diverge in low courant number
Old   April 10, 2013, 19:59
Default diverge in low courant number
immortality's Avatar
Ehsan
immortality is on a distinguished road
i have set a filling process of a tube.i have set totalPressure and totalTemperature in inlet and tube is closed at other end and flow is compressible.
A shoch should occur that occures but has low resolution and other issue is that this sowewhat simple problem diverges at low courants like .1 with printstack error.but in higher cfl's like .6 doesn't occure an error but continuity residuals goes far away zero in minus direction when the shocks hits to wall and residuals after that return back to zero again.
What may be the cause of this strange behaviour?
immortality is offline   Reply With Quote
Old   April 11, 2013, 08:41
Ehsan
my BC's are
p:
left
        type totalPressure;
            p0 uniform 932190;
            gamma 1.4;
            rho rho;
            //psi none;
            U U;
            phi phi;
            value uniform 303975;
T:
left
        type totalTemperature;
        T0 uniform 1248;
        gamma 1.4;
U:
left
       type pressureDirectedInletOutletVelocity;
       inletDirection uniform (1 0 0);
       value uniform (300 0 0);
controlDict:
application     rhoPimpleFoam;
startFrom       latestTime;
startTime       0;
stopAt          endTime;
endTime         0.020708089;
deltaT          5.6e-9;
writeControl    adjustableRunTime;
writeInterval   .000001;
purgeWrite      0;
writeFormat     binary;
writePrecision  10;
writeCompression on;
timeFormat      general;
timePrecision   6;
runTimeModifiable true;
adjustTimeStep  yes;
maxCo           0.6;
maxDeltaT       .0001;
libs ( "libOpenFOAM.so" "libgroovyBC.so" ) ;
and schemes:
ddtSchemes
    default         backward;
gradSchemes
    default         Gauss linear;
    grad(p)         Gauss linear;
    grad(U)         cellLimited leastSquares 1.0;
divSchemes
    default         none;
    div(phi,U)      Gauss upwind;
    div(phid,p)     Gauss upwind;
    div(phi,K)      Gauss upwind;
    div(phi,h)      Gauss upwind;
    div(phi,k)      Gauss upwind;
    div(phi,epsilon) Gauss upwind;
    div(phi,R)      Gauss upwind;
    div(phi,omega)  Gauss upwind;
    div((rho*R))    Gauss linear;
    div(R)          Gauss linear;
    div(U)          Gauss linear;
    div((muEff*dev2(T(grad(U))))) Gauss linear;
    div(tauMC)  Gauss linear;
laplacianSchemes
    default         Gauss linear corrected;//limited .5
    /*laplacian(muEff,U) Gauss linear corrected;
    laplacian(mut,U) Gauss linear corrected;
    laplacian(DkEff,k) Gauss linear corrected;
    laplacian(DepsilonEff,epsilon) Gauss linear corrected;
    laplacian(DREff,R) Gauss linear corrected;
    laplacian(DomegaEff,omega) Gauss linear corrected;
    laplacian((rho*(1|A(U))),p) Gauss linear corrected;
    laplacian(alphaEff,h) Gauss linear corrected;
    laplacian(k,T)   Gauss linear corrected;
    laplacian(alpha,e) Gauss linear corrected;
    laplacian(alphaEff,e)  Gauss linear corrected;*/
interpolationSchemes
    default         linear;
snGradSchemes
    default       corrected;//limited .5
fluxRequired
    default         no;
    p               ;
AMI speed performance danny123 OpenFOAM 21 October 24, 2020 04:13
Turbulence model for low Reynolds number flow? Nokadu Main CFD Forum 3 May 26, 2013 11:42
same geometry,structured and unstructured mesh,different behaviour. sharonyue OpenFOAM Running, Solving & CFD 13 January 2, 2013 22:40
pisoFoam with k-epsilon turb blows up - Some questions Heroic OpenFOAM Running, Solving & CFD 26 December 17, 2012 03:34
Courant number, patches, etc oort OpenFOAM 1 July 24, 2009 18:05
