chord lenght reduction for airfoil analysis using openfoam |
April 10, 2013, 01:50 |
Akshay Bagi
Rep Power: 13 |
I am using OpenFOAM for analysis of NACA4412 airfoil. chord length is 1m. Now i want to analyse the same for different Re by varying the chord lenght. I dont know how to vary the chord length. Please help |
April 10, 2013, 04:03 |
Håkon Bartnes Line
Rep Power: 14 |
As long as the Reynolds number is the only dimensionless quantity that's relevant for your analysis, then doubling the inlet velocity or halving nu (the kinematic viscosity) will have the same effect.
If you do want to increase the chord length, then there are different ways of doing it, depending on if you're using blockMesh or snappyhexMesh. For blockMesh, you simply double the parameter "convertToMeters", which you'll find near the top of your blockMeshDict. For snappyHexMesh, you need to launch paraFoam, and open the .obj or .stl-file that defines the wing geometry (you can find it in the "constant/triSurface" folder of your case directory. Apply the "transform"-filter, and set the parameter "scale" to 2 in all directions. Save as an stl-file. |
April 12, 2013, 03:09 |
Akshay Bagi
Rep Power: 13 |
@hakonbar: I am not using either hexmesh or snappy. I mesh it in gmsh and convert it to openfoam mesh. I have used digitiser for now but it approximates the profile, so it may not be the accurate profile. Any other suggestions?
April 12, 2013, 05:46 |
Håkon Bartnes Line
Rep Power: 14 |
I've never used gmsh myself, so I don't know, sorry. As long as the wing is the only solid object in your analysis, and you don't have to define its size in relation to any other object in the flow field, then i don't think it would necessary to increase its size - you could just change some other parameter like I suggested earlier.
April 12, 2013, 05:52 |
Akshay Bagi
Rep Power: 13 |
Digitiser is working fine now
Thanks |
April 12, 2013, 07:22 |
Ehsan
Rep Power: 26 |
hi Ashkay
What does digitiser do? I have a problem like you.can i use digitiser to change geometry? I've meshed in gambit and want to use in openfoam.could digitiser help me in changing in naca0012? Where can i download it?is it free? |
April 13, 2013, 01:09 |
Akshay Bagi
Rep Power: 13 |
Hi immortality
Digitiser is used to generate profiles from image files. ex if you have an image file of an airfoil, you can generate its profile from the image using digitiser. This open source, digitizing software converts an image file showing a graph or map, into numbers. Link: http://digitizer.sourceforge.net/ You'll get it here for free. I dont think you can use it to change geometry. You say you have meshed in Gambit. What you can do is you can convert the mesh file into OpenFOAM mesh in OpenFoam using the command 'gambitMeshToFoam' and use it in OpenFOAM. |
OpenFOAM - Validation of Results | Ahmed | OpenFOAM Running, Solving & CFD | 10 | May 13, 2018 18:28 |
Article release about heat transfer analysis with OpenFOAM | luca | OpenFOAM | 7 | March 14, 2013 02:32 |
OpenFOAM Training in Europe and USA | hjasak | OpenFOAM | 0 | August 8, 2008 05:33 |
Stability Analysis of OpenFoam twofluid models | pierre | OpenFOAM Running, Solving & CFD | 1 | March 14, 2007 08:13 |
OpenFOAM Training and Workshop Zagreb 2628Jan2006 | hjasak | OpenFOAM | 1 | February 2, 2006 21:07 |
