> `./processor1/0/include/initialConditions'
`0.org/include/frontBackUpperPatches' -> `./processor1/0/include/frontBackUpperPatches'
`0.org/include/fixedInlet' -> `./processor1/0/include/fixedInlet'
`0.org/omega' -> `./processor1/0/omega'
`0.org/k' -> `./processor1/0/k'
`0.org/p' -> `./processor1/0/p'
`0.org/U' -> `./processor1/0/U'
`0.org' -> `./processor2/0'
`0.org/nut' -> `./processor2/0/nut'
`0.org/include' -> `./processor2/0/include'
`0.org/include/initialConditions' -> `./processor2/0/include/initialConditions'
`0.org/include/frontBackUpperPatches' -> `./processor2/0/include/frontBackUpperPatches'
`0.org/include/fixedInlet' -> `./processor2/0/include/fixedInlet'
`0.org/omega' -> `./processor2/0/omega'
`0.org/k' -> `./processor2/0/k'
`0.org/p' -> `./processor2/0/p'
`0.org/U' -> `./processor2/0/U'
`0.org' -> `./processor3/0'
`0.org/nut' -> `./processor3/0/nut'
`0.org/include' -> `./processor3/0/include'
`0.org/include/initialConditions' -> `./processor3/0/include/initialConditions'
`0.org/include/frontBackUpperPatches' -> `./processor3/0/include/frontBackUpperPatches'
`0.org/include/fixedInlet' -> `./processor3/0/include/fixedInlet'
`0.org/omega' -> `./processor3/0/omega'
`0.org/k' -> `./processor3/0/k'
`0.org/p' -> `./processor3/0/p'
`0.org/U' -> `./processor3/0/U'
`0.org' -> `./processor4/0'
`0.org/nut' -> `./processor4/0/nut'
`0.org/include' -> `./processor4/0/include'
`0.org/include/initialConditions' -> `./processor4/0/include/initialConditions'
`0.org/include/frontBackUpperPatches' -> `./processor4/0/include/frontBackUpperPatches'
`0.org/include/fixedInlet' -> `./processor4/0/include/fixedInlet'
`0.org/omega' -> `./processor4/0/omega'
`0.org/k' -> `./processor4/0/k'
`0.org/p' -> `./processor4/0/p'
`0.org/U' -> `./processor4/0/U'
`0.org' -> `./processor5/0'
`0.org/nut' -> `./processor5/0/nut'
`0.org/include' -> `./processor5/0/include'
`0.org/include/initialConditions' -> `./processor5/0/include/initialConditions'
`0.org/include/frontBackUpperPatches' -> `./processor5/0/include/frontBackUpperPatches'
`0.org/include/fixedInlet' -> `./processor5/0/include/fixedInlet'
`0.org/omega' -> `./processor5/0/omega'
`0.org/k' -> `./processor5/0/k'
`0.org/p' -> `./processor5/0/p'
`0.org/U' -> `./processor5/0/U'
Running patchSummary in parallel on /home/OF_user/OpenFOAM/OF_user-2.2.0/run/tutorials/incompressible/simpleFoam/motorBike using 6 processes
Running potentialFoam in parallel on /home/OF_user/OpenFOAM/OF_user-2.2.0/run/tutorials/incompressible/simpleFoam/motorBike using 6 processes
Running simpleFoam in parallel on /home/OF_user/OpenFOAM/OF_user-2.2.0/run/tutorials/incompressible/simpleFoam/motorBike using 6 processes
Running reconstructParMesh on /home/OF_user/OpenFOAM/OF_user-2.2.0/run/tutorials/incompressible/simpleFoam/motorBike
Running reconstructPar on /home/OF_user/OpenFOAM/OF_user-2.2.0/run/tutorials/incompressible/simpleFoam/motorBike
On my Ubuntu 12.10 64 bit virtualbox on my windows machine, where OpenFoam 2.2.0 was installed from the repository (as a binary, not compiled), the tutorial worked without a hitch.
Any idea what's the cause of this? Thanks.
EDIT: Just wanted to say that the introductory "Cavity" tutorial worked just fine with the compiled OF, so my "newbie" guess is that it has to do with SnappyHexMesh.
sudo is offline   Reply With Quote
Old   March 25, 2013, 11:41
I saw there is a similar earlier thread, here:
http://www.cfd-online.com/Forums/ope...tml#post416285
So I posted my problem there.
Old   March 26, 2013, 22:48
starter
sihaqqi is on a distinguished road
I have the same problem. When I type in simpleFoam, it does 50 calculations and say Segmentation fault (core dumped). If you can perhaps advise, I shall be grateful
Regards
sihaqqi is offline   Reply With Quote
Old   April 2, 2013, 17:27
SOLVED!!!! Thanks to Bruno, look here:
http://www.cfd-online.com/Forums/ope...r-upgrade.html
Segmentation fault when running dieselFoam or dieselEngineFoam in parallel francesco OpenFOAM Bugs 4 May 2, 2017 21:59
segmentation fault when installing OF-2.1.1 on a cluster Rebecca513 OpenFOAM Installation 9 July 31, 2012 15:06
Segmentation fault in interFoam run through openMPI voingiappone OpenFOAM 16 November 2, 2011 06:49
Segmentation Fault Shawn_A OpenFOAM Running, Solving & CFD 6 October 31, 2011 14:38
ParaView segmentation fault only for multiphase gwierink OpenFOAM 9 March 25, 2010 07:23
